BME680 Erro reading data
Hello everyone,
I have problem with a code for reading BME680. Here is my code the values display are wrong and never change.
Thank you for your time. I used this Library : github.com/.../BME680_driver the problem should be in the user_read or user_write but I Don't fine anything.
 * Copyright (c) 2016 - 2019, Nordic Semiconductor ASA
 * All rights reserved.
 *    list of conditions and the following disclaimer.
 *    Semiconductor ASA integrated circuit in a product or a software update for
 *    such product, must reproduce the above copyright notice, this list of
 *    conditions and the following disclaimer in the documentation and/or other
 *    materials provided with the distribution.
 *    contributors may be used to endorse or promote products derived from this
 *    software without specific prior written permission.
 *    Nordic Semiconductor ASA integrated circuit.
 *    engineered, decompiled, modified and/or disassembled.
/** @file
 * @defgroup tw_scanner main.c
 * @ingroup nrf_twi_example
 * @brief TWI Sensor Example main file.
 * This file contains the source code for a sample application using TWI.
#include <stdio.h>
#include "boards.h"
#include "app_error.h"
#include "nrf_drv_twi.h"
#include "nrf_delay.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#include "bme680.h"
struct bme680_dev gas_sensor;
int8_t rslt = BME680_OK;
/* TWI instance ID. */
#if TWI0_ENABLED
#define TWI_INSTANCE_ID     0
#elif TWI1_ENABLED
#define TWI_INSTANCE_ID     1
int compteur = 0;
/* TWI instance. */
static const nrf_drv_twi_t m_twi = NRF_DRV_TWI_INSTANCE(TWI_INSTANCE_ID);
int8_t user_i2c_read (uint8_t dev_id, uint8_t reg_addr, uint8_t *data, uint16_t len)
  ret_code_t err;
  uint8_t tampon[30]={0};
  NRF_LOG_INFO("read : reg addr : %d",reg_addr);
  NRF_LOG_FLUSH();
  int size=0, result = 0, j=0;
  uint8_t reg[1]={reg_addr};
  nrf_drv_twi_tx(&m_twi, dev_id, reg, 1,false);
  err = nrf_drv_twi_rx(&m_twi, dev_id, tampon, len);
  NRF_LOG_INFO("read : len %d :",len);
  NRF_LOG_FLUSH();
  if(err==0)
   {size=1;
 for(int i = 0 ;i<30;i++)
    if(tampon[i]!=0) size=i+1;
   size=0;
//       NRF_LOG_INFO("len %d",len);
//    NRF_LOG_FLUSH();
//    NRF_LOG_INFO("size %d",size);
//    NRF_LOG_FLUSH();
if(size ==15  ) size=len;
NRF_LOG_INFO("read : wire.available %d :",size);
  NRF_LOG_FLUSH();
  if(len<=size)
    { for (int i=0;i<len;i++)
      data[i]=tampon[i];
      NRF_LOG_INFO("%d",data[i]);
      NRF_LOG_FLUSH();
   {result=5;}
return result;
 * Write the content into the register targeted register for a specified device
 * Parameter :
 *    dev_id : the I2C adress of the device
 *    reg_addr : the adresse of the targeted register
 *    *data : pointer to the data to write
 *    len : number in byte of the data
 * Return:  Error code
int8_t user_i2c_write (uint8_t dev_id, uint8_t reg_addr, uint8_t *data, uint16_t len)
  int result=0;
  NRF_LOG_INFO("write reg : %d",reg_addr);
  uint8_t reg[]={reg_addr,*data};
  nrf_drv_twi_tx(&m_twi, dev_id, reg, len+1, false);
  for(int i = 0;i<len;i++)
  NRF_LOG_FLUSH();
  return result;
//  int result=0;
//  uint8_t reg[1]={reg_addr};
//  nrf_drv_twi_tx(&m_twi, dev_id, reg, 1, false);
//  for(int i=0;i<len;i++)
//  uint8_t reg0[1]={data[i]};
//  nrf_drv_twi_tx(&m_twi, dev_id, reg0, 1, false);
//  return result;
 * function to wait the time
 * Parameter :
 *    period : time that will be waited in millisecond
void user_delay_ms (uint32_t period)
  nrf_delay_ms(period);
 * @brief TWI initialization.
void twi_init (void)
    ret_code_t err_code;
    const nrf_drv_twi_config_t twi_config = {
       .scl                = ARDUINO_SCL_PIN ,
       .sda                = ARDUINO_SDA_PIN  ,
       .frequency          = NRF_DRV_TWI_FREQ_100K,
       .interrupt_priority = APP_IRQ_PRIORITY_HIGH,
       .clear_bus_init     = false
    err_code = nrf_drv_twi_init(&m_twi, &twi_config, NULL, NULL);
    nrf_drv_twi_enable(&m_twi);
 * @brief Function for initialising bme 680 in forced mode.
void init_bme (void)
    uint8_t set_required_settings;
    /* Set the temperature, pressure and humidity settings */
    gas_sensor.tph_sett.os_hum = BME680_OS_2X;
    gas_sensor.tph_sett.os_pres = BME680_OS_4X;
    gas_sensor.tph_sett.os_temp = BME680_OS_8X;
    gas_sensor.tph_sett.filter = BME680_FILTER_SIZE_3;
    /* Set the remaining gas sensor settings and link the heating profile */
    gas_sensor.gas_sett.run_gas = BME680_ENABLE_GAS_MEAS;
    /* Create a ramp heat waveform in 3 steps */
    gas_sensor.gas_sett.heatr_temp = 320; /* degree Celsius */
    gas_sensor.gas_sett.heatr_dur = 150; /* milliseconds */
    /* Select the power mode */
    /* Must be set before writing the sensor configuration */
    gas_sensor.power_mode = BME680_FORCED_MODE;
    /* Set the required sensor settings needed */
    set_required_settings = BME680_OST_SEL | BME680_OSP_SEL | BME680_OSH_SEL | BME680_FILTER_SEL
        | BME680_GAS_SENSOR_SEL;
    /* Set the desired sensor configuration */
    rslt = bme680_set_sensor_settings(set_required_settings,&gas_sensor);
    /* Set the power mode */
    rslt = bme680_set_sensor_mode(&gas_sensor);
    NRF_LOG_INFO("TWI scanner started.");
    NRF_LOG_FLUSH();
    twi_init();
    gas_sensor.dev_id = BME680_I2C_ADDR_SECONDARY;
    gas_sensor.intf = BME680_I2C_INTF;
    gas_sensor.read = user_i2c_read;
    gas_sensor.write = user_i2c_write;
    gas_sensor.delay_ms = user_delay_ms;
    gas_sensor.amb_temp = 25;
    rslt = bme680_init(&gas_sensor);
    init_bme();
    NRF_LOG_INFO("chip_id : %d :",gas_sensor.chip_id);
    NRF_LOG_FLUSH();
    NRF_LOG_INFO("Rslt : %d",rslt);
    NRF_LOG_FLUSH();
    if(rslt!=0)
    NRF_LOG_INFO("no BME680 detected");
    NRF_LOG_FLUSH();
    while(1);
    while (true)
//    uint8_t donnee[1] = {1};
//    uint8_t reado[1] = {0};
//    while(1){
//    NRF_LOG_INFO("READMAINMAINMAIN");
//    NRF_LOG_FLUSH();
//    user_i2c_write(gas_sensor.dev_id,0x72,donnee,sizeof(donnee));
//    user_i2c_read(gas_sensor.dev_id,0x72,reado,1);
//    NRF_LOG_INFO("DONNEE : %d",reado[0]);
//    NRF_LOG_FLUSH();
//    while(1);
        // put your main code here, to run repeatedly:
  uint16_t meas_period;
  bme680_get_profile_dur(&meas_period, &gas_sensor);
  struct bme680_field_data data;
    while(1){
  nrf_delay_ms(meas_period);
  rslt = bme680_get_sensor_data(&data, &gas_sensor);
  NRF_LOG_INFO("RSLT READ %d",rslt);
  NRF_LOG_FLUSH();
  NRF_LOG_INFO("STATUS");
  NRF_LOG_FLUSH();
  NRF_LOG_INFO("%d",data.temperature);
  NRF_LOG_FLUSH();
  NRF_LOG_ERROR( "Température :  " NRF_LOG_FLOAT_MARKER "\r\n", NRF_LOG_FLOAT(data.temperature /100.0));
  NRF_LOG_FLUSH();
  NRF_LOG_ERROR( "Pression :  " NRF_LOG_FLOAT_MARKER "\r\n", NRF_LOG_FLOAT(data.pressure));
  NRF_LOG_FLUSH();
  NRF_LOG_ERROR( "Humidity :  " NRF_LOG_FLOAT_MARKER "\r\n", NRF_LOG_FLOAT(data.humidity /1000.0));
  NRF_LOG_FLUSH();
  /* Avoid using measurements from an unstable heating setup */
  if (data.status & BME680_GASM_VALID_MSK)
    NRF_LOG_INFO("G: ");
    NRF_LOG_INFO("%d",data.gas_resistance);
    NRF_LOG_INFO("Kohms");
    NRF_LOG_FLUSH();
  /* Trigger the next measurement if you would like to read data out continuously */
  if (gas_sensor.power_mode == BME680_FORCED_MODE) {
uint8_t reg_data[1]={0};
uint8_t dat[1]={65};
uint8_t reg[1]={0x74};
bme680_get_regs(0x74, reg_data, 1, &gas_sensor);
NRF_LOG_INFO("registre 0x74 : %d",reg_data[0]);
NRF_LOG_FLUSH();
