Optimisation level in SES - nrf52832 + ICM20948
I am developing an  ESB application with 1 central (nrf52832 DK) and several peripheral.  The peripheral are nrf52832 + ICM 20948.  Development is done with Segger embedded studio (SES) .
I am using SDK16, the latest.
 Application on the peripheral is working correctly in debug mode, although power consumption is higher that  would like while CPU resting.
I have tried to compile the program in Release mode but I have ran in issues.
I have tried to understand the difference between Debug and Release mode
I have  found that the preprocessor definition have some difference.
for Debug mode :  "DEBUG; DEBUG_NRF" from solution in Debug configuration  ;     For Release mode :  "NDEBUG"
DEBUG or NDEBUG does not affect the program operation.
In Code generation section:  Optimisation level is set differently.
I ahve found out that  Optimisation level 0 work fine. This is the setting for DEBUG mode.
With Optimisation level 1 or 2,  the CPU does not communicate correctly with the ICM.
When I try to read the quaternions, I get some blank instead of numbers.   Power consumption is not improved.
Optimisation level 1 and specially 2 are supposed to make the program more efficient and consume less power.
Any Idea why it does not work with the ICM?
Sylvain
Parents Reply
  • Hi, I have found that the main culprit is the HFCLK used for the ESB.  I have to do more measurement and testing today.
    nrf_drv_clock_hfclk_release(); // does nothing
    NRF_CLOCK->TASKS_HFCLKSTOP = 1;  //  power consumption drop from 200µA to almost nothing, less than 40µA.  Its time to get my scope to get more precise data.
    Now the problem is that I don't know how to restart the clock.
    Calling the clocks_start routine does not do the trick.
    void clocks_start( void )
        while (NRF_CLOCK->EVENTS_HFCLKSTARTED == 0);
    Any suggestion ?
