How to extract the current time from the calendar_example, i am not clear with the procedure
I understand now that the time I am getting is UTC from the NTP server.
How could I convert it to get a time in CEST zone ?
Adeel.
Hi Adeel
I must admit I asked myself the same question ;)
The naive way is to simply add 2 hours to the timestamp before you do the conversion.
If my math is correct two hours should equal 7.200.000 ms, or 7200 seconds.
I will check with the date_time developer if there is a more elegant way to do this, that checks the local timezone and adjust the time accordingly.
Best regards
Torbjørn
Hi Tobjorn,
No worries, You could let me know if you get any heads up on this. I can continue on with the development through this for now :).
Thanks a lot for the help .
Hi Adeel
The developer basically suggested the same thing ;)
Time zone adjustment will need to happen separately, by adding or subtracting the required number of hours from the timestamp.
Best regards
Torbjørn
Hi Tobjorn,
Thanks for the update on this. Yes, I think it makes sense as well since different time zones can adapt differently just by adding the hours based on their difference to the UTC :).
Many thanks, I have adjusted it to my zone by adding the reqd. number of hours :).
Adeel.
