My ESB PTX receives delayed duplicate ACK packets from my PRX
Hello!
My problem is that I am getting duplicates of the ACK packets I send from my PRX device to my PTX device.
To debug this problem, I configured my PTX to continuously stream data at 100hz. In my PRX device, I receive the packets, handle them, and then I send an ack packet on ever 100th sample.
So from my PRX I am sending (one uint32 number at a time) 0,1,2,3,4,5,6,7,8,9,10, 11, 12, 13, 14, ...
But on my PTX I receive (one uint32 number  at a time)           0,1,2,3,4,5,6,7,0,8,1,9,2,10,3,11,4,12,5,13,6,14, ...
The pattern is always consistent - the first 8 packets come through without any problem, and then I start getting current data interleaved with duplicate data that is always 8 packets old.
I suspect that I must be doing something wrong, but I have tried a lot of things and the only thing that I have found that gets rid of the duplicate packets is to flush the tx_fifo buffer on the PRX inside my esb event handler when I receive my NRF_ESB_EVENT_TX_SUCCESS event. I have to completely flush it. calling nrf_esb_pop_tx() has no effect. The really crazy thing is that if I run nrf_esb_pop_tx() I get NRF_ERROR_BUFFER_EMPTY,  but if I don't flush the (apparently empty) buffer, My PRX will send duplicate packets!
At first I assumed that the packets were lingering in the fifo buffer. The documentation is clear about when packets are removed from the tx_buffer of the PTX device, but it is somewhat vague about when packets get removed from the tx_fifo on the PRX. That doesn't seem to be the issue though - if it were, then nrf_pop_tx() would not return NRF_ERROR_BUFFER_EMPTY.
Is this a common problem? Should I have to call nrf_esb_flush_tx() in my NRF_ESB_EVENT_TX_SUCCESS handler? It seems like a very bad idea - If multiple tx packets get loaded before the PRX receives an incoming message to attach them to, then all but one will be lost. Is it common to address this problem on the PTX side somehow? Am I doing something else wrong?
Both of the devices I used for this test were nrf52 dev boards. I am using sdk version 15.2.0.
Here is my PRX setup
nrf_esb_config_t nrf_esb_config 	= NRF_ESB_DEFAULT_CONFIG;
nrf_esb_config.protocol 			= NRF_ESB_PROTOCOL_ESB_DPL;
nrf_esb_config.retransmit_delay 	= 1000;
nrf_esb_config.retransmit_count 	= 0; // not sure what this even means on PRX
nrf_esb_config.bitrate 				= NRF_ESB_BITRATE_2MBPS;
nrf_esb_config.event_handler 		= nrf_esb_event_handler;
nrf_esb_config.mode 				= NRF_ESB_MODE_PRX;
nrf_esb_config.selective_auto_ack	= false;
nrf_esb_config.payload_length       = 4;
nrf_esb_config.tx_output_power      = RADIO_TXPOWER_TXPOWER_Pos4dBm;
err_code = nrf_esb_init(&nrf_esb_config);
VERIFY_SUCCESS(err_code);
err_code = nrf_esb_set_base_address_0(base_addr_0);
err_code = nrf_esb_set_base_address_1(base_addr_1);
err_code = nrf_esb_set_prefixes(addr_prefix, 8);
err_code = nrf_esb_set_rf_channel(s_data_channel);
err_code = nrf_esb_start_rx();
and here is my PTX setup
nrf_esb_config.retransmit_delay			= 600;
nrf_esb_config.retransmit_count         = 2;
nrf_esb_config.mode                     = NRF_ESB_MODE_PTX;
//    nrf_esb_config.payload_length			= 30;
This is the function I use to send ack packets from the PRX to the PTX
void esb_send_ack_packet(uint8_t pipe, uint8_t * ackpack, uint8_t nbytes)
	//tx_payload.noack = false;
	nrf_esb_payload_t tx_payload = {0};
	memcpy(tx_payload.data, ackpack, nbytes);
	tx_payload.length = nbytes;
	tx_payload.pipe = pipe;
	uint32_t err_code = nrf_esb_write_payload(&tx_payload);
	if (err_code == NRF_SUCCESS) {
		NRF_LOG_INFO("SENDING ACK PACK to pipe %d - %d %d %d %d", pipe, ackpack[0], ackpack[1], ackpack[2], ackpack[3]);
	else if (err_code == NRF_ERROR_NO_MEM) {
		nrf_esb_flush_tx();
		NRF_LOG_INFO("esb buff full - flushing");
	}else {
		NRF_LOG_INFO("Sending packet failed\r\n");
If any else would be useful, let me know
