Hi:
I use the PCA1004 EVK bord to configuer the I2S MCK as 256K, 32MHz/125 (I2S_CONFIG_MCK_SETUP 34340864) .
then I measure the pin use oscilloscope, but I only get 255K. what happened for it. the crystal oscillator error?
Thanks
By Gu Yahui
Hi:
Thanks
By Gu Yahui
This error is less than one percent. Did you calibrate your oscilloscope?
Hi Turbo:
Thanks for your reply, I use the Tektronix's multimeter to measure and get the same result, and also I use the MCK(configure to 16M) as a codec's reference to produce a 8K audio data, then I count the frequency use software, and get the value less than 8K
Hi :
This problem is fixed, the cause is the source of the HFCLK ,
nordic use the HFINT as defualt, and it works ok when I switch to the HFXO use nrf_drv_clock_hfclk_request()
