Hi guys. I'm currently stumped by a most peculiar issue.
Im using two PCA10040 boards (20 cm apart) to send a data stream via the GZLL protocol: DEVICE button pressed -> DEVICE sends two bytes (uint16_t) that pretty much tell the HOST how many bytes make up a complete message, then the DEVICE sends the actual payload, in 32 bytes increments.
this is are the releant typedefs:
typedef enum
PAYLOAD_STATUS_STANDBY, // waiting to send/ receive
PAYLOAD_STATUS_HEADER_SENT, // a header has been sent
PAYLOAD_STATUS_SENDING_DATA, // a header has been received, we are now sending the actual payload
PAYLOAD_STATUS_RECEIVING_DATA, // a header has been received, we are now receiving the payload
} CORE_PAYLOAD_STATUS_typedef;
typedef struct
union
uint16_t Uint; // the payload length
uint8_t Bytes[2];
} Header; // this basically converts two bytes to an uint16_t
uint8_t Buffer[1024]; // this is actual payload
uint16_t Offset; // used to append data to the Buffer, at the correct position
CORE_PAYLOAD_STATUS_typedef Status;
} CORE_PAYLOAD_typedef;
i have the same project for both host and device, which is pretty much a copy paste of the project provided in the sdk (v17 i think) - the only difference being a #define HOST which handles Gzll's init.
Now, the problem:
If I send 512 bytes or less, the whole process works flawlessly.
However, if i try and send 1022 or 980, for example, it fails. Miserably.
// THIS IS THE ROUTINE USED TO SEND THE HEADER. IT WORKS
static void SendData (uint8_t* data, uint16_t size)
private.TxPayload.Header.Uint = size;
memcpy(private.TxPayload.Buffer, data, size);
NRF_LOG_INFO("WIRELESS SENDING %u HEADER", private.TxPayload.Header.Uint);
bool result = nrf_gzll_add_packet_to_tx_fifo(0, private.TxPayload.Header.Bytes, 2);
ErrorHandler(result, "ERROR SENDING HEADER");
private.TxPayload.Status = PAYLOAD_STATUS_HEADER_SENT;
after I use the above, I wait for the nrf_gzll_device_tx_success callback.
// HANDLE THE DATA SENDING
// A HEADER HAS BEEN RECEIVED BY THE HOST
if(private.TxPayload.Status == PAYLOAD_STATUS_HEADER_SENT)
// SWITCH STATUS TO DATA SENDING
private.TxPayload.Status = PAYLOAD_STATUS_SENDING_DATA;
NRF_LOG_INFO("WIRELESS HEADER SENT");
if(private.TxPayload.Status == PAYLOAD_STATUS_SENDING_DATA)
// SELECT THE FIRST 32 OR THE REMAINING BYTES FROM THE PAYLOAD
uint32_t bytesToSend = MIN(32, private.TxPayload.Header.Uint - private.TxPayload.Offset);
// SEND THE DATA TO THE FIFO
while(nrf_gzll_add_packet_to_tx_fifo(0, private.TxPayload.Buffer + private.TxPayload.Offset, bytesToSend) != true)
NRF_LOG_INFO("NU S A PUTUT COAE");
// INCREASE THE STEP
private.TxPayload.Offset += bytesToSend;
//NRF_LOG_INFO("FRAME - OFFSET SIZE %u", private.TxPayload.Offset);
// IF ALL THE BYTES HAVE BEEN SENT, SWITCH TO STANDBY
if(private.TxPayload.Offset == private.TxPayload.MessageLength.Uint)
private.TxPayload.Status = PAYLOAD_STATUS_STANDBY;
private.TxPayload.Offset = 0;
NRF_LOG_INFO("SENT A MESSAGE");
This works as well, I always receive the correct number of callbacks. However, on the host side, the MCU hangs on nrf_gzll_host_rx_data_ready:
uint32_t data_payload_length = NRF_GZLL_CONST_MAX_PAYLOAD_LENGTH;
nrf_gzll_error_code_t errorCode;
// THIS ALWAYS FIRES
if(private.RxPayload.Status == PAYLOAD_STATUS_STANDBY)
nrf_gzll_fetch_packet_from_rx_fifo(pipe, m_data_payload, &data_payload_length);
memcpy(private.RxPayload.Header.Bytes, m_data_payload, data_payload_length);
private.RxPayload.Status = PAYLOAD_STATUS_RECEIVING_DATA;
NRF_LOG_INFO("HEADER SIZE RECEIVED: %u", private.RxPayload.Header.Uint);
// THIS HANGS
while(nrf_gzll_fetch_packet_from_rx_fifo(pipe, m_data_payload, &data_payload_length) != false)
NRF_LOG_INFO("1");
if(private.RxPayload.Status == PAYLOAD_STATUS_RECEIVING_DATA)
memcpy(private.RxPayload.Buffer + private.RxPayload.Offset, m_data_payload, data_payload_length);
private.RxPayload.Offset += data_payload_length;
NRF_LOG_INFO("REC %lu", private.RxPayload.Offset);
if(private.RxPayload.Offset == private.RxPayload.Header.Uint)
private.RxPayload.Status = PAYLOAD_STATUS_STANDBY;
private.RxPayload.Offset = 0;
RaiseNewDataAvailableEvent(private.RxPayload.Buffer, private.RxPayload.MessageLength.Uint);
NRF_LOG_INFO("2");
Now, if I send 512 bytes, it works perfectly. However, if I try and send 1022:
<info> app: HEADER SIZE RECEIVED: 1024
<info> app: 2
<info> app: 1
<info> app: REC 32
<info> app: 2
<info> app: 1
<info> app: REC 64
<info> app: 2
<info> app: 1
<info> app: REC 96
<info> app: 2
<info> app: 1
<info> app: REC 128
<info> app: 2
<info> app: 1
<info> app: REC 160
<info> app: 2
<info> app: 1
<info> app: REC 192
<info> app: 2
<info> app: 1
<info> app: REC 224
<info> app: 2
<info> app: 1
<info> app: REC 256
<info> app: 2
<info> app: 1
<info> app: REC 288
<info> app: 2
<info> app: 1
<info> app: REC 320
<info> app: 2
<info> app: 1
<info> app: REC 352
<info> app: 2
<info> app: 2
<info> app: 2
<info> app: 2
<info> app: 2
<info> app: 2
<info> app: 2
<info> app: 2
<info> app: 2
<info> app: 2
<info> app: 2
<info> app: 2
<info> app: 2
this is the output.
I am going crazy. I've stayed up till 4 am. I cant for the life of me figure it out.
BTW: stack heap & size are 8096.
