Simultaneous execution of extended advertisement and scanning
I am developing software with the following features.
  • Communicates between two boards with nRF52840, nRF5 SDK 15.3.0, and its S140
  • Activate both extended advertising and scanning on each node
    Parameters: BLE_GAP_ADV_TYPE_EXTENDED_NONCONNECTABLE_NONSCANNABLE_UNDIRECTED, BLE_GAP_PHY_CODED, etc.
  • Repeat advertising and scanning alternately.
    One is advertising, the other is scanning
The software having above features is operating normally. But I am wondering about the following:
[Question 1]
If the node stop scanning during advertising, it can communicate normally.
(Call nrf_ble_scan_stop() just before the advertising starts and nrf_ble_scan_start() after the advertising ends.)
But if the node do not stop scanning during advertising, the communication success rate will drop extremely.
(Almost no communication)
Is this correct behavior? Or can it be improved by changing parameters or API calls?
*I understand from the ticket below that this is the correct behavior/limitation.
devzone.nordicsemi.com/.../simultaneous-scanning-and-extended-advertising-with-sdk-15-2
[Question 2]
How do I embed long length unique data into its advertising? The following is my source code.
Please correct any mistakes in the following methods.
And if correct, please tell me how many bytes can be sent this way.
Currently I am sending 185 bytes, but I want to send as much data as possible.
/* For advertising */
static uint8_t m_enc_advdata[BLE_GAP_ADV_SET_DATA_SIZE_EXTENDED_MAX_SUPPORTED];         /**< Buffer for storing an encoded advertising set. */
static ble_gap_adv_data_t m_adv_data =
    .adv_data =
        .p_data = m_enc_advdata,
        .len    = BLE_GAP_ADV_SET_DATA_SIZE_EXTENDED_MAX_SUPPORTED
    .scan_rsp_data =
        .p_data = NULL,
        .len    = 0
static bool advertising_data_set(void)
    ret_code_t ret;
    ble_gap_adv_params_t const adv_params =
        .properties    =
          .type = BLE_GAP_ADV_TYPE_EXTENDED_NONCONNECTABLE_NONSCANNABLE_UNDIRECTED,
        .p_peer_addr   = NULL,
        .filter_policy = BLE_GAP_ADV_FP_ANY,
        .interval      = 80,
        .duration      = 80,
        .primary_phy   = BLE_GAP_PHY_CODED,
        .secondary_phy = BLE_GAP_PHY_CODED,
        .max_adv_evts  = 1,
    ble_advdata_t const adv_data =
        .name_type          = BLE_ADVDATA_NO_NAME,
        .flags              = BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE,
        .include_appearance = false,
/* set long length unique data to m_enc_advdata */
    memcpy(m_enc_advdata, <long length unique data>, 185);
/* call sd_ble_gap_adv_set_configure without calling ble_advdata_encode() */
    ret = sd_ble_gap_adv_set_configure(&m_adv_handle, &m_adv_data, &adv_params);
/* For scanning */
NRF_BLE_SCAN_DEF(m_scan);                                   /**< Scanning Module instance. */
static ble_gap_scan_params_t m_scan_param =                 /**< Scan parameters requested for scanning and connection. */
    .active        = 0x00,
    .interval      = 170,
    .window        = 170,
    .filter_policy = BLE_GAP_SCAN_FP_ACCEPT_ALL,
    .timeout       = 0,
    .scan_phys     = BLE_GAP_PHY_CODED,                                 // Choose only one of the following scan_phys
    .extended      = 1,
        case BLE_GAP_EVT_ADV_REPORT:
            <In this part, referring m_scan.scan_buffer.len and m_scan.scan_buffer.p_data>
  • Hi.
    Q1.
    From the ticket you linked to; It is true that there is a limitation that the device cannot advertise and scan simultaniously. The radio will have to swap between advertising and scanning, due to the fact that there is only one radio.
    Q2.
    From what I can see you have already enabled extended advertising. Using extended advertising allows you to advertise up to 255 bytes of data.
    Br,
    Joakim
  • Dear Joakim,
    Thank you for your reply. And I'm sorry for my late reply.
    With your help, my development is progressing.
    However, there is one point that makes me wonder.
    That is, the byte length that can be sent in an advertisement is limited to 236 bytes.
    If I fill the buffer with 237 bytes data and send it, API sd_ble_gap_adv_set_configure returns NRF_ERROR_INVALID_LENGTH.
    As I've already seen last time, I set the advertise buffer size to BLE_GAP_ADV_SET_DATA_SIZE_EXTENDED_MAX_SUPPORTED(means 255).
    Then, before sending it by calling sd_ble_gap_adv_start, I call sd_ble_gap_adv_set_configure after filling this buffer with application-dependent data, and it works fine up to a data length of 236 bytes, but from 237 bytes, the above error occurs.
    So far, 236 bytes is long enough for my application, so this issue doesn't hinder my development.
    But I want to understand why it's technically an error.
    I would appreciate it if you could give me some advice.
  • The SoftDevice checks the validity of the advertising data. So it can return NRF_ERROR_INVALID_LENGTH in several situations:
    • len field is 0 or > max (depends on extended or not).
    • Flags length field is other than 2 (always 1 octet AD type, 1 octet AD data)
    • Length fields in packet add up to be more than the packet length.
  • Dear Joakim,
    Thank you for providing valuable information.
    Can you give me the format information about where the following three fields you pointed out correspond to in the raw data? It is enough to introduce the corresponding web page that describes it.
    - Len field
    - Flags length field
    - Length fields
    Additionally, in my source code, the API ble_advdata_encode is not called, following the example on page 4 of "nRF5_SDK_15.3.0_59ac345/components/softdevice/s140/doc/s140_nrf52_6.1.0_migration-document.pdf".
    Please check if there is no problem with this method.
    * The raw extended advertising data I send starts with 4 bytes of fixed data {0x89, 0xF6, 0xA2, 0x3D}.
    The next 1-byte upper 4 bits and lower 4 bits can be any value from 0 to 3.
    After that, the data to be actually sent is placed.
  • Hi.
    Sorry about the delay.
    If you haven't found the information you were looking for here, you can find detailed information about almost everything related to BLE in the official Bluetooth Core Specification;
    https://www.bluetooth.com/specifications/bluetooth-core-specification/
    You can also find a lot of information in our online documentation:
    https://infocenter.nordicsemi.com/index.jsp
    Br,
    Joakim
