CMake Error: include could not find load file: /cmake/mcuboot.cmake
I've been wrestling with the NRF9160 toolchain for a couple days now, gotta say it's a complete nightmare compared to your lovely NRF5 toolchain.
Currently stuck here:
~/Projects/NRF/NRF91-SDK/sdk-nrf/samples/nrf9160/mqtt_simple $ west build -b thingy91_nrf9160
Including boilerplate (Zephyr base): /home/triffid/Projects/NRF/NRF91-SDK/sdk-zephyr/cmake/app/boilerplate.cmake
-- Application: /home/triffid/Projects/NRF/NRF91-SDK/sdk-nrf/samples/nrf9160/mqtt_simple
-- Zephyr version: 2.3.99 (/home/triffid/Projects/NRF/NRF91-SDK/sdk-zephyr)
-- Found Python3: /usr/bin/python3.7 (found suitable exact version "3.7.8") found components: Interpreter
-- git describe failed: fatal: No names found, cannot describe anything.;
BUILD_VERSION is left undefined
-- Board: thingy91_nrf9160
-- Found toolchain: zephyr (/home/triffid/Projects/NRF/zephyr/sdk-ng)
-- Found west: /home/triffid/.local/bin/west (found suitable version "0.7.2", minimum required is "0.7.1")
-- Found dtc: /usr/bin/dtc (found suitable version "1.5.0", minimum required is "1.4.6")
-- Found toolchain: gnuarmemb (/usr)
-- Found BOARD.dts: /home/triffid/Projects/NRF/NRF91-SDK/sdk-nrf/boards/arm/thingy91_nrf9160/thingy91_nrf9160.dts
thingy91_nrf9160.dts.pre.tmp:57.42-69.3: Warning (unique_unit_address_if_enabled): /soc/peripheral@50000000/flash-controller@39000: duplicate unit-address (also used in node /soc/peripheral@50000000/kmu@39000)
thingy91_nrf9160.dts.pre.tmp:306.19-312.3: Warning (unique_unit_address_if_enabled): /soc/peripheral@50000000/clock@5000: duplicate unit-address (also used in node /soc/peripheral@50000000/power@5000)
-- Generated zephyr.dts: /home/triffid/Projects/NRF/NRF91-SDK/sdk-nrf/samples/nrf9160/mqtt_simple/build/zephyr/zephyr.dts
-- Generated devicetree_unfixed.h: /home/triffid/Projects/NRF/NRF91-SDK/sdk-nrf/samples/nrf9160/mqtt_simple/build/zephyr/include/generated/devicetree_unfixed.h
Parsing /home/triffid/Projects/NRF/NRF91-SDK/sdk-nrf/samples/nrf9160/mqtt_simple/Kconfig
Loaded configuration '/home/triffid/Projects/NRF/NRF91-SDK/sdk-nrf/boards/arm/thingy91_nrf9160/thingy91_nrf9160_defconfig'
Merged configuration '/home/triffid/Projects/NRF/NRF91-SDK/sdk-nrf/samples/nrf9160/mqtt_simple/prj.conf'
Configuration saved to '/home/triffid/Projects/NRF/NRF91-SDK/sdk-nrf/samples/nrf9160/mqtt_simple/build/zephyr/.config'
Kconfig header saved to '/home/triffid/Projects/NRF/NRF91-SDK/sdk-nrf/samples/nrf9160/mqtt_simple/build/zephyr/include/generated/autoconf.h'
warning: The choice symbol BOARD_THINGY91_NRF9160 (defined at
/home/triffid/Projects/NRF/NRF91-SDK/sdk-nrf/boards/arm/thingy91_nrf9160/Kconfig.board:9) was
selected (set =y), but BOARD_THINGY91_NRF9160NS (defined at
/home/triffid/Projects/NRF/NRF91-SDK/sdk-nrf/boards/arm/thingy91_nrf9160/Kconfig.board:13) ended up
as the choice selection. See
docs.zephyrproject.org/.../CONFIG_BOARD_THINGY91_NRF9160.html and/or
look up BOARD_THINGY91_NRF9160 in the menuconfig/guiconfig interface. The Application Development
Primer, Setting Configuration Values, and Kconfig - Tips and Best Practices sections of the manual
might be helpful too.
-- The C compiler identification is GNU 10.2.0
-- The CXX compiler identification is GNU 10.2.0
-- Found assembler: /usr/bin/arm-none-eabi-gcc
-- Cache files will be written to: /home/triffid/.cache/zephyr
=== child image spm - thingy91_nrf9160 begin ===
-- Application: /home/triffid/Projects/NRF/NRF91-SDK/sdk-nrf/samples/nrf9160/spm
-- Generated zephyr.dts: /home/triffid/Projects/NRF/NRF91-SDK/sdk-nrf/samples/nrf9160/mqtt_simple/build/spm/zephyr/zephyr.dts
-- Generated devicetree_unfixed.h: /home/triffid/Projects/NRF/NRF91-SDK/sdk-nrf/samples/nrf9160/mqtt_simple/build/spm/zephyr/include/generated/devicetree_unfixed.h
Parsing /home/triffid/Projects/NRF/NRF91-SDK/sdk-zephyr/Kconfig
Merged configuration '/home/triffid/Projects/NRF/NRF91-SDK/sdk-nrf/samples/nrf9160/spm/prj.conf'
Configuration saved to '/home/triffid/Projects/NRF/NRF91-SDK/sdk-nrf/samples/nrf9160/mqtt_simple/build/spm/zephyr/.config'
Kconfig header saved to '/home/triffid/Projects/NRF/NRF91-SDK/sdk-nrf/samples/nrf9160/mqtt_simple/build/spm/zephyr/include/generated/autoconf.h'
CMake Error at /home/triffid/Projects/NRF/NRF91-SDK/bootloader/mcuboot/zephyr/CMakeLists.txt:1 (include):
See also "/home/triffid/Projects/NRF/NRF91-SDK/sdk-nrf/samples/nrf9160/mqtt_simple/build/spm/CMakeFiles/CMakeOutput.log".
See also "/home/triffid/Projects/NRF/NRF91-SDK/sdk-nrf/samples/nrf9160/mqtt_simple/build/spm/CMakeFiles/CMakeError.log".
CMake Error at ../../../cmake/multi_image.cmake:182 (message):
CMake generation for spm failed, aborting. Command: 1
../../../cmake/multi_image.cmake:56 (add_child_image_from_source)
../../CMakeLists.txt:8 (add_child_image)
See also "/home/triffid/Projects/NRF/NRF91-SDK/sdk-nrf/samples/nrf9160/mqtt_simple/build/CMakeFiles/CMakeOutput.log".
See also "/home/triffid/Projects/NRF/NRF91-SDK/sdk-nrf/samples/nrf9160/mqtt_simple/build/CMakeFiles/CMakeError.log".
FATAL ERROR: command exited with status 1: /usr/bin/cmake -DWEST_PYTHON=/usr/lib/python-exec/python3.7/python3 -B/home/triffid/Projects/NRF/NRF91-SDK/sdk-nrf/samples/nrf9160/mqtt_simple/build -S/home/triffid/Projects/NRF/NRF91-SDK/sdk-nrf/samples/nrf9160/mqtt_simple -GNinja -DBOARD=thingy91_nrf9160
That cmake file says include(${ZEPHYR_NRF_MODULE_DIR}/cmake/mcuboot.cmake) but I have export ZEPHYR_NRF_MODULE_DIR=/home/triffid/Projects/NRF/NRF91-SDK/sdk-nrf in my ~/.zephyrrc (and also in my environment), so apparently somewhere in this mess of a toolchain that's being unset for some reason.
Any ideas how to fix this and move on?
  • I actually have the same problem. Was this ever resolved?
    -- The C compiler identification is GNU 9.2.1
    -- The CXX compiler identification is GNU 9.2.1
    -- Found assembler: /opt/nordic/ncs/v1.4.2/toolchain/bin/arm-none-eabi-gcc
    CMake Error at /opt/nordic/ncs/v1.4.2/bootloader/mcuboot/zephyr/CMakeLists.txt:1 (include):
    I checked the mcuboot/zephyr/CMakeLists.txt file, which has the following line:
    `include(${ZEPHYR_NRF_MODULE_DIR}/cmake/mcuboot.cmake)`
    so ZEPHYR_NRF_MODULE_DIR is not set.
    I added it to ~/.zephyrrc, i exported it prior to running make, same results.
    OP Author stated
    "I dug the cmake invocation out with strace and added a def for ZEPHYR_NRF_MODULE_DIR"
    Where was this set? Where is this value supposed to be set?
  • Hi Lars,
    Please make a new devzone case, since this one is over 6months old.
    Thank you!
