Problem with setting two uart on pca10040 board
hello
I am reading the log by teraterm by connecting pca10040 board to PC via USB.
I am trying to connect 6pin and 8pin of the board to other devices through uart.
The example used ble_app_uart.
The problem occurs with NRF_BREAKPOINT_COND in uart init.
In my opinion, it seems to conflict with printf output to teraterm and 6,8 pin uart.
Is there a way to use two uarts separately?
//best regards
    Unfortunately no, the nRF52832 SoC only has 1 UART instance.
    I would think this error you are seeing is from trying to initialize the one instance twice.
    If you would like to verify this, please add DEBUG to your preprocessor defines as shown in the included picture, to see what error is being generated.
    What other devices are you trying to connect with? Perhaps the other devices support another serial interface?
    Karl
  • Thanks for your kind response.
    The device I am trying to connect is the IMU Module.
    I am trying to connect the uart pin (vcc,gnd,rx,tx) of the device with the PCA10040 board.
    The purpose is to send the value of the IMU Module to the PCA10040 board
    and then send the value back to the terminal of the PC via USB.
    Recompiled using the method you indicated.
    DEBUG Massage
    Is there any way to solve the problem?
    tobaro4
  • Hello Tobaro4,
    tobaro4 said:
    Thank you.
    No problem at all, I am happy to help!
    tobaro4 said:
    If it is sd_ble_enable, do you mean NRF_SDH_BLE_ENABLED in sdk_config.h?
    If so, it is active.
    If not, can you tell me which SoftDevice to set up?
    Sorry, but maybe I didn't understand your advice.
    I will try to be more specific. Please let me know if anything still should be unclear.
    In the unmodified ble_app_uart example the SoftDevice is enabled as part of the ble_stack_init function ( specifically during the nrf_sdh_enable_request ).
    Have you made any changes to this?
    Does your application start, or could you go into debugger mode to see if the application gets past this function call at all?
    If it does not, then there is a problem with the SoftDevice configuration or setup.
    tobaro4 said:
    I searched for the related error message:
    https://devzone.nordicsemi.com/f/nordic-q-a/37193/nrf_error_svc_handler_missing-of-uart
    There is something like this, but I still don't understand.
    This is a good find, and may apply to your situation if the debugging check I mentioned above does not produce anything. If your application is able to start, and begin communication before suddenly failing during uart transfer, then it might indeed be an overrun error.
    In that case, we will need to take a look at the buffer size you have specified, and how frequently they are processed and emptied.
    Karl
  • I know you're doing your best for me. Thanks for this.
    But I am completely newbie on this part. I'm using an unmodified example and I don't know how to fix it.
    Should I call the ble_stack_init() function before the uart_init() function? I really don't understand. I'm really sorry.
    If the IMU device is connected to the rx pin, the program will not run. If you don't connect the rx pin, the program will run. However, if I connect the rx pin while the program is running, it dies quickly. It seems to die reading about 147 bytes. How to process or empty the buffer size?
    tobaro4
    It is truly no problem at all, do not worry :)
    Lets take it from the start instead. Have you tried running an unmodified version of the example? I.e, does the example work as intended when you program your device with an unmodified version?
    The unmodified Nordic UART peripheral example should behave as described in its documentation.
    When we have confirmed that this is working as intended, then we may move on to modifying the example to suit the needs of your application.
    This is very interesting. Could you elaborate what you mean when you say that the program dies, or what happens if it does not start at all?
    Perhaps this is caused by the buffers being overrun.
    Is it an option to use flow control on the UART communication to the IMU?
    Or, could you share the parts of the code in which you empty / process the contents of the RX buffer?
    Looking forward to resolving this issue together!
    Karl
  • ok
    Thanks to you, I am encouraged.
    When I say that the program dies, it dies with NRF_BREAKPOINT_COND as in the screenshot I posted above.
    When looking at the IMU's menual, it seems that flow control is not used.
    Attach the c file of the program I modified.
     * Copyright (c) 2016 - 2020, Nordic Semiconductor ASA
     * All rights reserved.
    #include <stdio.h>
    #include <stdint.h>
    #include <stdbool.h>
    #include "nordic_common.h"
    #include "app_error.h"
    #include "app_uart.h"
    #include "ble_db_discovery.h"
    #include "app_timer.h"
    #include "app_util.h"
    #include "bsp_btn_ble.h"
    #include "ble.h"
    #include "ble_gap.h"
    #include "ble_hci.h"
    #include "nrf_sdh.h"
    #include "nrf_sdh_ble.h"
    #include "nrf_sdh_soc.h"
    #include "ble_nus_c.h"
    #include "nrf_ble_gatt.h"
    #include "nrf_pwr_mgmt.h"
    #include "nrf_ble_scan.h"
    #include "nrf_log.h"
    #include "nrf_log_ctrl.h"
    #define APP_BLE_CONN_CFG_TAG    1                                       /**< Tag that refers to the BLE stack configuration set with @ref sd_ble_cfg_set. The default tag is @ref BLE_CONN_CFG_TAG_DEFAULT. */
    #define APP_BLE_OBSERVER_PRIO   3                                       /**< BLE observer priority of the application. There is no need to modify this value. */
    #define UART_TX_BUF_SIZE        256                                     /**< UART TX buffer size. */
    #define UART_RX_BUF_SIZE        256                                     /**< UART RX buffer size. */
    #define NUS_SERVICE_UUID_TYPE   BLE_UUID_TYPE_VENDOR_BEGIN              /**< UUID type for the Nordic UART Service (vendor specific). */
    #define ECHOBACK_BLE_UART_DATA  1                                       /**< Echo the UART data that is received over the Nordic UART Service (NUS) back to the sender. */
    BLE_NUS_C_DEF(m_ble_nus_c);                                             /**< BLE Nordic UART Service (NUS) client instance. */
    NRF_BLE_GATT_DEF(m_gatt);                                               /**< GATT module instance. */
    BLE_DB_DISCOVERY_DEF(m_db_disc);                                        /**< Database discovery module instance. */
    NRF_BLE_SCAN_DEF(m_scan);                                               /**< Scanning Module instance. */
    NRF_BLE_GQ_DEF(m_ble_gatt_queue,                                        /**< BLE GATT Queue instance. */
                   NRF_SDH_BLE_CENTRAL_LINK_COUNT,
                   NRF_BLE_GQ_QUEUE_SIZE);
    static uint16_t m_ble_nus_max_data_len = BLE_GATT_ATT_MTU_DEFAULT - OPCODE_LENGTH - HANDLE_LENGTH; /**< Maximum length of data (in bytes) that can be transmitted to the peer by the Nordic UART service module. */
    /**@brief NUS UUID. */
    static ble_uuid_t const m_nus_uuid =
        .uuid = BLE_UUID_NUS_SERVICE,
        .type = NUS_SERVICE_UUID_TYPE
    ////////////tobaro4
    static uint32_t m_button_number = 0;
    static uint32_t m_beacon_number = 0;
    static uint32_t m_rx_done_flag = 0;
    static int m_beacon_rssi[4] = {0,};
    /**@brief Function for handling asserts in the SoftDevice.
     * @details This function is called in case of an assert in the SoftDevice.
     * @warning This handler is only an example and is not meant for the final product. You need to analyze
     *          how your product is supposed to react in case of assert.
     * @param[in] line_num     Line number of the failing assert call.
     * @param[in] p_file_name  File name of the failing assert call.
        app_error_handler(0xDEADBEEF, line_num, p_file_name);
    /**@brief Function for handling the Nordic UART Service Client errors.
    static void nus_error_handler(uint32_t nrf_error)
        APP_ERROR_HANDLER(nrf_error);
    /**@brief Function to start scanning. */
    static void scan_start(void)
        ret_code_t ret;
        ret = nrf_ble_scan_start(&m_scan);
        APP_ERROR_CHECK(ret);
        ret = bsp_indication_set(BSP_INDICATE_SCANNING);
    /**@brief Function for handling Scanning Module events.
    static void scan_evt_handler(scan_evt_t const * p_scan_evt)
        ret_code_t err_code;
        switch(p_scan_evt->scan_evt_id)
             case NRF_BLE_SCAN_EVT_CONNECTING_ERROR:
                  err_code = p_scan_evt->params.connecting_err.err_code;
             } break;
             case NRF_BLE_SCAN_EVT_CONNECTED:
                  ble_gap_evt_connected_t const * p_connected =
                                   p_scan_evt->params.connected.p_connected;
                 // Scan is automatically stopped by the connection.
                 NRF_LOG_INFO("Connecting to target %02x%02x%02x%02x%02x%02x",
                          p_connected->peer_addr.addr[0],
                          p_connected->peer_addr.addr[1],
                          p_connected->peer_addr.addr[2],
                          p_connected->peer_addr.addr[3],
                          p_connected->peer_addr.addr[4],
                          p_connected->peer_addr.addr[5]
             } break;
             case NRF_BLE_SCAN_EVT_SCAN_TIMEOUT:
                 NRF_LOG_INFO("Scan timed out.");
                 scan_start();
             } break;
    		 case NRF_BLE_SCAN_EVT_NOT_FOUND:
    			ble_gap_evt_adv_report_t const * p_adv_report =
                                   p_scan_evt->params.p_not_found;
        	 	//NRF_LOG_INFO("[SCAN][data:%02x%02x%02x%02x%02x%02x][mac:%02x%02x%02x]",
        	 	if((p_adv_report->data.p_data != NULL) && (p_adv_report->data.len != 0))
        	 #if 1
        	 		if((p_adv_report->data.p_data[5] == 0x59) && (p_adv_report->data.p_data[6] == 0x00) &&
    					(p_adv_report->data.p_data[7] == 0x02) && (p_adv_report->data.p_data[8] == 0x15) &&
    					(p_adv_report->data.p_data[25] == 0xAB) && (p_adv_report->data.p_data[26] == 0xCD) &&
    					(p_adv_report->data.p_data[27] == 0xEF))
        	 			if((p_adv_report->data.p_data[28] & 0x0F) == 1)
        	 				m_beacon_rssi[0] = p_adv_report->rssi;
    					else if((p_adv_report->data.p_data[28] & 0x0F) == 2)
        	 				m_beacon_rssi[1] = p_adv_report->rssi;
    					else if((p_adv_report->data.p_data[28] & 0x0F) == 3)
        	 				m_beacon_rssi[2] = p_adv_report->rssi;
    					else if((p_adv_report->data.p_data[28] & 0x0F) == 4)
        	 				m_beacon_rssi[3] = p_adv_report->rssi;
        	 #else
        	 		switch(m_button_number)
        	 			case 1:
        	 			printf("[SCANDATA][NAME(%d):", p_adv_report->data.len);
    					for(int i = 0; i < p_adv_report->data.len; i++)
    						printf("%02x", p_adv_report->data.p_data[i]);
    					printf("][MACADR:%02x%02x%02x%02x%02x%02x \r\n",
    						p_adv_report->peer_addr.addr[5],
    						p_adv_report->peer_addr.addr[4],
    						p_adv_report->peer_addr.addr[3],
    						p_adv_report->peer_addr.addr[2],
    						p_adv_report->peer_addr.addr[1],
    						p_adv_report->peer_addr.addr[0]);
    					case 2:
    							printf("][MACADR:%02x%02x%02x%02x%02x%02x][RSSI:%d] \r\n",
    								p_adv_report->peer_addr.addr[0],
    								p_adv_report->rssi);
    					case 3:
        	 					if((p_adv_report->data.p_data[28] & 0x0F) == m_beacon_number)
    					case 4:
    		 } break;
    /**@brief Function for initializing the scanning and setting the filters.
    static void scan_init(void)
        nrf_ble_scan_init_t init_scan;
        memset(&init_scan, 0, sizeof(init_scan));
        init_scan.connect_if_match = true;
        init_scan.conn_cfg_tag     = APP_BLE_CONN_CFG_TAG;
        err_code = nrf_ble_scan_init(&m_scan, &init_scan, scan_evt_handler);
        //err_code = nrf_ble_scan_filter_set(&m_scan, SCAN_UUID_FILTER, &m_nus_uuid);
        //APP_ERROR_CHECK(err_code);
        //err_code = nrf_ble_scan_filters_enable(&m_scan, NRF_BLE_SCAN_UUID_FILTER, false);
    /**@brief Function for handling database discovery events.
     * @details This function is a callback function to handle events from the database discovery module.
     *          Depending on the UUIDs that are discovered, this function forwards the events
     *          to their respective services.
     * @param[in] p_event  Pointer to the database discovery event.
    static void db_disc_handler(ble_db_discovery_evt_t * p_evt)
        ble_nus_c_on_db_disc_evt(&m_ble_nus_c, p_evt);
    /**@brief Function for handling characters received by the Nordic UART Service (NUS).
     * @details This function takes a list of characters of length data_len and prints the characters out on UART.
     *          If @ref ECHOBACK_BLE_UART_DATA is set, the data is sent back to sender.
    static void ble_nus_chars_received_uart_print(uint8_t * p_data, uint16_t data_len)
        ret_code_t ret_val;
        NRF_LOG_DEBUG("Receiving data.");
        NRF_LOG_HEXDUMP_DEBUG(p_data, data_len);
        for (uint32_t i = 0; i < data_len; i++)
            do
                ret_val = app_uart_put(p_data[i]);
                if ((ret_val != NRF_SUCCESS) && (ret_val != NRF_ERROR_BUSY))
                    NRF_LOG_ERROR("app_uart_put failed for index 0x%04x.", i);
                    APP_ERROR_CHECK(ret_val);
            } while (ret_val == NRF_ERROR_BUSY);
        if (p_data[data_len-1] == '\r')
            while (app_uart_put('\n') == NRF_ERROR_BUSY);
        if (ECHOBACK_BLE_UART_DATA)
            // Send data back to the peripheral.
            do
                ret_val = ble_nus_c_string_send(&m_ble_nus_c, p_data, data_len);
                    NRF_LOG_ERROR("Failed sending NUS message. Error 0x%x. ", ret_val);
     * @details This function receives a single character from the app_uart module and appends it to
     *          a string. The string is sent over BLE when the last character received is a
     *          'new line' '\n' (hex 0x0A) or if the string reaches the maximum data length.
        static uint16_t index = 0;
        uint32_t ret_val;
    	//char data_copy[256] = {0,};
    	//int idx = 0;
        switch (p_event->evt_type)
            /**@snippet [Handling data from UART] */
            case APP_UART_DATA_READY:
    			if(data_array[index] == '*')
                	printf("1,%d, 2,%d 3,%d 4,%d %c,", m_beacon_rssi[0], m_beacon_rssi[1], m_beacon_rssi[2], m_beacon_rssi[3], data_array[index]);
                	//idx == 0;
    				//m_rx_done_flag = 1;
    				//printf("%c,", data_array[index]);
    				printf("%c", data_array[index]);
    			//data_copy[idx++] = data_array[index];
    			index++;
                if ((data_array[index - 1] == '\n') ||
                    (data_array[index - 1] == '\r') ||
                    (index >= (m_ble_nus_max_data_len)))
    				//else
                   		do
                        	ret_val = ble_nus_c_string_send(&m_ble_nus_c, data_array, index);
                        	if ( (ret_val != NRF_ERROR_INVALID_STATE) && (ret_val != NRF_ERROR_RESOURCES) )
                    	} while (ret_val == NRF_ERROR_RESOURCES);
                    	index = 0;
                NRF_LOG_ERROR("Communication error occurred while handling UART.");
            case APP_UART_FIFO_ERROR:
                NRF_LOG_ERROR("Error occurred in FIFO module used by UART.");
    /**@brief Callback handling Nordic UART Service (NUS) client events.
     * @details This function is called to notify the application of NUS client events.
     * @param[in]   p_ble_nus_c   NUS client handle. This identifies the NUS client.
     * @param[in]   p_ble_nus_evt Pointer to the NUS client event.
    /**@snippet [Handling events from the ble_nus_c module] */
    static void ble_nus_c_evt_handler(ble_nus_c_t * p_ble_nus_c, ble_nus_c_evt_t const * p_ble_nus_evt)
        switch (p_ble_nus_evt->evt_type)
            case BLE_NUS_C_EVT_DISCOVERY_COMPLETE:
                NRF_LOG_INFO("Discovery complete.");
                err_code = ble_nus_c_handles_assign(p_ble_nus_c, p_ble_nus_evt->conn_handle, &p_ble_nus_evt->handles);
                err_code = ble_nus_c_tx_notif_enable(p_ble_nus_c);
                NRF_LOG_INFO("Connected to device with Nordic UART Service.");
            case BLE_NUS_C_EVT_NUS_TX_EVT:
                ble_nus_chars_received_uart_print(p_ble_nus_evt->p_data, p_ble_nus_evt->data_len);
            case BLE_NUS_C_EVT_DISCONNECTED:
                NRF_LOG_INFO("Disconnected.");
                scan_start();
     * @brief Function for handling shutdown events.
     * @param[in]   event       Shutdown type.
    static bool shutdown_handler(nrf_pwr_mgmt_evt_t event)
        switch (event)
            case NRF_PWR_MGMT_EVT_PREPARE_WAKEUP:
                // Prepare wakeup buttons.
        return true;
    NRF_PWR_MGMT_HANDLER_REGISTER(shutdown_handler, APP_SHUTDOWN_HANDLER_PRIORITY);
        ble_gap_evt_t const * p_gap_evt = &p_ble_evt->evt.gap_evt;
            case BLE_GAP_EVT_CONNECTED:
                err_code = ble_nus_c_handles_assign(&m_ble_nus_c, p_ble_evt->evt.gap_evt.conn_handle, NULL);
                // start discovery of services. The NUS Client waits for a discovery result
                err_code = ble_db_discovery_start(&m_db_disc, p_ble_evt->evt.gap_evt.conn_handle);
                NRF_LOG_INFO("Disconnected. conn_handle: 0x%x, reason: 0x%x",
                             p_gap_evt->conn_handle,
                             p_gap_evt->params.disconnected.reason);
            case BLE_GAP_EVT_TIMEOUT:
                if (p_gap_evt->params.timeout.src == BLE_GAP_TIMEOUT_SRC_CONN)
                    NRF_LOG_INFO("Connection Request timed out.");
                // Pairing not supported.
                err_code = sd_ble_gap_sec_params_reply(p_ble_evt->evt.gap_evt.conn_handle, BLE_GAP_SEC_STATUS_PAIRING_NOT_SUPP, NULL, NULL);
            case BLE_GAP_EVT_CONN_PARAM_UPDATE_REQUEST:
                // Accepting parameters requested by peer.
                err_code = sd_ble_gap_conn_param_update(p_gap_evt->conn_handle,
                                                        &p_gap_evt->params.conn_param_update_request.conn_params);
                ble_gap_phys_t const phys =
                    .rx_phys = BLE_GAP_PHY_AUTO,
                    .tx_phys = BLE_GAP_PHY_AUTO,
            } break;
            case BLE_GATTC_EVT_TIMEOUT:
            case BLE_GATTS_EVT_TIMEOUT:
        uint32_t ram_start = 0;
        // Enable BLE stack.
    /**@brief Function for handling events from the GATT library. */
    void gatt_evt_handler(nrf_ble_gatt_t * p_gatt, nrf_ble_gatt_evt_t const * p_evt)
        if (p_evt->evt_id == NRF_BLE_GATT_EVT_ATT_MTU_UPDATED)
            NRF_LOG_INFO("ATT MTU exchange completed.");
            m_ble_nus_max_data_len = p_evt->params.att_mtu_effective - OPCODE_LENGTH - HANDLE_LENGTH;
            NRF_LOG_INFO("Ble NUS max data length set to 0x%X(%d)", m_ble_nus_max_data_len, m_ble_nus_max_data_len);
    /**@brief Function for initializing the GATT library. */
    void gatt_init(void)
        err_code = nrf_ble_gatt_init(&m_gatt, gatt_evt_handler);
        err_code = nrf_ble_gatt_att_mtu_central_set(&m_gatt, NRF_SDH_BLE_GATT_MAX_MTU_SIZE);
     * @param[in] event  Event generated by button press.
        switch (event)
        	case BSP_EVENT_KEY_0:
    			m_button_number = 1;
    			//printf("[BTNPUSH] Push Button Number 1!!! \r\n");
    		case BSP_EVENT_KEY_1:
    			m_button_number = 2;
    			//printf("[BTNPUSH] Push Button Number 2!!! \r\n");
    		case BSP_EVENT_KEY_2:
    			m_button_number = 3;
    			m_beacon_number++;
    			if(m_beacon_number > 4)
    				m_beacon_number = 1;
    			//printf("[BTNPUSH] Push Button Number 3!!!, beacon number %d \r\n", m_beacon_number);
    		case BSP_EVENT_KEY_3:
    			m_button_number = 4;
    			//printf("[BTNPUSH] Push Button Number 4!!! \r\n");
            case BSP_EVENT_SLEEP:
                nrf_pwr_mgmt_shutdown(NRF_PWR_MGMT_SHUTDOWN_GOTO_SYSOFF);
            case BSP_EVENT_DISCONNECT:
                err_code = sd_ble_gap_disconnect(m_ble_nus_c.conn_handle,
    /**@brief Function for initializing the UART. */
    static void uart_init(void)
            .rx_pin_no    = RX_PIN_NUMBER,
            .tx_pin_no    = TX_PIN_NUMBER,
            .flow_control = APP_UART_FLOW_CONTROL_ENABLED,
            .use_parity   = false,
            .baud_rate    = UART_BAUDRATE_BAUDRATE_Baud115200
                           UART_RX_BUF_SIZE,
                           UART_TX_BUF_SIZE,
                           uart_event_handle,
                           APP_IRQ_PRIORITY_LOWEST,
                           err_code);
    /**@brief Function for initializing the Nordic UART Service (NUS) client. */
    static void nus_c_init(void)
        ble_nus_c_init_t init;
        init.evt_handler   = ble_nus_c_evt_handler;
        init.error_handler = nus_error_handler;
        init.p_gatt_queue  = &m_ble_gatt_queue;
        err_code = ble_nus_c_init(&m_ble_nus_c, &init);
    /**@brief Function for initializing buttons and leds. */
    static void buttons_leds_init(void)
        bsp_event_t startup_event;
        err_code = bsp_init(BSP_INIT_LEDS, bsp_event_handler);
    	err_code = bsp_init(BSP_INIT_BUTTONS, bsp_event_handler);
    /**@brief Function for initializing the timer. */
    static void timer_init(void)
    /**@brief Function for initializing the nrf log module. */
    static void log_init(void)
    /** @brief Function for initializing the database discovery module. */
    static void db_discovery_init(void)
        ble_db_discovery_init_t db_init;
        memset(&db_init, 0, sizeof(ble_db_discovery_init_t));
        db_init.evt_handler  = db_disc_handler;
        db_init.p_gatt_queue = &m_ble_gatt_queue;
        ret_code_t err_code = ble_db_discovery_init(&db_init);
     * @details Handles any pending log operations, then sleeps until the next event occurs.
            nrf_pwr_mgmt_run();
        // Initialize.
        log_init();
        timer_init();
        uart_init();
        buttons_leds_init();
        db_discovery_init();
        power_management_init();
        ble_stack_init();
        gatt_init();
        nus_c_init();
        scan_init();
        // Start execution.
        printf("BLE UART central example started.\r\n");
        NRF_LOG_INFO("BLE UART central example started.");
        scan_start();
        // Enter main loop.
        for (;;)
            idle_state_handle();
    		//if(m_rx_done_flag == 1)
    		//	printf("rx ok! \r\n");
    		//	m_rx_done_flag = 0;
    Even if it doesn't solve the problem, I'll try to find another way.
    Thank you again.
    tobaro4
  • Hello Tobaro4,
    I am happy to hear that!
    I understand. Do you get the exact same error generated, as in the screenshot you shared earlier?
    In that case, I would think it is an overrun error, i.e a start bit is received while the previous data is still in the RXD buffer.
    Do you have access to a logic analyzer? That would make this very easy to confirm.
    When reading your main.c file I am not entirely sure what the intentions of some of your commented out code is.
    Could you walk me through the changes you have made to the uart_event_handler - what is the purpose and goal of these changes?
    Karl
  • Hello Tobaro4,
    Karl
