I have a question about the problem of merging pwm with ble_app_uart.
Hello, everyone.
I learned about Bluetooth communication through the example of ble_app_uart. I learned about Bluetooth communication through the example of bl_app_uart. And I used the pwm_library to use the buzzer.  There is no problem using the buzzer in the pwm_library. And we merged this into bl_app_uart. However, the buzzer operates in this code, but the BLE does not.
The following is a section on the PWM in the main().
#define buzzer_pin  25
APP_PWM_INSTANCE(PWM1,1);                   // Create the instance "PWM1" using TIMER1.
static volatile bool ready_flag;            // A flag indicating PWM status.
void pwm_ready_callback(uint32_t pwm_id)    // PWM callback function
    ready_flag = true;
int main()
    //PWM setting
    ret_code_t err_code;`
    app_pwm_config_t pwm1_cfg = APP_PWM_DEFAULT_CONFIG_1CH(1500, buzzer_pin); //period_in_us(sound), pin
    /* Switch the polarity of the second channel. */
    pwm1_cfg.pin_polarity[1] = APP_PWM_POLARITY_ACTIVE_HIGH;
    /* Initialize and enable PWM. */
    err_code = app_pwm_init(&PWM1,&pwm1_cfg,pwm_ready_callback);
    for(;;)
       //PWM
       ready_flag = false;
       //wait for callback
       while (app_pwm_channel_duty_set(&PWM1, 0, 10) == NRF_ERROR_BUSY); //p_instance, channel, duty cycle(%)
       app_pwm_enable(&PWM1); //start pwm
Can I get a solution to this problem?
Thank you.
