I'm developing for a 52833 using SDK_17.0.0 and S113_7.0.1.
I'm using the following code with the intention that when the RDY pin goes low, it will wake up the processor. The RDY pin is connected to the output from a proximity sensor. There is an external 4K7 pull-up. If new data is available, the sensor pulls the RDY pin low.
nrf_gpio_cfg_sense_set(RDY_PIN, NRF_GPIO_PIN_SENSE_LOW);
APP_ERROR_CHECK(sd_power_system_off()); // This function will not return; wakeup will cause a reset).
I have confirmed that the sensor is working correctly, but the processor is not resetting. Instead, it seems to get stuck in an indeterminate state where the current draw is ~6mA, compared to around 100nA before the RDY pin goes low. If I pull the RDY pin low using a switch, then everything works as expected. I thought this might mean that the RDY pin was not going low for long enough for the SENSE to work. The sensor generates a series of pulses on the RDY line rather than a single transition. However, the minimum pulse width is ~10ms, which should be plenty long enough. Is there a problem if the SENSE input changes state during wakeup?
I then switched to using interrupts to detect RDY going low using the following code, and this works. The interrupt routine gets called.
ret_code_t err_code;
in_config.pull = NRF_GPIO_PIN_NOPULL;
However, I have noticed that calls to NVIC_SystemReset() do not appear to work after running the above function. If I call NVIC_SystemReset() before running the above then it works but if I call NVIC_SystemReset() either in the interrupt routine or anytime thereafter, then the processor gets stuck in the same indeterminate, high-current state described above.
So...
- Are there any timing requirements for SENSE signals when used to wake the processor?
- Is there anything specific that I need to enable/disable/clear before enabling a SENSE input, or after enabling a SENSE input but before calling sd_system_power_off() or NVIC_System_Reset()?
Thanks.
