Looking at the footprint you supply for the aQFN73 package (I have looked at the one supplied for nRF52840), I see that the pad have a size = 0.275mm.
If IPC-7351 is followed, and the Maximum Material Condition (MMC) is used for the pads, the resulting pad size = 0.2mm (using the supplied nominal ball diameter in your datasheet).
Have you encountered problems using the IPC standard with your package and thus used a ~25% larger pad size? Maybe there are other reasons?
Best Regards
Martin
