reception within a basement?
For a customer we're trying to see if we can build an IoT solution with nrf9160 to periodically send a status update to the cloud. Unfortunately, the devices are typically in the basement. Connecting from a basement over LTE-M/NB-IoT with nrf9160 has been unsuccessful sofar. We tested in three basements with no luck (normal house basement and two office building garages). As this is one of the main use cases for IoT: stuff in a basement sends a status update once in a long time we were quite surprised that it didn't work. Any hints you can give us? The antenna we tried is an 20 cm tall LTE antenna. Is this a problem with the providers not enabling NB-IoT/LTE-M features for wall-penetration? I failed to find any options to boost the receive or send amplifiers? Are there better antennas that we should try?
  • Hi Ronald,
    When it comes to IoT devices that are located underground such as basements etc. It is recommended to use the NB-IoT technology since it provide a much better penetration.
    From what I read you are using a custom board? Or are you testing with the nRF91DK?
    How are you doing these tests?
    I would recommend just running the AT Client sample (which is also included as a precompiled .hex file in the .zip folder in the nRF91DK page).
    Please make sure you have the latest modem firmware.
    Please send a serial output log using the AT Client sample getting a sucessful connection over ground via NB-IoT, and then go underground and follow the same steps.
    Martin L.
  • I tried it with both our custom board and the eval board.
    here is a part of our log:
    00> D: Sending AT command to set system mode: AT%XSYSTEMMODE=0,1,1,0
    00> Sending command AT%XSYSTEMMODE=0,1,1,0
    00> Sending command AT%XSYSTEMMODE?
    00> Sending command AT+CEDRXS=2,5,"1001"
    00> Sending command AT+CEREG=5
    00> Sending command AT+COPS=0
    00> Sending command AT+CGDCONT=0,"IPv4v6","iot.1nce.net"
    00> I: PDP Context: AT+CGDCONT=0,"IPv4v6","iot.1nce.net"
    00> Sending command AT+CSCON=1
    00> Sending command AT+CFUN=1
    00> D: +CEREG notification: +CEREG: 2,"FFFE","FFFFFFFF",9,0,0,"11100000","11100000"
    00>
    00> D: TAU: -1 sec, active time: -1 sec
    00>
    00> D: +CEREG notification: +CEREG: 2,"BEC6","0145E367",9,0,0,"11100000","11100000"
    00>
    00>
    00> D: +CSCON notification
    00> D: +CEREG notification: +CEREG: 4,"BEC6","0145E367",9,0,15,"11100000","11100000"
    00>
    00>
    00> D: +CEREG notification: +CEREG: 4,"FFFE","FFFFFFFF",9,0,15,"11100000","11100000"
    00>
    00>
    00>
    00>
    The logs with the AT client is coming up.
  • eval board + at client in the office (the good case, not the basement. pasting that next)
    AT+CFUN?
    Sending command
    AT+CFUN?
    +CFUN: 1
    OK
    AT+CGSN=1
    Sending command
    AT+CGSN=1
    +CGSN: "352656100028862"
    OK
    AT+CGMI
    Sending command
    AT+CGMI
    Nordic Semiconductor ASA
    OK
    AT+CGMM
    Sending command
    AT+CGMM
    nRF9160-SICA
    OK
    AT+CGMR
    Sending command
    AT+CGMR
    mfw_nrf9160_1.2.0
    OK
    AT+CEMODE?
    Sending command
    AT+CEMODE?
    +CEMODE: 0
    OK
    AT%XCBAND=?
    Sending command
    AT%XCBAND=?
    %XCBAND: (1,2,3,4,5,8,12,13,17,19,20,25,26,28,66)
    OK
    AT+CMEE?
    Sending command
    AT+CMEE?
    +CMEE: 1
    OK
    AT+CNEC?
    Sending command
    AT+CNEC?
    +CNEC: 24
    OK
    AT+CGEREP?
    Sending command
    AT+CGEREP?
    +CGEREP: 1,0
    OK
    AT+CIND=1,1,1
    Sending command
    OK
    AT+CEREG=2
    Sending command
    OK
    AT+CEREG?
    Sending command
    AT+CEREG?
    +CEREG: 2,5,"CB52","02278E03",9
    OK
    AT+COPS=3,2
    Sending command
    OK
    AT+COPS?
    Sending command
    AT+COPS?
    +COPS: 1,2,"26201",9
    OK
    AT%XCBAND
    Sending command
    AT%XCBAND
    %XCBAND: 8
    OK
    AT+CGDCONT?
    Sending command
    AT+CGDCONT?
    +CGDCONT: 0,"IP","cdp.iot.t-mobile.nl","10.128.5.215",0,0
    OK
    AT+CGACT?
    Sending command
    AT+CGACT?
    +CGACT: 0,1
    OK
    AT%CESQ=1
    Sending command
    OK
    AT+CESQ
    Sending command
    AT+CESQ
    +CESQ: 99,99,255,255,255,255
    OK
    AT%XSIM=1
    Sending command
    OK
    AT%XSIM?
    Sending command
    AT%XSIM?
    %XSIM: 1
    OK
    AT+CPIN?
    Sending command
    AT+CPIN?
    +CPIN: READY
    OK
    AT+CPINR="SIM PIN"
    Sending command
    AT+CPINR="SIM PIN"
    +CME ERROR: 0
    AT+CGDCONT=0,"IPv4v6","cdp.iot.t-mobile.nl"
    Sending command
    +CME ERROR: 3
    Sending command
    +CME ERROR: 3
    AT+CFUN=4
    Sending command
    %CESQ: 44,2,19,2
    +CGEV: ME PDN DEACT 0
    +CEREG: 0,"CB52","02278E03",9
    +CIND: "service",0
    +CIND: "roam",0
    +CGEV: ME DETACH
    %CESQ: 255,0,255,0
    %XSIM: 0
    OK
    Sending command
    OK
    AT+CGDCONT?
    Sending command
    AT+CGDCONT?
    +CGDCONT: 0,"IPV4V6","cdp.iot.t-mobile.nl","",0,0
    OK
    AT+CGDCONT?
    Sending command
    AT+CGDCONT?
    OK
    AT+CGACT?
    Sending command
    AT+CGACT?
    +CGACT: 0,0
    OK
    AT+CGACT?
    Sending command
    AT+CGACT?
    +CGACT: 0,0
    OK
    AT+CFUN=1
    Sending command
    OK
    %CESQ: 46,2,19,2
    +CEREG: 2,"CB52","02278E03",9
    %XSIM: 1
    AT+CPIN?
    Sending command
    AT+CPIN?
    +CPIN: READY
    OK
    AT+CPINR="SIM PIN"
    Sending command
    AT+CPINR="SIM PIN"
    +CPINR: "SIM PIN",3
    OK
    AT+CIMI
    Sending command
    AT+CIMI
    901405700009565
    OK
    +CGEV: ME PDN ACT 0,0
    +CNEC_ESM: 50,0
    +CEREG: 5,"CB52","02278E03",9
    AT+CGDCONT?
    +CIND: "service",1
    +CIND: "roam",1
    Sending command
    AT+CGDCONT?
    +CGDCONT: 0,"IP","cdp.iot.t-mobile.nl","10.128.4.63",0,0
    OK
    AT+COPS=3,2
    Sending command
    OK
    AT+CGACT?
    Sending command
    AT+CGACT?
    +CGACT: 0,1
    OK
    AT+COPS?
    Sending command
    AT+COPS?
    OK
    AT%XCBAND
    Sending command
    AT%XCBAND
    %XCBAND: 8
    OK
    AT+CGDCONT?
    Sending command
    AT+CGDCONT?
    OK
    AT+CGACT?
    Sending command
    AT+CGACT?
    +CGACT: 0,1
    OK
    %CESQ: 46,2,25,3
  • in the basement with AT client + eval board:
    Sending command AT+CFUN?
    +CFUN: 0
    OK
    AT%XSYSTEMMODE=0,1,0,0
    Sending command
    OK
    Sending command
    OK
    AT+CFUN=4
    Sending command
    OK
    Sending command
    OK
    AT+CFUN=1
    Sending command
    OK
    AT+CFUN?
    Sending command
    +CFUN: 1
    OK
    AT+CGSN=1
    Sending command
    AT+CGSN=1
    OK
    AT+CGMI
    Sending command
    AT+CGMI
    OK
    AT+CGMM
    Sending command
    AT+CGMM
    nRF9160-SICA
    OK
    AT+CGMR
    Sending command
    AT+CGMR
    mfw_nrf9160_1.2.0
    OK
    AT+CEMODE?
    Sending command
    AT+CEMODE?
    +CEMODE: 0
    OK
    AT%XCBAND=?
    Sending command
    AT%XCBAND=?
    OK
    AT+CMEE?
    Sending command
    AT+CMEE?
    +CMEE: 0
    OK
    AT+CMEE=1
    Sending command
    OK
    AT+CNEC?
    Sending command
    AT+CNEC?
    +CNEC: 0
    OK
    AT+CNEC=24
    Sending command
    OK
    AT+CGEREP?
    Sending command
    AT+CGEREP?
    +CGEREP: 0,0
    OK
    AT+CGDCONT?
    Sending command
    AT+CGDCONT?
    OK
    AT+CGACT?
    Sending command
    AT+CGACT?
    +CGACT: 0,0
    OK
    AT+CGEREP=1
    Sending command
    OK
    AT+CIND=1,1,1
    Sending command
    OK
    AT+CEREG=2
    Sending command
    OK
    AT+CEREG?
    Sending command
    AT+CEREG?
    +CEREG: 2,4,"FFFE","FFFFFFFF",9
    OK
    AT%CESQ=1
    Sending command
    OK
    AT+CESQ
    Sending command
    AT+CESQ
    OK
    AT%XSIM=1
    Sending command
    OK
    AT%XSIM?
    Sending command
    AT%XSIM?
    %XSIM: 1
    OK
    AT+CPIN?
    Sending command
    AT+CPIN?
    +CPIN: READY
    OK
    AT+CPINR="SIM PIN"
    Sending command
    AT+CPINR="SIM PIN"
    +CPINR: "SIM PIN",3
    OK
    AT+CIMI
    Sending command
    AT+CIMI
    901405700009565
    OK
    %CESQ: 16,0,16,2
    +CEREG: 2,"CB52","02996A05",9
    AT+CGDCONT?
    +CNEC_ESM: 50,0
    +CEREG: 5,"CB52","02996A05",9
    +CIND: "service",1
    +CIND: "roam",1
    Sending command
    AT+CGDCONT?
    +CGDCONT: 0,"IP","cdp.iot.t-mobile.nl","10.0.5.248",0,0
    OK
    AT+CGACT?
    Sending command
    AT+CGACT?
    +CGACT: 0,1
    OK
    %CESQ: 255,0,255,0
  • looking at this it got SOME reception: it was able to resolve the cdp.iot.t-mobile.nl to an IP. But afterwards it fails to connect (cesq = 255,0,255,0)
