Please, give me an advice. I need to measure the supply voltage and trigger an interrupt after the measurement. An END interrupt is triggered only once. It must be without libraries, just by writing to NRF_SAADC->....
Have you remembered to clear it after it has fired?
I start the measurement by software.
In interrupt the flag is cleared.:
void SAADC_IRQHandler(void)
if(NRF_SAADC->EVENTS_END > 0)
NRF_SAADC->EVENTS_END = 0;
Try to use nrf_saadc_event_clear instead of NRF_SAADC->EVENTS_END = 0;
It doesn't work. I have a project where bluetooth is used and due to the size of the softdevice, all logs must be turned off and libraries must not be used.
jca said:libraries must not be used
You need to use the HAL in order to operate the nRF52 safely, for instance:
__STATIC_INLINE void nrf_saadc_event_clear(nrf_saadc_event_t event)
*((volatile uint32_t *)((uint8_t *)NRF_SAADC + (uint32_t)event)) = 0x0UL;
#if __CORTEX_M == 0x04
volatile uint32_t dummy = *((volatile uint32_t *)((uint8_t *)NRF_SAADC + (uint32_t)event));
(void)dummy;
That dummy read is necessary, see Migrating from the nRF51 Series to the nRF52 Series -> Functional changes.
