Can't configure 2 gpio pins with opposite pull state
I try configure 2 gpio pins with opposite pull state, one NRF_GPIO_PIN_PULLUP, other NRF_GPIO_PIN_PULLDOWN:
nrf_drv_gpiote_in_config_t in_config = GPIOTE_CONFIG_IN_SENSE_LOTOHI(false);
in_config.pull = NRF_GPIO_PIN_PULLUP;
err_code = nrf_drv_gpiote_in_init(PIN_BUTTON, &in_config, button_handler);
nrf_drv_gpiote_in_event_enable(PIN_BUTTON, true);
in_config.pull = NRF_GPIO_PIN_PULLDOWN;
err_code = nrf_drv_gpiote_in_init(PIN_IMPULSE, &in_config, impulse_handler);
nrf_drv_gpiote_in_event_enable(PIN_IMPULSE, true);
But, callback don`t called.
If I configure with same pull state, then callback is called.
Why is this occurs? How to set up pins with diffrent pull state?
Thank you!
    That sounds strange.
    Could you detail your issue some more:
    How are you testing this, and how does it behave differently than expected? I just want to make sure that I have understood you correctly.
    Could you also share the callback code, which is / is not being called?
    Which pins on the nRF52832 are you using, and what are they connected to?
    Are you working with a nRF52 DK, or a custom board?
    Looking forward to resolving this issue together!
    Karl
  • Hello, Karl!
    Callback code, for example:
    void button_handler(nrf_drv_gpiote_pin_t pin, nrf_gpiote_polarity_t action)
       NRF_LOG_INFO("button_handler %d %d", pin, action);
       nrf_gpio_pin_toggle(PIN_LED);
    void impulse_handler(nrf_drv_gpiote_pin_t pin, nrf_gpiote_polarity_t action)
       NRF_LOG_INFO("impulse_handler %d %d", pin, action);
    If I configure 1(any) gpio pin then corresponding callback called(log is displayed).
    PIN_BUTTON - 25
    PIN_IMPULSE - 9 (I use CONFIG_NFCT_PINS_AS_GPIOS define)
    I use custom board:
  • In same time, I can use this code:
        nrf_gpio_cfg_input(PIN_BUTTON, NRF_GPIO_PIN_PULLUP);
    And then use nrf_gpio_pin_read(PIN_BUTTON)
    But that doesn't suit me..
    Sorry for my late reply.
    Thank you for clarifying.
    Could you also tell me what this pin is connected to?
    Are you using deferred logging, by the way?
    If you are, it is not a definite way to see the flow of your program using logs, since they will be written only when the CPU have no other task.
    Instead, I would suggest using a LED or sending a message to verify that you have entered into one of the callbacks.
    No, I would not recommend this, this is far from ideal.
    I see now that you are configuring both your inputs as low-accuracy.
    Could you tell me what your GPIOTE_CONFIG_NUM_OF_LOW_POWER_EVENTS is defined as in your sdk_config? I suspect it might be set to 1, in which case you should try increasing it to 2. Please try this, and let me know if this resolves your issue.
    Furthermore, I would alert you to the difference between PORT event and IN_EVENT, since you are currently using low-accuracy configuration which means that both pins will generate the same PORT event, as opposed to high-accuracy configuration which has a dedicated IN_EVENT per pin.
    Looking forward to resolving this issue together,
    Karl
  • Could you also tell me what this pin is connected to?
    For testing purposes, I`m connecting it with a plus. Thus, it is like a button. In release, a phototransistor will be connected there.
    I like your holistic approach) I've tried using nrf_gpio_pin_toggle(PIN_LED)
    I am aware of this define. But thank you for not forgetting about that. It`s equal 4
    Now for the good news. As you suggested. I setup pin with hi-accuracy is true and now it works.
    But does this cause increased power consumption? The device under development is powered by a CR2032 battery and the issue of power consumption is very important.
    Thus, low-accuracy don't work for pins with opposite pull state?
    Thanks for your answers.
