Not connecting to US LTE-M network
We're experiencing a strange issue where a device we sent to a partner in the US wasn't able to connect over there after rigorously testing this before shipping here in the EU and tuning it for the US. However, when it was shipped back to the Netherlands it was able to connect to EU networks as soon as it arrived.
What's even stranger is we replicated the issue with another device in the US using the same low-power software and it wasn't able to connect. Then when flashing it with the same software build (only with debug enabled) it was able to connect.
Has this problem been seen before? Is it possible the nRF9160 has a different procedure/method for scanning through LTE-M bands while in low-power vs. active?
  • Hi JThomson,
    Are you using the Lte_lc library to configure the modem when booting up?
    Do you select the systemode (lte-m) or any Bandlock when booting up, or do you configure the XDATAPRFL?
    What do you define by "active" vs. "low power"?
    It would be helpful with more information of the configuration used, and some serial output logs.
    CONFIG_SERIAL=y
    CONFIG_LOG=y
    CONFIG_LTE_LINK_CONTROL_LOG_LEVEL_DBG=y
  • Yes the LTE_LC library is used, the function used for connecting is lte_lc_init_and_connect(). Also no bandlock is applied but the power level is set using the command "AT%XDATAPRFL=0".
    By active I mean one where the systems are functionally identical but the UART socket isn't disabled like in the low-power build.
    Here's the configuration used:
    CONFIG_NEWLIB_LIBC=y
    CONFIG_NEWLIB_LIBC_NANO=n
    CONFIG_BSD_LIBRARY=y
    CONFIG_GPIO=y
    CONFIG_STDOUT_CONSOLE=y
    CONFIG_TEST_RANDOM_GENERATOR=y
    CONFIG_NETWORKING=y
    CONFIG_NET_SOCKETS_OFFLOAD=y
    CONFIG_NET_SOCKETS=y
    CONFIG_NET_SOCKETS_POSIX_NAMES=y
    CONFIG_RING_BUFFER=y
    CONFIG_TRUSTED_EXECUTION_NONSECURE=y
    CONFIG_LOG_DEFAULT_LEVEL=4
    # Trace not LP
    #CONFIG_THREAD_NAME=y
    #CONFIG_SEGGER_SYSTEMVIEW=y
    #CONFIG_USE_SEGGER_RTT=y
    # LTE link control
    CONFIG_LTE_NETWORK_MODE_LTE_M_GPS=y
    CONFIG_LTE_LINK_CONTROL=y
    CONFIG_LTE_AUTO_INIT_AND_CONNECT=n
    # This time out is 2 x 90s scans + 10s between
    CONFIG_LTE_NETWORK_TIMEOUT=190
    CONFIG_LTE_NETWORK_USE_FALLBACK=n
    # Heap and stacks
    #CONFIG_MPU_STACK_GUARD=y
    CONFIG_MINIMAL_LIBC_MALLOC_ARENA_SIZE=16384
    CONFIG_NEWLIB_LIBC_ALIGNED_HEAP_SIZE=16384
    CONFIG_HEAP_MEM_POOL_SIZE=16384
    CONFIG_MAIN_STACK_SIZE=2048
    CONFIG_MAIN_THREAD_PRIORITY=7
    # eDRX Cycle = 327.68s
    CONFIG_LTE_EDRX_REQ_VALUE="1010"
    # Watch Dog
    #CONFIG_WDT_LOG_LEVEL_DBG=y
    CONFIG_WATCHDOG=y
    # Enable SUPL client support
    CONFIG_NRF9160_GPS=y
    CONFIG_NRF9160_GPS_LOG_LEVEL_DBG=y
    CONFIG_SUPL_CLIENT_LIB=y
    #ESP8285
    CONFIG_UART_1_NRF_UARTE=y
    CONFIG_BSD_LIBRARY_TRACE_ENABLED=n
    #AT commands (Not LP)
    CONFIG_AT_HOST_LIBRARY=y
    CONFIG_LOG=y
    # For LP
    #CONFIG_AT_HOST_LIBRARY=n
    #CONFIG_BOOT_BANNER=n
    #CONFIG_PRINTK=n
    #CONFIG_LOG=n
    # ADC
    CONFIG_ADC=y
    CONFIG_ADC_0=y
    CONFIG_ADC_NRFX_SAADC=y
    # NVS
    # FLASH MEMORY
    CONFIG_FLASH=y
    CONFIG_FLASH_PAGE_LAYOUT=y
    CONFIG_MPU_ALLOW_FLASH_WRITE=y
    CONFIG_NVS=y
  • Hi JThomson,
    I forgot to ask, which modem firmware versions are you using?
    I will try to replicate the issue.
  • Is it possible to replicate this with the CONFIG_BSD_LIBRARY_TRACE_ENABLED=y?
    If so please share the modem trace.
