I have a question about pairing control.
Hi, I have a question about Bluetooth pairing control.
I use nrf52dk board and sdk v17.  I am working on many things using the example of sdk.
Now I'm trying to control pairing using the button.  I found two ways to stop pairing.
    //No pairing1
     //uint32_t err_code = sd_ble_gap_sec_params_reply(m_conn_handle, BLE_GAP_SEC_STATUS_PAIRING_NOT_SUPP, NULL, NULL);
     //APP_ERROR_CHECK(err_code);
    //No pairing2
     //uint32_t err_code = pm_sec_params_set(NULL);
But I don't know how to restart pairing.  How can I restart pairing?
And to start pairing with buttons, should I modify it at the button input of the function 'bsp_evt_handler'?
Thank you very much.
    You can try calling pm_sec_params_set() and passing the initial parameter that is used when first initializing the module.
    Yes, I think this should work.
    regards
    Jared
  • Thank you for your answer.  I'm sorry, but I'm not sure yet.
    I think it's a simple problem, but I'm sorry to keep asking you.
    I wrote it like this so I wouldn't pair up at the beginning.
    (For your information, I combined 'ble_app_uart' and 'peer_manager'.)
        uint32_t err_code;
    So it doesn't pairing at first.
    And this code enables pairing with button input.
        uint32_t err_code;
        switch (event)
             case BSP_EVENT_KEY_2: //button3
                //peer_manager_init(); //Not doing nothing
                //err_code = pm_sec_params_set(&sec_param); //error
    I tried this, but I think I did something wrong.
    What do I need to enter in the parameters for pm_sec_params_set()?
  • What are you doing in peer_manager_init()? Most examples in the SDK that use the peer manager already have a pm_sec_param_set() call in peer_manager_init() Which would make line 10 redundant. I would try calling the peer_manager_init() in start of main and remove both the pm_sec_params_set(NULL) call and the call in the init function if you have one. You could then only call pm_sec_params_set(&sec_param) in the BSP_EVENT_KEY_2. Notice that it's not recommended to do too much in the interrupt handlers as it can interfere with other priority tasks.
     Elaborate more on this. Does the function call return any errors?
