Hi All,
we are seeing a problem when stopping for debugging that we end up in an end stop called "app_error_fault_handler" after a few single steps.
This thread sheds light onto what is happening:
So it seems as soon as the "softdevice" is running the debugger stops working. The solution seems to be this segger "monitor mode" debugging:
www.segger.com/.../monitor-mode-debugging
But this requires some extra software and extra hardware because the on board jlink is not working with the only difference (I think) being one bit different written into the processor when stopping to keep interrupts running.
So can somebody confirm / deny if this "monitor mode" is really not working on the Nordic DK boards? Also can somebody confirm / deny if this "monitor mode" is really working to use a debugger in single step mode with the Nordic "softdevice" running? We ran into so many problems with this segger stuff that we are considering to pull the plug and look elsewhere for bluetooth ics. Also I do not think those segger type of business models should be supported.
Kind Regards,
