Cannot run code on custom board.
Dear All,
I am trying to run a simple program that beacons, prints a message to the UART and toggles a pin on a custom nRF52833 based board. I am using softdevice s113 and nRF5_SDK_16.0.0
My code works on my DK, but not on my board which weird (I am using the NRF52833-QDAA package). On my board I am using the DCDC converter instead of the LDO. My main is the following:
 * Copyright (c) 2014 - 2019, Nordic Semiconductor ASA
 * All rights reserved.
/** @file
 * @defgroup ble_sdk_app_beacon_main main.c
 * @ingroup ble_sdk_app_beacon
 * @brief Beacon Transmitter Sample Application main file.
 * This file contains the source code for an Beacon transmitter sample application.
#include <stdbool.h>
#include <stdint.h>
#include "nordic_common.h"
#include "nrf_soc.h"
#include "nrf_sdh.h"
#include "nrf_sdh_ble.h"
#include "ble_advdata.h"
#include "app_timer.h"
#include "nrf_pwr_mgmt.h"
#include "nrf_drv_gpiote.h"
#include "nrf_delay.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#define APP_BLE_CONN_CFG_TAG            1                                  /**< A tag identifying the SoftDevice BLE configuration. */
#define NON_CONNECTABLE_ADV_INTERVAL    MSEC_TO_UNITS(100, UNIT_0_625_MS)  /**< The advertising interval for non-connectable advertisement (100 ms). This value can vary between 100ms to 10.24s). */
#define APP_BEACON_INFO_LENGTH          0x17                               /**< Total length of information advertised by the Beacon. */
#define APP_ADV_DATA_LENGTH             0x15                               /**< Length of manufacturer specific data in the advertisement. */
#define APP_DEVICE_TYPE                 0x02                               /**< 0x02 refers to Beacon. */
#define APP_MEASURED_RSSI               0xC3                               /**< The Beacon's measured RSSI at 1 meter distance in dBm. */
#define APP_COMPANY_IDENTIFIER          0x0059                             /**< Company identifier for Nordic Semiconductor ASA. as per www.bluetooth.org. */
#define APP_MAJOR_VALUE                 0x01, 0x02                         /**< Major value used to identify Beacons. */
#define APP_MINOR_VALUE                 0x03, 0x04                         /**< Minor value used to identify Beacons. */
#define APP_BEACON_UUID                 0x01, 0x12, 0x23, 0x34, \
                                        0x45, 0x56, 0x67, 0x78, \
                                        0x89, 0x9a, 0xab, 0xbc, \
                                        0xcd, 0xde, 0xef, 0xf0            /**< Proprietary UUID for Beacon. */
#define DEAD_BEEF                       0xDEADBEEF                         /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
#if defined(USE_UICR_FOR_MAJ_MIN_VALUES)
#define MAJ_VAL_OFFSET_IN_BEACON_INFO   18                                 /**< Position of the MSB of the Major Value in m_beacon_info array. */
#define UICR_ADDRESS                    0x10001080                         /**< Address of the UICR register used by this example. The major and minor versions to be encoded into the advertising data will be picked up from this location. */
static ble_gap_adv_params_t m_adv_params;                                  /**< Parameters to be passed to the stack when starting advertising. */
static uint8_t              m_adv_handle = BLE_GAP_ADV_SET_HANDLE_NOT_SET; /**< Advertising handle used to identify an advertising set. */
static uint8_t              m_enc_advdata[BLE_GAP_ADV_SET_DATA_SIZE_MAX];  /**< Buffer for storing an encoded advertising set. */
/**@brief Struct that contains pointers to the encoded advertising data. */
static ble_gap_adv_data_t m_adv_data =
    .adv_data =
        .p_data = m_enc_advdata,
        .len    = BLE_GAP_ADV_SET_DATA_SIZE_MAX
    .scan_rsp_data =
        .p_data = NULL,
        .len    = 0
static uint8_t m_beacon_info[APP_BEACON_INFO_LENGTH] =                    /**< Information advertised by the Beacon. */
    APP_DEVICE_TYPE,     // Manufacturer specific information. Specifies the device type in this
                         // implementation.
    APP_ADV_DATA_LENGTH, // Manufacturer specific information. Specifies the length of the
                         // manufacturer specific data in this implementation.
    APP_BEACON_UUID,     // 128 bit UUID value.
    APP_MAJOR_VALUE,     // Major arbitrary value that can be used to distinguish between Beacons.
    APP_MINOR_VALUE,     // Minor arbitrary value that can be used to distinguish between Beacons.
    APP_MEASURED_RSSI    // Manufacturer specific information. The Beacon's measured TX power in
                         // this implementation.
/**@brief Callback function for asserts in the SoftDevice.
 * @param[in]   line_num   Line number of the failing ASSERT call.
 * @param[in]   file_name  File name of the failing ASSERT call.
 * @details Encodes the required advertising data and passes it to the stack.
 *          Also builds a structure to be passed to the stack when starting advertising.
    uint32_t      err_code;
    ble_advdata_t advdata;
    uint8_t       flags = BLE_GAP_ADV_FLAG_BR_EDR_NOT_SUPPORTED;
    ble_advdata_manuf_data_t manuf_specific_data;
    manuf_specific_data.company_identifier = APP_COMPANY_IDENTIFIER;
    // If USE_UICR_FOR_MAJ_MIN_VALUES is defined, the major and minor values will be read from the
    // UICR instead of using the default values. The major and minor values obtained from the UICR
    // are encoded into advertising data in big endian order (MSB First).
    // To set the UICR used by this example to a desired value, write to the address 0x10001080
    // using the nrfjprog tool. The command to be used is as follows.
    // nrfjprog --snr <Segger-chip-Serial-Number> --memwr 0x10001080 --val <your major/minor value>
    // For example, for a major value and minor value of 0xabcd and 0x0102 respectively, the
    // the following command should be used.
    // nrfjprog --snr <Segger-chip-Serial-Number> --memwr 0x10001080 --val 0xabcd0102
    uint16_t major_value = ((*(uint32_t *)UICR_ADDRESS) & 0xFFFF0000) >> 16;
    uint16_t minor_value = ((*(uint32_t *)UICR_ADDRESS) & 0x0000FFFF);
    uint8_t index = MAJ_VAL_OFFSET_IN_BEACON_INFO;
    m_beacon_info[index++] = MSB_16(major_value);
    m_beacon_info[index++] = LSB_16(major_value);
    m_beacon_info[index++] = MSB_16(minor_value);
    m_beacon_info[index++] = LSB_16(minor_value);
    manuf_specific_data.data.p_data = (uint8_t *) m_beacon_info;
    manuf_specific_data.data.size   = APP_BEACON_INFO_LENGTH;
    // Build and set advertising data.
    memset(&advdata, 0, sizeof(advdata));
    advdata.name_type             = BLE_ADVDATA_NO_NAME;
    advdata.flags                 = flags;
    advdata.p_manuf_specific_data = &manuf_specific_data;
    // Initialize advertising parameters (used when starting advertising).
    memset(&m_adv_params, 0, sizeof(m_adv_params));
    m_adv_params.properties.type = BLE_GAP_ADV_TYPE_NONCONNECTABLE_NONSCANNABLE_UNDIRECTED;
    m_adv_params.p_peer_addr     = NULL;    // Undirected advertisement.
    m_adv_params.filter_policy   = BLE_GAP_ADV_FP_ANY;
    m_adv_params.interval        = NON_CONNECTABLE_ADV_INTERVAL;
    m_adv_params.duration        = 0;       // Never time out.
    err_code = ble_advdata_encode(&advdata, m_adv_data.adv_data.p_data, &m_adv_data.adv_data.len);
    err_code = sd_ble_gap_adv_set_configure(&m_adv_handle, &m_adv_data, &m_adv_params);
    ret_code_t err_code;
    err_code = sd_ble_gap_adv_start(m_adv_handle, APP_BLE_CONN_CFG_TAG);
    uint32_t ram_start = 0;
    // Enable BLE stack.
/**@brief Function for initializing logging. */
static void log_init(void)
/**@brief Function for initializing timers. */
static void timers_init(void)
        nrf_pwr_mgmt_run();
 * @brief Function for application main entry.
    // Initialize.
    log_init();
    timers_init();
    power_management_init();
    ble_stack_init();
    advertising_init();
    sd_power_dcdc_mode_set(NRF_POWER_DCDC_ENABLE);
    nrf_drv_gpiote_out_config_t out_config = NRFX_GPIOTE_CONFIG_OUT_SIMPLE(0);
    err_code = nrf_drv_gpiote_out_init(0, &out_config);
    // Start execution.
    NRF_LOG_INFO("Beacon example started.");
    advertising_start();
    // Enter main loop.
    for (;; )
        nrf_delay_ms(500);
        nrf_gpio_pin_toggle(0);
        NRF_LOG_INFO("HERE");
This is my .emProject:
<!DOCTYPE CrossStudio_Project_File>
<solution Name="uart_pca10100" target="8" version="2">
  <project Name="uart_pca10100">
    <configuration
      Name="Common"
      arm_architecture="v7EM"
      arm_core_type="Cortex-M4"
      arm_endian="Little"
      arm_fp_abi="Hard"
      arm_fpu_type="FPv4-SP-D16"
      arm_linker_heap_size="8192"
      arm_linker_process_stack_size="0"
      arm_linker_stack_size="8192"
      arm_linker_treat_warnings_as_errors="No"
      arm_simulator_memory_simulation_parameter="RWX 00000000,00100000,FFFFFFFF;RWX 20000000,00010000,CDCDCDCD"
      arm_target_device_name="nRF52833_xxAA"
      arm_target_interface_type="SWD"
      c_user_include_directories="../../../config;../../../../../../components;../../../../../../components/ble/ble_advertising;../../../../../../components/ble/ble_dtm;../../../../../../components/ble/ble_racp;../../../../../../components/ble/ble_services/ble_ancs_c;../../../../../../components/ble/ble_services/ble_ans_c;../../../../../../components/ble/ble_services/ble_bas;../../../../../../components/ble/ble_services/ble_bas_c;../../../../../../components/ble/ble_services/ble_cscs;../../../../../../components/ble/ble_services/ble_cts_c;../../../../../../components/ble/ble_services/ble_dfu;../../../../../../components/ble/ble_services/ble_dis;../../../../../../components/ble/ble_services/ble_gls;../../../../../../components/ble/ble_services/ble_hids;../../../../../../components/ble/ble_services/ble_hrs;../../../../../../components/ble/ble_services/ble_hrs_c;../../../../../../components/ble/ble_services/ble_hts;../../../../../../components/ble/ble_services/ble_ias;../../../../../../components/ble/ble_services/ble_ias_c;../../../../../../components/ble/ble_services/ble_lbs;../../../../../../components/ble/ble_services/ble_lbs_c;../../../../../../components/ble/ble_services/ble_lls;../../../../../../components/ble/ble_services/ble_nus;../../../../../../components/ble/ble_services/ble_nus_c;../../../../../../components/ble/ble_services/ble_rscs;../../../../../../components/ble/ble_services/ble_rscs_c;../../../../../../components/ble/ble_services/ble_tps;../../../../../../components/ble/common;../../../../../../components/ble/nrf_ble_gatt;../../../../../../components/ble/nrf_ble_qwr;../../../../../../components/ble/peer_manager;../../../../../../components/boards;../../../../../../components/libraries/atomic;../../../../../../components/libraries/atomic_fifo;../../../../../../components/libraries/atomic_flags;../../../../../../components/libraries/balloc;../../../../../../components/libraries/bootloader/ble_dfu;../../../../../../components/libraries/button;../../../../../../components/libraries/cli;../../../../../../components/libraries/crc16;../../../../../../components/libraries/crc32;../../../../../../components/libraries/crypto;../../../../../../components/libraries/csense;../../../../../../components/libraries/csense_drv;../../../../../../components/libraries/delay;../../../../../../components/libraries/ecc;../../../../../../components/libraries/experimental_section_vars;../../../../../../components/libraries/experimental_task_manager;../../../../../../components/libraries/fds;../../../../../../components/libraries/fstorage;../../../../../../components/libraries/gfx;../../../../../../components/libraries/gpiote;../../../../../../components/libraries/hardfault;../../../../../../components/libraries/hci;../../../../../../components/libraries/led_softblink;../../../../../../components/libraries/log;../../../../../../components/libraries/log/src;../../../../../../components/libraries/low_power_pwm;../../../../../../components/libraries/mem_manager;../../../../../../components/libraries/memobj;../../../../../../components/libraries/mpu;../../../../../../components/libraries/mutex;../../../../../../components/libraries/pwm;../../../../../../components/libraries/pwr_mgmt;../../../../../../components/libraries/queue;../../../../../../components/libraries/ringbuf;../../../../../../components/libraries/scheduler;../../../../../../components/libraries/sdcard;../../../../../../components/libraries/slip;../../../../../../components/libraries/sortlist;../../../../../../components/libraries/spi_mngr;../../../../../../components/libraries/stack_guard;../../../../../../components/libraries/strerror;../../../../../../components/libraries/svc;../../../../../../components/libraries/timer;../../../../../../components/libraries/twi_mngr;../../../../../../components/libraries/usbd;../../../../../../components/libraries/usbd/class/audio;../../../../../../components/libraries/usbd/class/cdc;../../../../../../components/libraries/usbd/class/cdc/acm;../../../../../../components/libraries/usbd/class/hid;../../../../../../components/libraries/usbd/class/hid/generic;../../../../../../components/libraries/usbd/class/hid/kbd;../../../../../../components/libraries/usbd/class/hid/mouse;../../../../../../components/libraries/usbd/class/msc;../../../../../../components/libraries/util;../../../../../../components/nfc/ndef/conn_hand_parser;../../../../../../components/nfc/ndef/conn_hand_parser/ac_rec_parser;../../../../../../components/nfc/ndef/conn_hand_parser/ble_oob_advdata_parser;../../../../../../components/nfc/ndef/conn_hand_parser/le_oob_rec_parser;../../../../../../components/nfc/ndef/connection_handover/ac_rec;../../../../../../components/nfc/ndef/connection_handover/ble_oob_advdata;../../../../../../components/nfc/ndef/connection_handover/ble_pair_lib;../../../../../../components/nfc/ndef/connection_handover/ble_pair_msg;../../../../../../components/nfc/ndef/connection_handover/common;../../../../../../components/nfc/ndef/connection_handover/ep_oob_rec;../../../../../../components/nfc/ndef/connection_handover/hs_rec;../../../../../../components/nfc/ndef/connection_handover/le_oob_rec;../../../../../../components/nfc/ndef/generic/message;../../../../../../components/nfc/ndef/generic/record;../../../../../../components/nfc/ndef/launchapp;../../../../../../components/nfc/ndef/parser/message;../../../../../../components/nfc/ndef/parser/record;../../../../../../components/nfc/ndef/text;../../../../../../components/nfc/ndef/uri;../../../../../../components/nfc/platform;../../../../../../components/nfc/t2t_lib;../../../../../../components/nfc/t2t_parser;../../../../../../components/nfc/t4t_lib;../../../../../../components/nfc/t4t_parser/apdu;../../../../../../components/nfc/t4t_parser/cc_file;../../../../../../components/nfc/t4t_parser/hl_detection_procedure;../../../../../../components/nfc/t4t_parser/tlv;../../../../../../components/softdevice/common;../../../../../../components/softdevice/s113/headers;../../../../../../components/softdevice/s113/headers/nrf52;../../../../../../components/toolchain/cmsis/include;../../../../../../external/fprintf;../../../../../../external/segger_rtt;../../../../../../external/utf_converter;../../../../../../integration/nrfx;../../../../../../integration/nrfx/legacy;../../../../../../modules/nrfx;../../../../../../modules/nrfx/drivers/include;../../../../../../modules/nrfx/hal;../../../../../../modules/nrfx/mdk;../config;../../../../../../components/libraries/bootloader;../../../../../../components/libraries/bootloader/dfu;../../../../../../components/libraries/bootloader/ble_dfu;../../../../../../components/libraries/svc"
      c_preprocessor_definitions="APP_TIMER_V2;APP_TIMER_V2_RTC1_ENABLED;BOARD_PCA10100;CONFIG_GPIO_AS_PINRESET;FLOAT_ABI_HARD;INITIALIZE_USER_SECTIONS;NO_VTOR_CONFIG;NRF52833_XXAA;NRF_SD_BLE_API_VERSION=7;S113;SOFTDEVICE_PRESENT;"
      debug_target_connection="J-Link"
      gcc_entry_point="Reset_Handler"
      macros="CMSIS_CONFIG_TOOL=../../../../../../external_tools/cmsisconfig/CMSIS_Configuration_Wizard.jar"
      debug_register_definition_file="../../../../../../modules/nrfx/mdk/nrf52833.svd"
      debug_additional_load_file="../../../../../../components/softdevice/s113/hex/s113_nrf52_7.0.1_softdevice.hex"
      debug_start_from_entry_point_symbol="No"
      gcc_debugging_level="Level 3"      linker_output_format="hex"
      linker_printf_width_precision_supported="Yes"
      linker_printf_fmt_level="long"
      linker_scanf_fmt_level="long"
      linker_section_placement_file="flash_placement.xml"
      linker_section_placement_macros="FLASH_PH_START=0x0;FLASH_PH_SIZE=0x80000;RAM_PH_START=0x20000000;RAM_PH_SIZE=0x20000;FLASH_START=0x1c000;FLASH_SIZE=0x64000;RAM_START=0x2000260c;RAM_SIZE=0x1d9f4"
      linker_section_placements_segments="FLASH RX 0x0 0x80000;RAM RWX 0x20000000 0x20000"
      project_directory=""
      project_type="Executable" />
      <folder Name="Segger Startup Files">
        <file file_name="$(StudioDir)/source/thumb_crt0.s" />
      </folder>
    <folder Name="nRF_Log">
      <file file_name="../../../../../../components/libraries/log/src/nrf_log_backend_rtt.c" />
      <file file_name="../../../../../../components/libraries/log/src/nrf_log_backend_serial.c" />
      <file file_name="../../../../../../components/libraries/log/src/nrf_log_backend_uart.c" />
      <file file_name="../../../../../../components/libraries/log/src/nrf_log_default_backends.c" />
      <file file_name="../../../../../../components/libraries/log/src/nrf_log_frontend.c" />
      <file file_name="../../../../../../components/libraries/log/src/nrf_log_str_formatter.c" />
    </folder>
    <folder Name="nRF_Libraries">
      <file file_name="../../../../../../components/libraries/button/app_button.c" />
      <file file_name="../../../../../../components/libraries/util/app_error.c" />
      <file file_name="../../../../../../components/libraries/util/app_error_handler_gcc.c" />
      <file file_name="../../../../../../components/libraries/util/app_error_weak.c" />
      <file file_name="../../../../../../components/libraries/scheduler/app_scheduler.c" />
      <file file_name="../../../../../../components/libraries/timer/app_timer2.c" />
      <file file_name="../../../../../../components/libraries/util/app_util_platform.c" />
      <file file_name="../../../../../../components/libraries/crc16/crc16.c" />
      <file file_name="../../../../../../components/libraries/timer/drv_rtc.c" />
      <file file_name="../../../../../../components/libraries/fds/fds.c" />
      <file file_name="../../../../../../components/libraries/hardfault/hardfault_implementation.c" />
      <file file_name="../../../../../../components/libraries/util/nrf_assert.c" />
      <file file_name="../../../../../../components/libraries/atomic_fifo/nrf_atfifo.c" />
      <file file_name="../../../../../../components/libraries/atomic_flags/nrf_atflags.c" />
      <file file_name="../../../../../../components/libraries/atomic/nrf_atomic.c" />
      <file file_name="../../../../../../components/libraries/balloc/nrf_balloc.c" />
      <file file_name="../../../../../../external/fprintf/nrf_fprintf.c" />
      <file file_name="../../../../../../external/fprintf/nrf_fprintf_format.c" />
      <file file_name="../../../../../../components/libraries/fstorage/nrf_fstorage.c" />
      <file file_name="../../../../../../components/libraries/fstorage/nrf_fstorage_sd.c" />
      <file file_name="../../../../../../components/libraries/memobj/nrf_memobj.c" />
      <file file_name="../../../../../../components/libraries/pwr_mgmt/nrf_pwr_mgmt.c" />
      <file file_name="../../../../../../components/libraries/ringbuf/nrf_ringbuf.c" />
      <file file_name="../../../../../../components/libraries/experimental_section_vars/nrf_section_iter.c" />
      <file file_name="../../../../../../components/libraries/sortlist/nrf_sortlist.c" />
      <file file_name="../../../../../../components/libraries/strerror/nrf_strerror.c" />
    </folder>
    <folder Name="None">
      <file file_name="../../../../../../modules/nrfx/mdk/ses_startup_nrf52833.s" />
      <file file_name="../../../../../../modules/nrfx/mdk/ses_startup_nrf_common.s" />
      <file file_name="../../../../../../modules/nrfx/mdk/system_nrf52833.c" />
    </folder>
    <folder Name="Board Definition">
      <file file_name="../../../../../../components/boards/boards.c" />
    </folder>
    <folder Name="nRF_Drivers">
      <file file_name="../../../../../../integration/nrfx/legacy/nrf_drv_clock.c" />
      <file file_name="../../../../../../integration/nrfx/legacy/nrf_drv_uart.c" />
      <file file_name="../../../../../../modules/nrfx/soc/nrfx_atomic.c" />
      <file file_name="../../../../../../modules/nrfx/drivers/src/nrfx_clock.c" />
      <file file_name="../../../../../../modules/nrfx/drivers/src/nrfx_gpiote.c" />
      <file file_name="../../../../../../modules/nrfx/drivers/src/prs/nrfx_prs.c" />
      <file file_name="../../../../../../modules/nrfx/drivers/src/nrfx_uart.c" />
      <file file_name="../../../../../../modules/nrfx/drivers/src/nrfx_uarte.c" />
	  <file file_name="../../../../../../modules/nrfx/drivers/src/nrfx_wdt.c" />
	  <file file_name="../../../../../../modules/nrfx/drivers/src/nrfx_saadc.c" />
	  <file file_name="../../../../../../modules/nrfx/drivers/src/nrfx_pwm.c" />
    </folder>
    <folder Name="Application">
      <file file_name="../../../main.c" />
      <file file_name="../config/sdk_config.h" />
    </folder>
    <folder Name="nRF_Segger_RTT">
      <file file_name="../../../../../../external/segger_rtt/SEGGER_RTT.c" />
      <file file_name="../../../../../../external/segger_rtt/SEGGER_RTT_Syscalls_SES.c" />
      <file file_name="../../../../../../external/segger_rtt/SEGGER_RTT_printf.c" />
    </folder>
    <folder Name="nRF_BLE">
      <file file_name="../../../../../../components/ble/peer_manager/auth_status_tracker.c" />
      <file file_name="../../../../../../components/ble/common/ble_advdata.c" />
      <file file_name="../../../../../../components/ble/ble_advertising/ble_advertising.c" />
      <file file_name="../../../../../../components/ble/common/ble_conn_params.c" />
      <file file_name="../../../../../../components/ble/common/ble_conn_state.c" />
      <file file_name="../../../../../../components/ble/common/ble_srv_common.c" />
      <file file_name="../../../../../../components/ble/peer_manager/gatt_cache_manager.c" />
      <file file_name="../../../../../../components/ble/peer_manager/gatts_cache_manager.c" />
      <file file_name="../../../../../../components/ble/peer_manager/id_manager.c" />
      <file file_name="../../../../../../components/ble/nrf_ble_gatt/nrf_ble_gatt.c" />
      <file file_name="../../../../../../components/ble/nrf_ble_qwr/nrf_ble_qwr.c" />
      <file file_name="../../../../../../components/ble/peer_manager/peer_data_storage.c" />
      <file file_name="../../../../../../components/ble/peer_manager/peer_database.c" />
      <file file_name="../../../../../../components/ble/peer_manager/peer_id.c" />
      <file file_name="../../../../../../components/ble/peer_manager/peer_manager.c" />
      <file file_name="../../../../../../components/ble/peer_manager/peer_manager_handler.c" />
      <file file_name="../../../../../../components/ble/peer_manager/pm_buffer.c" />
      <file file_name="../../../../../../components/ble/peer_manager/security_dispatcher.c" />
      <file file_name="../../../../../../components/ble/peer_manager/security_manager.c" />
    </folder>
    <folder Name="UTF8/UTF16 converter">
      <file file_name="../../../../../../external/utf_converter/utf.c" />
    </folder>
    <folder Name="nRF_SoftDevice">
      <file file_name="../../../../../../components/softdevice/common/nrf_sdh.c" />
      <file file_name="../../../../../../components/softdevice/common/nrf_sdh_ble.c" />
      <file file_name="../../../../../../components/softdevice/common/nrf_sdh_soc.c" />
    </folder>
  </project>
  <configuration Name="Release"
    c_preprocessor_definitions="NDEBUG"
    gcc_optimization_level="Optimize For Size" />
  <configuration Name="Debug"
    c_preprocessor_definitions="DEBUG; DEBUG_NRF"
    gcc_optimization_level="None"/>
</solution>
If I upload a simple sketch that blinks an LED on my board, without the softdevice it the LED blinks.  So what am I missing here? I repeat that on the DK it seems to work just fine
