Question about using Install Code
Hi Sir or Madam,
I tested examples\zigbee\light_control demo recently and I want to test install code function based on this example, the first step is I add install code in coordinator, then I power up coordinator and bulb(without install code function), and I found the bulb still can join the coordinator, does this means the install code function still can't work? If I want to use install code to join the netwrok that coordinator created what else I need to do? Thanks for your help!
if (zb_secur_ic_add(dut_ieee_addr1, ZB_IC_TYPE_128, install_code) != RET_OK){
zb_set_installcode_policy(ZB_TRUE);
    What SDK version are you using?
    So where do you call this, and what does zb_secur_ic_add() return?
    Please be aware that your check:
    if (zb_secur_ic_add(dut_ieee_addr, ZB_IC_TYPE_128, install_code) != RET_OK)
        // you are not doing anything here.
    BR,
    Edvin
  • Thanks Edvin for your reply.
    nRF5_SDK_for_Thread_and_Zigbee_v4.1.0_32ce5f8 is what I use. And I called this after zboss_start_no_autostart(). I already checked the return value of add is RET_OK. Thanks.
    /** Start Zigbee Stack. */
    zb_err_code = zboss_start_no_autostart();
    ZB_ERROR_CHECK(zb_err_code);
    /* Set device installcode policy */
  • Hi Edvin,
    Sorry for my misunderstanding. In fact the router is not join success, and the failure I found it is caused by the order of IEEE Address which I set on Coordinator is not correct.
    Thanks!
     You may mean to say that you have already checked while debugging, but this snippet doesn't check the return value of zb_secur_ic_add(), just in case you think this snippet checks, and your application is supposed to handle the exception if one occurs.
    This is because the {} brackets are empty. Just like this will print "a is equal to b":
    uint8_t a = 1;
    uint8_t b = 2;
    if (a == b)     //check if a == b
    NRF_LOG_INFO("a is equal to b");
    I'm glad to hear that you found out the issue Slight smile
    Edvin
