Zigbee electrical measurement cluster - sending data
I'm trying to send some payload via ELECTRICAL_MEASUREMENT cluster.
The sending is realized in the similar way to the zigbee_light_switch example.
I'm sending data to the broadcast addr:
    zb_uint16_t addr = 0xFFFF;
    uint16_t measured_val = 0xABCD;
    NRF_LOG_INFO("Send el measurement command");
    ZB_CUSTOM_EL_MEASUREMENT_SEND_REQ(bufid,
                           addr,
                           ZB_APS_ADDR_MODE_16_ENDP_PRESENT,
                           HA_SMART_PLUG_ENDPOINT, //todo
                           ZB_AF_HA_PROFILE_ID,
                           ZB_ZCL_DISABLE_DEFAULT_RESPONSE,
                           NULL,
                           measured_val);
Where the macro is:
#define ZB_CUSTOM_EL_MEASUREMENT_SEND_REQ(        \
    buffer, addr, dst_addr_mode, dst_ep, ep, prof_id, def_resp, cb, measured_val)                                                             \
  zb_uint8_t* ptr = ZB_ZCL_START_PACKET_REQ(buffer)        \
  ZB_ZCL_CONSTRUCT_SPECIFIC_COMMAND_REQ_FRAME_CONTROL(ptr, def_resp)        \
  ZB_ZCL_CONSTRUCT_COMMAND_HEADER_REQ(ptr, ZB_ZCL_GET_SEQ_NUM(), ZB_ZCL_CMD_ELECTRICAL_MEASUREMENT_GET_MEASUREMENT_PROFILE_RESPONSE_COMMAND); \
  ZB_ZCL_PACKET_PUT_DATA16_VAL(ptr, (measured_val));        \
  ZB_ZCL_FINISH_PACKET(buffer, ptr)        \
  ZB_ZCL_SEND_COMMAND_SHORT(        \
      buffer, addr, dst_addr_mode, dst_ep, ep, prof_id, ZB_ZCL_CLUSTER_ID_ELECTRICAL_MEASUREMENT, cb);                                        \
After that I'm trying to find those data in the sniffer.
Cluster ID is correct, Cmd ID is also correct and the measured_val (0xABCD) is visible.
Unfortunatelly the packet seems to be malformed. Any idea what am I doing wrong and how to fix it ?
BR,
Jakub
  • Hello again,
    I've tried the cli example but I occured some problems.
    Let me describe the whole procedure:
    1. Update <proj_dir>/nrf-thread-sdk/examples/zigbee/light_control/light_bulb/main.c with function to read device address just after 'zb_set_long_address(ieee_addr);' call:
    zb_get_long_address(buf);
    for(int i = 0 ; i < 8; i++)
        NRF_LOG_INFO("MY ADDR: %X", buf[i]);
    2. Connect first nRF52-DK (A) make and flash it with <proj_dir>/nrf-thread-sdk/examples/zigbee/light_control/light_bulb/ hex file
    3. Connect second nRF52-DK (B) and flash it with cli example
    4. Open <proj_dir>/testing/zigbee_cli/config.yaml and update COM port (B) and eui64 with addr from 1.
    5. Run mqtt broker (mosquitto.exe)
    6. Run python3 cli.py
    7.  'Client started' occurs in the cli.py output and LED3 on (B) lights up.
    8. Type 'mosquitto_pub -t home/light2/on_off/state -m 0'.
    9.  Notice that logs in the cli.py terminal occured:
        cli.py: INFO: Message - Topic: home/light2/on_off/state ,Payload: b'0'
        cli.py: INFO: CLI cmd send : EUI64=F4CE36CC34102197 EP=10 CLUSTER=0006 CMD=0000 RESP=True PAYLOAD=None
    PROBLEMS:
    - The LED on (A) - light bulb does not change its state
    - The sniffer doesn't see any Zigbee traffic on channel 16
    I suppose that there is still something i do wrong.
    BR,
    Jakub
    I am a bit confused by your post. There is no Zigbee CLI example currently released for NCS so I am not sure where did you find this CLI example? Tomchy linked to the CLI example from the nRF5 SDK for Thread&Zigbee v4.1.0. I recommend you use this one since the example is still not available on NCS. It is possible to run the CLI example from the nRF5 SDK and run the light bulb on NCS and have both on the same network.
