On line 904 of nrf_log_frontend.c there is a log message to indicate the backends are flushed – but this message adds a log to the queue. If auto flush is enabled, this can lead to an infinite loop. Present in SDK 17.0.0
Thank you for reporting this issue. It is highly appreciated! I have made an entry in our internal issue tracker, for the SDK team to look into.
Terje
Has this issue been addressed in SDK 17.0.2? I believe we are seeing a similar problem in our device using the RTT transport. We are also using SDK 17.0.2.
This issue is present in SDK 17.0.2.
The offending line is line 904 in <sdk root>/components/libraries/log/src/nrf_log_frontend.c:
NRF_LOG_WARNING("Backends flushed");
If what you see is this issue, then commenting out or removing that line should fix it.
Terje
It could also be this other issue I recently discovered: devzone.nordicsemi.com/.../bug-in-nrf_log_frontend-c
I use SDK 17.0.2.
I try to use flash backend crash log function, I found "Backends flushed" kept showing even there was no crash. Is this a related issue?
