bootloader from SDK 6.1, S110 V7.0.0 and GCC
Hello all, i am trying to make working the ble bootloader from SDK 6.1 with SoftDevice 7.0.0 and gcc setup (pure Eclipse gcc project frome here devzone.nordicsemi.com/.../ with gcc 4.8 from here launchpad.net/.../4.8-2014-q2-update) but i run into some memory issue;
Anytime i try to upload an application from latest nRF-Tollbox (Android), immediately after pressing the UPLOAD button the bootloader asserts a NRF_ERROR_NO_MEM error into dfu_dual_bank.c file, when calling the app_timer_stop function inside the dfu_timer_restart function;
I am using all the possible flags in order to reduce firmware size and ram footprint (-Os -lc -lnosys --specs=nano.specs -flto -ffunction-sections -fdata-sections -fno-builtin) but nothing seems to work;
Attached are the gcc scripts used[gcc_nrf51_s110_xxaa.ld] [gcc_nrf51_common.ld] [gcc_startup_nrf51.S]
I am using SDK 6.1 and SD S110 7.0.0 because my nRF51822 ic is hw revision 2 and the compatibility matrix document specifies SDK 6.1 and SD7.0.0 as the latest available;
Any idea? Or could be possible to use a newer SDK only for the bootloader project remaining with SD 7.0.0?
(/attachment/6c7cf8af8da878b5de1759613e95f933)(/attachment/bee9ac43da93fd17b190f3de11470e44)(/attachment/12db1f39d6b56c29a477c307e6fdaebf)
  • Thanks Nguyen, i have already moved my bootloader project to the SDK 7.1 and made it working (when no application is previously flashed) with my eclipse configuration;
    So my new question is if it is totally safe to use the SDK 7.2 which is stated (into the release note) as "optimized for ic revision 3" for my ic revision 2;
    Thanks in advance
  • Thanks Nguyen, it is good to know that previous revision still works well;
    My only complaint about migrating to SDK8 is the need to use also SoftDevice 8, cause in my projects i use a nRF51822 module which is already SIG qualified with SD 7, and flashing new SD8 probably means loosing the qualification
