Hi everyonoe,
I would like to set a timeout for advertising, and catch this event. So I have
// Initialize advertising parameters (used when starting advertising). memset(&m_adv_params, 0, sizeof(m_adv_params)); m_adv_params.properties.type = BLE_GAP_ADV_TYPE_CONNECTABLE_SCANNABLE_UNDIRECTED; m_adv_params.p_peer_addr = NULL; // Undirected advertisement. m_adv_params.filter_policy = BLE_GAP_ADV_FP_ANY; m_adv_params.duration = 500; // 500*10ms = 5s m_adv_params.interval = MSEC_TO_UNITS(4000, UNIT_0_625_MS); // 9s advertising so timeout occurs before, and SoftDevice accepts the value
According to ble_gap.h :
uint16_t duration; /**< Advertising duration in 10 ms units. When timeout is reached,
an event of type @ref BLE_GAP_EVT_ADV_SET_TERMINATED is raised.
So in the handler I registered with NRF_SDH_BLE_OBSERVER, I have :
static void ble_evt_handler(ble_evt_t const * p_ble_evt, void * p_context) { uint32_t err_code; switch (p_ble_evt->header.evt_id) { case BLE_GAP_EVT_CONNECTED: ble_evt_ConnectedEvent_handler(); m_conn_handle = p_ble_evt->evt.gap_evt.conn_handle; err_code = nrf_ble_qwr_conn_handle_assign(&m_qwr, m_conn_handle); APP_ERROR_CHECK(err_code); break; case BLE_GAP_EVT_DISCONNECTED: ble_evt_DisconnectedEvent_handler(); // LED indication will be changed when advertising starts. m_conn_handle = BLE_CONN_HANDLE_INVALID; break; case BLE_GAP_EVT_PHY_UPDATE_REQUEST: { // NRF_LOG_DEBUG("PHY update request."); ble_gap_phys_t const phys = { .rx_phys = BLE_GAP_PHY_AUTO, .tx_phys = BLE_GAP_PHY_AUTO, }; err_code = sd_ble_gap_phy_update(p_ble_evt->evt.gap_evt.conn_handle, &phys); APP_ERROR_CHECK(err_code); } break; case BLE_GAP_EVT_SEC_PARAMS_REQUEST: // Pairing not supported err_code = sd_ble_gap_sec_params_reply(m_conn_handle, BLE_GAP_SEC_STATUS_PAIRING_NOT_SUPP, NULL, NULL); APP_ERROR_CHECK(err_code); break; case BLE_GATTS_EVT_SYS_ATTR_MISSING: // No system attributes have been stored. err_code = sd_ble_gatts_sys_attr_set(m_conn_handle, NULL, 0, 0); APP_ERROR_CHECK(err_code); break; case BLE_GATTC_EVT_TIMEOUT: // Disconnect on GATT Client timeout event. err_code = sd_ble_gap_disconnect(p_ble_evt->evt.gattc_evt.conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION); APP_ERROR_CHECK(err_code); break; case BLE_GATTS_EVT_TIMEOUT: // Disconnect on GATT Server timeout event. err_code = sd_ble_gap_disconnect(p_ble_evt->evt.gatts_evt.conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION); APP_ERROR_CHECK(err_code); break; case BLE_GAP_EVT_ADV_SET_TERMINATED: printf("AdvTimeout!"); break; default: break; } }
My issue is : after 5s, I don't have "Timeout!" printed in my console. But if I set an advertising interval greater than 5s, "Timeout!" is printed immediately at boot, several time, until it reboots. The other events works well (connection, deconnection...)
Is there something I missed?
Thank you for your help!
