We plan to use NRF52805 in our existing boards to add BLE functionality. In the PCB guidelines of the NRF52805 there is a notification about the thickness of the PCB being max 0.8mm (shown below).
Note: The distance between the ground plane and the top layer should be less than or equal to 0.8 mm. If this design rule is not followed, Radio parameters may not meet specification.
But our current PCB has a thickness of 1.6mm. We assume we can still use NRF52805 by adjusting the transmission line widths and impedance matching components for the antenna. But we are unsure whether there are some further points to compensate for different PCB thickness. Which parameters should be expect to change/deteriorate and what precautions can be taken against.
Regards
