Compile pc-ble-driver-py for arm (just compile pc-ble-driver-py and not the driver itself)
I am trying to install the pc-ble-driver-py for my buildroot arm-board.
After some struggle I was able to compile the pc-ble-driver for it, however the python tool for it "pc-ble-driver-py" gives me some headache now.
For some reason pc-ble-driver-py builds its own drivers, which basically will be the false in the buildroot toolchain. (ERROR: architecture for "/usr/lib/python3.8/site-packages/pc_ble_driver_py/lib/_nrf_ble_driver_sd_api_v5.so" is "Advanced Micro Devices X86-64", should be "ARM") Although I dont want to use these anyways since I have my already compiled driver... Is there a way I can tell pc-ble-driver-py to stop compiling this pc-ble-drivers and just prepare the python tools and use the precompiled drivers instead?
I already tried to just delete the wrong drivers after the building process... sadly the program is to clever at that point and just rebuilds the wrong drivers...
EDIT: pc-ble-driver version: 4.1.2
         pc-ble-diver-py version: 0.14.2
Regards
F
  • I've tested the pc-ble-driver and the pc-ble-driver-py using nrfutil and it seems to work. Flashing a firmware with it worked. Still I cant stop pc-ble-driver-py to build the wrong drivers... someone got ideas how? The issue I have is that python scikit build is used which uses multiple other libraries (cmake-ninja, python extensions, python) and I dont know how to trick/tell pc-ble-driver-py to not build these wrong drivers...
    It is a bit unclear to me when this happens. When compiling or installing pc-ble-driver-py, when trying to run a pc-ble-driver-py project, or are you compiling a pc-ble-driver-py project into an executable? Other?
    I have had a chat with one of our developers. Assuming that you are cross compiling, you can try the following approach (although untested by us):
    1) Unset env variable VCPKG_ROOT
    2) Cross compile pc-ble-driver deps as you have already done
    3) Compile and install pc-ble-driver for ARM architecture (I'm assuming cross compilation on Intel platform to ARM), add flag -DCMAKE_INSTALL_PREFIX=<directory for RPI cross compiled binaries> and any other flags you use for cross compiling
    4) Run python setup.py bdist_wheel --build-type Release -- -DCMAKE_MODULE_PATH=<directory for RPI cross compiled binaries>/share/nrf-ble-driver <any other flags you use for cross compiling>
    I am sure we make a lot of assumptions here, so more info on your setup, toolchains, what build/install instructions you follow, etc. would help if the above does not lead you in the right direction.
    Terje
  • Hey Terje,
    Thank your for your reply!
    Tried the steps but they haven't effected the out coming drivers. They still are for x86_64 and not ARM.
    It already was quiet some work to "simply" cross compile the pc-ble-driver for ARM, as vcpkg isnt suited for ARM very well, and even less for cross compilation. My target with pc-ble-driver-py is to just obtain the cross compiled .py files. The .so files arent needed at all. I am not too sure what information could be of help so I may try to explain a "bit" more:
    Downloaded the latest git version and build it into our buildroot toolchain (ARMv7). My PC is running with x86_64 Arch Linux. Buildroot than simply executes the setup.py with its toolchain:
    (cd /buildroot/buildroot-2019.02.8.1/output/build/python-pc-ble-driver-py-0.14.2//; _PYTHON_SYSCONFIGDATA_NAME="" PATH="buildroot/buildroot-2019.02.8.1/output/host/binbuildroot/buildroot-2019.02.8.1/output/host/sbin:/usr/local/sbin:/usr/local/bin:/usr/bin:/usr/lib/jvm/default/bin:/usr/bin/site_perl:/usr/bin/vendor_perl:/usr/bin/core_perl" PYTHONPATH="/buildroot/buildroot-2019.02.8.1/output/host/arm-buildroot-linux-uclibcgnueabihf/sysroot/usr/lib/python3.8/" PYTHONNOUSERSITE=1 _python_sysroot=/buildroot/buildroot-2019.02.8.1/output/host/arm-buildroot-linux-uclibcgnueabihf/sysroot _python_prefix=/usr _python_exec_prefix=/usr  /buildroot//buildroot-2019.02.8.1/output/host/bin/python setup.py build  -Dnrf-ble-driver_DIR:PATH="/buildroot/buildroot-2019.02.8.1/output/host/usr/share/vcpkg/installed/arm-linux/share/nrf-ble-driver")
    Builds all elements, with a lot of magic thanks to all those different builders (scikit, python, cmake (ninja) and make) that pc-ble-driver-py uses, where I couldn't find out how to stop the .so-element building process.
    The reason I want to get rid of these is that  buildroot runs into the following issue:
    ... (copying files)
    running install_egg_info
    running egg_info
    creating pc_ble_driver_py.egg-info
    writing pc_ble_driver_py.egg-info/PKG-INFO
    writing dependency_links to pc_ble_driver_py.egg-info/dependency_links.txt
    writing requirements to pc_ble_driver_py.egg-info/requires.txt
    writing top-level names to pc_ble_driver_py.egg-info/top_level.txt
    writing manifest file 'pc_ble_driver_py.egg-info/SOURCES.txt'
    reading manifest file 'pc_ble_driver_py.egg-info/SOURCES.txt'
    reading manifest template 'MANIFEST.in'
    warning: no previously-included files matching '__pycache__' found under directory '*'
    warning: no previously-included files matching '*.py[co]' found under directory '*'
    Copying pc_ble_driver_py.egg-info to /buildroot/buildroot-2019.02.8.1/output/target/usr/lib/python3.8/site-packages/pc_ble_driver_py-0.14.2-py3.8.egg-info
    running install_scripts
    copied 0 files
    ERROR: architecture for "/usr/lib/python3.8/site-packages/pc_ble_driver_py/lib/_nrf_ble_driver_sd_api_v2.so" is "Advanced Micro Devices X86-64", should be "ARM"
    make: *** [package/pkg-generic.mk:340: /buildroot/buildroot-2019.02.8.1/output/build/python-pc-ble-driver-py-0.14.2/.stamp_target_installed] Fehler 1
    The python-pc-ble-driver-py.mk
    # python-pc-ble-driver-py
    PYTHON_PC_BLE_DRIVER_PY_VERSION = 0.14.2
    PYTHON_PC_BLE_DRIVER_PY_SOURCE = pc_ble_driver_py-$(PYTHON_PC_BLE_DRIVER_PY_VERSION).tar.gz
    PYTHON_PC_BLE_DRIVER_PY_SITE = $(call github,NordicSemiconductor,pc-ble-driver-py,v$(PYTHON_PC_BLE_DRIVER_PY_VERSION))
    PYTHON_PC_BLE_DRIVER_PY_LICENSE = Other/Proprietary License (Modified BSD License)
    PYTHON_PC_BLE_DRIVER_PY_DEPENDENCIES = host-python-scikit-build host-python-packaging host-python-wheel host-python-pyparsing host-python-distro pc-ble-driver
    PYTHON_PC_BLE_DRIVER_PY_SETUP_TYPE = setuptools
    PYTHON_PC_BLE_DRIVER_PY_BUILD_OPTS +=-Dnrf-ble-driver_DIR:PATH="$(HOST_DIR)/usr/share/vcpkg/installed/arm-linux/share/nrf-ble-driver"
    $(eval $(python-package))
  • The chip that is used on the board is the nRF52840 and should be used to update other bluetooth devices through nrfutil. We use a better patched buildroot version (2019.11) now. With changing the buildroot version I somehow ran into a new issue which only occures on the newer version but not on the before tested 2019.02:
    -- Trying "Ninja" generator - success
    Configuring Project
      Working directory:
        /buildroot/buildroot-2019.02.11.1/output/build/python-pc-ble-driver-py-0.14.2/_skbuild/linux-x86_64-3.8/cmake-build
      Command:
        cmake /buildroot/buildroot-2019.02.11.1/output/build/python-pc-ble-driver-py-0.14.2 -G Ninja -DCMAKE_INSTALL_PREFIX:PATH=/buildroot/buildroot-2019.02.11.1/output/build/python-pc-ble-driver-py-0.14.2/_skbuild/linux-x86_64-3.8/cmake-install -DPYTHON_EXECUTABLE:FILEPATH=/buildroot/buildroot-2019.02.11.1/output/host/bin/python -DPYTHON_VERSION_STRING:STRING=3.8.2 -DPYTHON_INCLUDE_DIR:PATH=/buildroot/buildroot-2019.02.11.1/output/host/include/python3.8 -DPYTHON_LIBRARY:FILEPATH=/buildroot/buildroot-2019.02.11.1/output/host/lib/libpython3.8.so -DSKBUILD:BOOL=TRUE -DCMAKE_MODULE_PATH:PATH=/buildroot/buildroot-2019.02.11.1/output/host/lib/python3.8/site-packages/skbuild/resources/cmake -Dnrf-ble-driver_DIR:PATH=/buildroot/buildroot-2019.02.11.1/output/host/usr/share/vcpkg/installed/arm-linux/share/nrf-ble-driver -DCMAKE_BUILD_TYPE:STRING=Release
    CMake Error at CMakeLists.txt:29 (find_package):
      Could not find a configuration file for package "nrf-ble-driver" that is
      compatible with requested version "4.1.1".
      The following configuration files were considered but not accepted:
        /buildroot/buildroot-2019.02.11.1/output/host/usr/share/vcpkg/installed/arm-linux/share/nrf-ble-driver/nrf-ble-driverConfig.cmake, version: 4.1.1 (64bit)
    See also "/buildroot/buildroot-2019.02.11.1/output/build/python-pc-ble-driver-py-0.14.2/_skbuild/linux-x86_64-3.8/cmake-build/CMakeFiles/CMakeOutput.log".
      File "/buildroot/buildroot-2019.02.11.1/output/host/lib/python3.8/site-packages/skbuild/setuptools_wrap.py", line 582, in setup
        env = cmkr.configure(cmake_args,
      File "/buildroot/buildroot-2019.02.11.1/output/host/lib/python3.8/site-packages/skbuild/cmaker.py", line 229, in configure
        raise SKBuildError(
    An error occurred while configuring with CMake.
      Command:
        cmake /buildroot/dimm/buildroot-2019.02.11.1/output/build/python-pc-ble-driver-py-0.14.2 -G Ninja -DCMAKE_INSTALL_PREFIX:PATH=/buildroot/buildroot-2019.02.11.1/output/build/python-pc-ble-driver-py-0.14.2/_skbuild/linux-x86_64-3.8/cmake-install -DPYTHON_EXECUTABLE:FILEPATH=/buildroot/buildroot-2019.02.11.1/output/host/bin/python -DPYTHON_VERSION_STRING:STRING=3.8.2 -DPYTHON_INCLUDE_DIR:PATH=/buildroot/buildroot-2019.02.11.1/output/host/include/python3.8 -DPYTHON_LIBRARY:FILEPATH=/buildroot/buildroot-2019.02.11.1/output/host/lib/libpython3.8.so -DSKBUILD:BOOL=TRUE -DCMAKE_MODULE_PATH:PATH=/buildroot/buildroot-2019.02.11.1/output/host/lib/python3.8/site-packages/skbuild/resources/cmake -Dnrf-ble-driver_DIR:PATH=/buildroot/buildroot-2019.02.11.1/output/host/usr/share/vcpkg/installed/arm-linux/share/nrf-ble-driver -DCMAKE_BUILD_TYPE:STRING=Release
      Source directory:
      Working directory:
    Please see CMake's output for more information.
    make: *** [package/pkg-generic.mk:255: /buildroot/buildroot-2019.02.11.1/output/build/python-pc-ble-driver-py-0.14.2/.stamp_built] Fehler 1
    Anyone got an idea why cmake got an issue with the nrf-ble-driverConfig.cmake here? I already replaced it with the "arm-linux" one from buildroot-2019.02 sadly with the same outcome. (Its the same cmake version: 3.18.1 and ninja version: 1.10.0)
