do i need to flash softdevice s140 when programming the nrf52840 dongle using another development board as debugger ?
hello Nordic
i want to use the bl652 laird development board (nrf52832) as a debugger  for the nrf52840 dongle
i have been working with that board allready so it has the s132 softdevice on it, maybe its a stupied question but i want to be sure the softdevice is flashed to the SOC and not on some local board memory
i have 2 question:
1. do i need to flash the s140 to the nrf52840 dongle before programing it and using the s140 examples ? if so what will be the easy way to do that ?
2.  if i would like to later use the usb on the dongle as a virtual serial port on my pc, how can i simulate a uart port when the dongle is connected and debugged via the development board ?
if you are not familiar with the bl652 then for answering consider i am using the 10040 board
best regards
Ziv
  • 1. do i need to flash the s140 to the nrf52840 dongle before programing it and using the s140 examples ? if so what will be the easy way to do that ?
     Yes. The easiest way is to use the USB bootloader and the Programmer app in nRF Connect For Desktop.
     You need to use the USB CDC library, see the USB CDC example in the SDK.
