Can't configure 2 gpio pins with opposite pull state
I try configure 2 gpio pins with opposite pull state, one NRF_GPIO_PIN_PULLUP, other NRF_GPIO_PIN_PULLDOWN:
nrf_drv_gpiote_in_config_t in_config = GPIOTE_CONFIG_IN_SENSE_LOTOHI(false);
in_config.pull = NRF_GPIO_PIN_PULLUP;
err_code = nrf_drv_gpiote_in_init(PIN_BUTTON, &in_config, button_handler);
nrf_drv_gpiote_in_event_enable(PIN_BUTTON, true);
in_config.pull = NRF_GPIO_PIN_PULLDOWN;
err_code = nrf_drv_gpiote_in_init(PIN_IMPULSE, &in_config, impulse_handler);
nrf_drv_gpiote_in_event_enable(PIN_IMPULSE, true);
But, callback don`t called.
If I configure with same pull state, then callback is called.
Why is this occurs? How to set up pins with diffrent pull state?
Thank you!
  • Hello again,
    I am terribly sorry for the late reply.
    Serhio said:
    For testing purposes, I`m connecting it with a plus. Thus, it is like a button. In release, a phototransistor will be connected there.
    Thank you for clarifying. So, what you are saying is that both GPIOs in questions are connected with a button, sensing a change in the level, correct?
    Serhio said:
    I like your holistic approach) I've tried using nrf_gpio_pin_toggle(PIN_LED)
    Great! What was the results of these trails, were you able to confirm the callback behavior using the LED?
    Serhio said:
    I am aware of this define. But thank you for not forgetting about that. It`s equal 4
    Thank you for verifying this. It is indeed quickly overlooked, and so I just had to make sure this was not the case right now.
    Serhio said:
    Now for the good news. As you suggested. I setup pin with hi-accuracy is true and now it works.
    That is good news indeed!
    Serhio said:
    But does this cause increased power consumption? The device under development is powered by a CR2032 battery and the issue of power consumption is very important.
    Yes, high-accuracy GPIOTE IN_EVENTS does increase power consumption compared to the low-accuracy PORT event. The GPIOTE IN will enable the HFCLK source to run when a edge is triggered, then start sampling using the HFCLK.
    There is also some Erratas present for the GPIOTE on the nRF52832. Which SoC version and variant are you working with?
    Serhio said:
    Thus, low-accuracy don't work for pins with opposite pull state?
    I have never heard of this behavior before, and neither has my colleagues that I have conferred with. I would not expect this either.
    Could you share with me a stripped down project in which you are seeing this behavior?
    I will then attempt to replicate the behavior on my end, so that I may better debug it.
    Looking forward to getting to the bottom of this!
    Karl
  • Hello again,
    Could you also try to use GPIOTE_CONFIG_IN_SENSE_TOGGLE() instead of _LOTOHI for your buttons?
    I believe that if a port event is triggered on a low to high transition on a pin, a new port event can’t be triggered before that pin has gone low again or the pin is configured to sense low (which will trigger a new event on high to low transition). See the answers to this and this post.
    The results of this test will also tell us more about what might be causing the unexpected behavior you are seeing.
    Karl
  • Hello! I`m very sorry for my late reply. I was on vacation.
    Yes
    Yes, the LED state did not change
    NRF52832_xxAA_REV2, SoftDevice S132 v5.0.0
    I tried. And it works! Code:
    {    nrf_drv_gpiote_in_config_t in_config = GPIOTE_CONFIG_IN_SENSE_TOGGLE(false);
        nrf_drv_gpiote_in_event_enable(PIN_BUTTON, true);}/**/
    I use GPIOTE_CONFIG_IN_SENSE_TOGGLE only for one button and now... works both buttons..
    For reproduce issue, just use code from my first message. And connect one button to "+" and other to "-"
    No worries at all, I hope you had a great vacation!
    Thank you for letting me know.
    I am glad to hear that! Then I would think the problem was caused due to the PORT event already being generated when the second one came in.
    Is the application now working as you had intended?
    If you are using TOGGLE on both, you can keep track of which direction it has transitioned since the last event.
    Karl
  • Is the application now working as you had intended?
    Yes, Karl, I'm satisfied how the application works now. Thank you for your help.
