app_error_fault_handler() when using spi_master_using_nrf_spi_mngr example
I'm beginner with Nordic nRF52 devices.
I'm working on a PCA10040 (2.1.0) dev kit and I would like to communicate through TWI interface.
Then I have installed SES and opened the example given in \nRF5_SDK_17.0.0_9d13099\examples\peripheral\spi_master_using_nrf_spi_mngr.
I have NO mbed Application Shield daughter card connected on the dev kit, I would like first to test the FW example before adding my custom board with sensor on it.
When I debug this project, I come in app_error_fault_handler() after the call of nrf_twi_mngr_perform() (in main.c)
I don't expect to raise an error handler if TWI sensor is not responsive, right?
Why do I have this error handler?
François
  • Hi François
    The example is set up to treat any error returned from the twi_manager module as a critical error, by calling the default error handler.
    If you want to test the example without a sensor attached I would suggest changing this behavior, and rather print the error code that is returned to the log so that you can see if the twi_manager library returns an error or not.
    Then the code will continue running, and you can try to connect your shield and (hopefully) see the error disappear.
    Best regards
    Torbjørn
