UART and TIMER conflicts happening while receiving data
Hi Everyone
We are using nrfx_uarte library to implement the uart functionality , Everything seems to work fine with the uart , but the problem comes when we want to have a timeout in the read function.
To implement the timer we are using TIMER 2 instance , but whenever the timer gets triggered at some point of non availabilty of data , the UART reception gets blocked or gives garbage characters sometimes.
Here is the code that i am using , any help/suggestion would be appreciated
#include "nrf_serial.h"
#include "uart_lte.h"
#include "nrf_drv_timer.h"
#include "nrf_delay.h"
//Boolean flag to be set in interrupt handler;
static volatile bool uart_xfer_done=false;
static volatile bool timeout;
//Uart instance to be used.
static const nrfx_uarte_t uart1 =
            NRFX_UARTE_INSTANCE (1);
const nrfx_timer_t TIMER_LED = NRFX_TIMER_INSTANCE(2);
//uart event handler decalartion
static void  uarte_event_handler(nrfx_uarte_event_t const * p_event,void * p_context);
void timer_led_event_handler(nrf_timer_event_t event_type, void* p_context)
    SEGGER_RTT_printf(0,"*");
    timeout = true;
    //one-shot
//    stop_timer();
void init_timer()
    uint32_t time_ms = 8000; //Time(in miliseconds) between consecutive compare events.
    uint32_t err_code = NRF_SUCCESS;
    nrfx_timer_config_t timer_cfg = NRFX_TIMER_DEFAULT_CONFIG;
    uninit_timer();
    err_code = nrfx_timer_init(&TIMER_LED, &timer_cfg, timer_led_event_handler);
    nrfx_timer_extended_compare(&TIMER_LED,
	NRF_TIMER_CC_CHANNEL2,
	nrfx_timer_ms_to_ticks(&TIMER_LED, time_ms),
	NRF_TIMER_SHORT_COMPARE2_CLEAR_MASK | NRF_TIMER_SHORT_COMPARE2_STOP_MASK , true
    nrfx_timer_enable(&TIMER_LED);
    stop_timer();
void uninit_timer()
    nrfx_timer_uninit(&TIMER_LED);
void start_timer()
    nrfx_timer_clear(&TIMER_LED);
    nrfx_timer_resume(&TIMER_LED);
 void stop_timer()
     nrfx_timer_pause(&TIMER_LED);
 * This function uses UARTE1 peripheral instance for communication
 * @param rx_pin to be used
 * @param tx_pin to be used
 * @return None
void uarte_init(uint32_t rx_pin,uint32_t tx_pin,uint32_t baud_rate)
    nrfx_uarte_config_t nrf_uart1;
    nrf_uart1.pselrxd = rx_pin ;
    nrf_uart1.pseltxd = tx_pin;
    nrf_uart1.pselcts = NRF_UARTE_PSEL_DISCONNECTED;
    nrf_uart1.pselrts = NRF_UARTE_PSEL_DISCONNECTED;
    nrf_uart1.hwfc = NRF_UARTE_HWFC_DISABLED;
    nrf_uart1.parity = NRF_UARTE_PARITY_EXCLUDED;
    nrf_uart1.interrupt_priority =6;
    nrf_uart1.p_context = NULL;
    switch(baud_rate)
         case baud_rate_lte_1200:
              nrf_uart1.baudrate = NRF_UARTE_BAUDRATE_1200;
         case baud_rate_lte_2400:
              nrf_uart1.baudrate = NRF_UARTE_BAUDRATE_2400;
         case baud_rate_lte_4800:
              nrf_uart1.baudrate = NRF_UARTE_BAUDRATE_4800;
         case baud_rate_lte_9600:
              nrf_uart1.baudrate = NRF_UARTE_BAUDRATE_9600;
         case baud_rate_lte_14400:
              nrf_uart1.baudrate = NRF_UARTE_BAUDRATE_14400;
         case baud_rate_lte_19200:
              nrf_uart1.baudrate = NRF_UARTE_BAUDRATE_19200;
         case baud_rate_lte_28800:
              nrf_uart1.baudrate = NRF_UARTE_BAUDRATE_28800;
         case baud_rate_lte_31250:
              nrf_uart1.baudrate = NRF_UARTE_BAUDRATE_31250;
         case baud_rate_lte_38400:
              nrf_uart1.baudrate = NRF_UARTE_BAUDRATE_38400;
         case baud_rate_lte_56000:
              nrf_uart1.baudrate = NRF_UARTE_BAUDRATE_56000;
         case baud_rate_lte_57600:
              nrf_uart1.baudrate = NRF_UARTE_BAUDRATE_57600;
         case baud_rate_lte_76800:
              nrf_uart1.baudrate = NRF_UARTE_BAUDRATE_76800;
         case baud_rate_lte_115200:
              nrf_uart1.baudrate = NRF_UARTE_BAUDRATE_115200;
         case baud_rate_lte_921600:
              nrf_uart1.baudrate = NRF_UARTE_BAUDRATE_921600;
    nrfx_uarte_init(&uart1,&nrf_uart1,uarte_event_handler);
    init_timer();
 * This function uninitalize the UARTE1
 * @param None
 * @param None
 * @return None
void uarte_uninit()
    uninit_timer();
    nrfx_uarte_uninit(&uart1);
uarte_retcode_t write_byte_uarte (uint8_t data)
    nrfx_uarte_tx(&uart1,&data,1);
    return wait_for_execution();
uarte_retcode_t write_bytes_uarte (char* data, size_t length)
    nrfx_uarte_tx(&uart1,data,length);
uarte_retcode_t read_byte_uarte (char* buffer)
   nrfx_uarte_rx(&uart1,buffer,1);
uarte_retcode_t read_bytes_uarte (char* buffer, size_t length)
   nrfx_uarte_rx(&uart1,buffer,length);
uarte_retcode_t wait_for_execution()
    start_timer();
    while(true)
	if(uart_xfer_done)
	    return UARTE_OK;
	else if(timeout)
	    timeout = false;
	    return UARTE_TIMEOUT;
 * @brief UART1 Event handler
 * @param event
  switch(p_event->type)
      case NRFX_UARTE_EVT_TX_DONE:
             uart_xfer_done = true;
      case NRFX_UARTE_EVT_RX_DONE:
             //SEGGER_RTT_printf(0,"RX LTE\r\n");
      case NRFX_UARTE_EVT_ERROR:
bool data_available_uarte(void)
   return nrfx_uarte_rx_ready(&uart1);
