nrf9160 fota download with Microsft Blob storage issue
I'm able to successful download and flash my application firmware using AWS S3, but unable to use Microsoft Blob Storage successfully.
I'm using Thingy91 with SDK 1.3.0 in a custom project.
My relevant prj.conf settings:
# Download client
CONFIG_DOWNLOAD_CLIENT=y
CONFIG_DOWNLOAD_CLIENT_TLS=y
CONFIG_DOWNLOAD_CLIENT_STACK_SIZE=8192
CONFIG_DOWNLOAD_CLIENT_SOCK_TIMEOUT_MS=10000
(also tried default -1 - forever timeout and 4k stack default size)
A  tiny file download succeeds, but recognizes that it's not a valid firmware image:
Starting OTA download for host:itoctonnectstore.blob.core.windows.net path:nrf/test/test.zip, sec_tag:10703
[00:00:19.566,986] <dbg> download_client.download_thread: Receiving up to 4096 bytes at 0x2002060c...
IoTConnect MQTT Connected
[00:00:19.789,031] <dbg> download_client.download_thread: Read 661 bytes from socket
[00:00:19.797,515] <dbg> download_client.header_parse: GET header size: 500
[00:00:19.805,084] <dbg> download_client.header_parse: client->buf HTTP/1.1 206 Partial Content
Content-Length: 161
Content-Type: application/octet-stream
Content-Range: bytes 0-160/161
Last-Modified: Fri, 07 Aug 2020 22:32:11 GMT
Accept-Ranges: bytes
ETag: "0x8D83B21B9F0CAB2"
Server: Windows-Azure-Blob/1.0 Microsoft-HTTPAPI/2.0
x-ms-request-id: f3993d2f-c01e-0069-0b0a-6dd9b2000000
x-ms-version: 2014-02-14
x-ms-lease-status: unlocked
x-ms-lease-state: available
x-ms-blob-type: BlockBlob
Content-Disposition:
Date: Fri, 07 Aug 2020 22:33:57 GMT
PK
[00:00:19.856,597] <dbg> download_client.header_parse: File size = 161
[00:00:19.863,861] <wrn> download_client: Copying 161 payload bytes
[00:00:19.871,002] <inf> download_client: Downloaded 161/161 bytes (100%)
[00:00:19.878,448] <err> dfu_target: No supported image type found
[00:00:19.885,498] <err> dfu_target: Unknown image type
[00:00:19.891,571] <err> fota_download: dfu_target_init error -134
A file of size 20Kbytes:
[00:00:21.046,295] <inf> download_client: Connected to itoctonnectstore.blob.core.windows.net
[00:00:21.055,450] <inf> download_client: Configuring socket timeout (10 s)
[00:00:21.063,140] <dbg> download_client.get_request_send: Send Buffer: GET /nrf/test/random.bin HTTP/1.1
Host: itoPacket id: 2 acknowledged
Connection: keep-alive
Range: bytes=0-2047
[00:00:21.084,442] <dbg> download_client.get_request_send: Sending HTTP request
[00:00:21.093,475] <dbg> download_client.download_thread: Receiving up to 4096 bytes at 0x2002060c...
[00:00:21.325,836] <wrn> download_client: Peer closed connection!
[00:00:21.332,763] <wrn> fota_download: Download socket error. 1 retries left...
[00:00:21.341,033] <inf> download_client: Reconnecting..
[00:00:21.348,297] <inf> download_client: Attempting to connect over IPv4
[00:00:21.355,987] <inf> download_client: Setting up TLS credentials
[00:00:23.047,271] <inf> download_client: Connected to itoctonnectstore.blob.core.windows.net
[00:00:23.056,457] <inf> download_client: Configuring socket timeout (10 s)
[00:00:23.064,147] <dbg> download_client.get_request_send: Send Buffer: GET /nrf/test/random.bin HTTP/1.1
Host: itoctonnectstore.blob.core.windows.net
Range: bytes=0-2047
[00:00:23.082,794] <dbg> download_client.get_request_send: Sending HTTP request
[00:00:23.091,796] <dbg> download_client.download_thread: Receiving up to 4096 bytes at 0x2002060c...
[00:00:23.325,836] <wrn> download_client: Peer closed connection!
[00:00:23.332,855] <err> fota_download: Download client error
Also, the same download works successfully with curl mimicking the same header and remote doesn't disconnect
curl -v -X GET \
-H 'Accept:' \
-H 'User-Agent:' \
-H 'Host: itoctonnectstore.blob.core.windows.net' \
-H 'Connection: keep-alive' \
-H 'Range: bytes=0-2047' \
'itoctonnectstore.blob.core.windows.net/.../random.bin'
This is difficult to debug because the disconnect may be coming from the modem. The read()  fails with 0 bytes in download_client.c and that ause the "Peer closed" error.
Can you please advise?
Nik
