I tried to drive the flash device W25Q32 on ncs v1.3, but there was no proper spi routine to refer to.
Hi,Håkon Alseth
This has little to do with the logic analyzer, just look at the log log and know that the w25q32 chip is not recognized.
Did you test with the development board PIN 10 11 12 13?
Kind regards, Peter.Min
Hi Peter,
peter.min said:Did you test with the development board PIN 10 11 12 13?
Yes I did.
peter.min said:This has little to do with the logic analyzer, just look at the log log and know that the w25q32 chip is not recognized.
Yes, I understand that the log states that it cannot find the IC, but your logic analyzer trace is not correct; which is the first indication for us to see what happens on the actual SPI lines. Does the IC respond to the initial transaction, does it fail further in the init() structure?
Håkon
I tested the routine you provided, which can be used,
But I made the following changes and couldn't use them.
The modifications are shown in the figure below:
By making cs, these pins can detect the flash chip of the spi interface.
P0.00 01 13 14 15 26 27 08 09
When these pins are cs, the flash chip of the spi interface cannot be detected.
P0.19 18 17 02 03 04 05 06 07 20 21 22 23 24 25 19 18 17 30 31
Hi Peter,
Some GPIOs are used for other purposes. Please see this list for the GPIOs that are already in use:
https://infocenter.nordicsemi.com/topic/ug_nrf91_dk/UG/nrf91_DK/board_controller.html?cp=2_0_5_4_6_0
Håkon
Hi Håkon Alseth,
I'm using an empty board test,
No hardware affects the use of the corresponding IO port.
I also didn't find where P0.13 was occupied by the software.
P0.13 Why not be used as a CS foot.
