I have added the include and src. file paths to the MAKEFILE and yet I am experiencing this error.
I tried deleting the main.c.o file too, but am still experiencing this issue.
Could you tell me some more about your development setup: Which IDE are you using, are you building with armgcc directly, or perhaps Segger Embedded Studios?
Could you also verify for me the path you have supplied, and how you have added it to the makefile?
In the case that you are using Segger Embedded Studios, could you detail for me how you have added the path to your project?
Looking forward to resolving this issue together,
Karl
Hello Karl, Thank you for your help.I am currently using nrf_power_system_off(); to put the nrf52840 dk to sleep.
Could you please help me with how to wake it up in normal mode? All I am getting are putting to sleep with soft device enabled or with low power mode. I am not using any of them. I am simply calling the functions and want to wake up the device using an interrupt(using if statement to read the gpio).
RJD said:Thank you for your help.
No problem at all, I am happy to help!
RJD said:I am currently using nrf_power_system_off(); to put the nrf52840 dk to sleep.
I would not recommend this. Please have a look at the nrf_power_system_off documentation.
RJD said:Could you please help me with how to wake it up in normal mode? All I am getting are putting to sleep with soft device enabled or with low power mode. I am not using any of them. I am simply calling the functions and want to wake up the device using an interrupt(using if statement to read the gpio).
What is your desired behavior here, I am not sure I understand. You would like the the device to be in SYSTEM OFF mode, and wake on a GPIO level change?
Be advised that the CPU is not running in SYSTEM OFF, so no code will be executed - i.e you may not check anything with an if statement.
I would recommend that you use the power management module instead of the power HAL.
You may see how this module is used in most of the SDK examples, for instance the BLE beacon example. They demonstrate how easy the power management module is to work with. When the device goes into low power mode here ( nrf_pwr_mgmt_run ) the device will be sleeping, but wake on interrupts.
Please do not hesitate to let me know if anything should be unclear, or if you encounter any issues or questions.
Karl
Hello Karl, Hope you are doing good.
I actually want my device to go to sleep when there is an inactivity and wake up on an interrupt from a sensor, take 20 readings and then go back to sleep and wake up again on an interrupt. I do not wnat to use soft devices
Also, here is the code snippet I am working on in accordance to the power management library:-
main(){
bsp_board_init(BSP_INIT_BUTTONS);
nrf_pwr_mgmt_run();
while (1)
NRF_LOG_INFO("MCU WAKE UP");
NRF_LOG_FLUSH();
for(int i=0;i<2;i++){
bsp_board_led_on(1);
nrf_delay_ms(500);
bsp_board_led_off(1);
nrf_delay_ms(1000);
//bsp_board_led_on(0);
NRF_LOG_INFO("THIS SHOULD BE DISPLAYED");
NRF_LOG_FLUSH();
bsp_wakeup_button_enable(1);
nrf_pwr_mgmt_shutdown(NRF_PWR_MGMT_SHUTDOWN_GOTO_SYSOFF);
//sd_power_system_off();
NRF_LOG_INFO("SHOULD NOT BE DISPLAYED");
NRF_LOG_FLUSH();
if(bsp_button_is_pressed(1)){
NVIC_SystemReset();
