I'm trying to run the https_client sample on an nrf9160dk, and it's giving me the following output:
*** Booting Zephyr OS build v2.3.0-rc1-ncs1-1440-g"020" !$#a 1 ***
Flash regions Domain Permissions
00 00 0x00000 0x08000 Secure rwxl
01 31 0x08000 0x100000 Non-Secure rwxl
Non-secure callable region 0 placed in flash region 0 with size 32.
SRAM region Domain Permissions
00 07 0x00000 0x10000 Secure rwxl
08 31 0x10000 0x40000 Non-Secure rwxl
Peripheral Domain Status
00 NRF_P0 Non-Secure OK
01 NRF_CLOCK Non-Secure OK
02 NRF_RTC0 Non-Secure OK
03 NRF_RTC1 Non-Secure OK
04 NRF_NVMC Non-Secure OK
05 NRF_UARTE1 Non-Secure OK
06 NRF_UARTE2 Secure SKIP
07 NRF_TWIM2 Non-Secure OK
08 NRF_SPIM3 Non-Secure OK
09 NRF_TIMER0 Non-Secure OK
10 NRF_TIMER1 Non-Secure OK
11 NRF_TIMER2 Non-Secure OK
12 NRF_SAADC Non-Secure OK
13 NRF_PWM0 Non-Secure OK
14 NRF_PWM1 Non-Secure OK
15 NRF_PWM2 Non-Secure OK
16 NRF_PWM3 Non-Secure OK
17 NRF_WDT Non-Secure OK
18 NRF_IPC Non-Secure OK
19 NRF_VMC Non-Secure OK
20 NRF_FPU Non-Secure OK
21 NRF_EGU1 Non-Secure OK
22 NRF_EGU2 Non-Secure OK
23 NRF_DPPIC Non-Secure OK
24 NRF_GPIOTE1 Non-Secure OK
25 NRF_REGULATORS Non-Secure OK
SPM: NS image at 0xc000
SPM: NS MSP at 0x20027028
SPM: NS reset vector at 0xea69
SPM: prepare to jump to Non-Secure image.
*** Booting Zephyr OS build v2.3.0-rc1-ncs1-1451-gb160c8c5caa5 ***
HTTPS client sample started
[00:00:00.008,209] <err> at_cmd: Failed to send AT command (err:9)
[00:00:00.008,270] <err> lte_lc: Could not send AT command, error: -9
[00:00:00.008,270] <err> lte_lc: Could not set system mode, error: -9
Provisioning certificate
Waiting for network..[00:10:00.575,469] <inf> lte_lc: Network connection attempt timed out
[00:10:00.597,229] <inf> lte_lc: Using fallback network mode
OK
Connecting to translate.google.cn
connect() failed, err: 45
error 9 is, as far as I can tell, EBADF bad file descriptor - does that seem right? Is there a better list for error codes than nrfxlib/bsdlib/include/nrf_errno.h
error 45 seems to be related to certificates from searching these forums, but I already noticed that the example certificate didn't match and grabbed an updated one directly from the domain - apparently to no avail.
I've added
CONFIG_SERIAL=y
CONFIG_UART_CONSOLE_LOG_LEVEL_DBG=y
CONFIG_LOG=y
CONFIG_LOG_BACKEND_UART=y
CONFIG_AT_HOST_LIBRARY=y
to the prj.conf so I could access the debug log and try to poke the modem with LTE link monitor, are some of those flags somehow incompatible with the https_client sample?
I couldn't find any documentation about config flag incompatibilities.
Is there any way to get more verbose error logging about what's happening?
If I connect LTE Link monitor after the "fallback network mode" message, it sometimes indicates that LTE is connected, however if I connect it before that message, it never shows LTE as connected - is it unable to discern the transition between not connected and connected, or is this 'connected' indication a false positive?
I searched for similar posts, but couldn't find anything mentioning an error 9 or -9.
Fwiw, I'm using the sim card that a Nordic FAE provided with my nrf9160-DK and said should work fine.
My phone is on the same LTE network and same table, and shows a signal strength of -104dBm / 36 ASU which it seems quite happy with.
PS: LTE Link Monitor seems to eat 100% CPU while connected to the serial port, is that normal? strace says it's continually hammering epoll_wait with zero timeout and there's a couple of threads throwing futexes back and forth as fast as they can.
