Mqtt simple nrf9160, send JSON as utf-8
I have configured the MQTT simple sample from nordic to send data to our broker, this works just fine at the moment.
I would like to send Json formated data to the broker ----->
"sensor_id": "c5278fbf-c6d5-4c48-b51d-652beb609b34",
"value": 13.0
When I subscribe to topic, I only see "{" as incoming data.
How can I make sure that the Json data is correctly formated i code ?
Any assistance would be appreciated.
I am using the <cJSON.h> library.
char field_name[80], value[80], *out;
                cJSON *root,*car;
                //char str1[80] = "{'sensor_id:' 'c5278fbf-c6d5-4c48-b51d-652beb609b34','value:' 13.0}";
                root  = cJSON_CreateObject();
                car=  cJSON_CreateArray();
                cJSON_AddItemToObject(root, "sensor_id", cJSON_CreateString("c5278fbf-c6d5-4c48-b51d-652beb609b34"));
                cJSON_AddItemToObject(root, "value", cJSON_CreateString("12"));
                cJSON_AddItemToArray(car, root);
                out = cJSON_Print(root);
                printk(out);
                //char out1 = {"sensor_id"":""c5278fbf-c6d5-4c48-b51d-652beb609b34","value"":""13.0"};
                k_sleep(K_MSEC(5000));
                data_publish(&client, MQTT_QOS_1_AT_LEAST_ONCE, car, sizeof(car));
David
  • Hello, David!
    I managed to publish and receive jSON data using the following code:
    static void transmit() {
       char *out;
       char *id1 = "c5278fbf-c6d5-4c48-b51d-652beb609b34";
       char *id2 = "c5278fgf-c6d5-4c48-b51d-652beb6s9b34";
       char *value1 = "13.0";
       char *value2 = "117.0";
       cJSON *root, *sensors, *sensor;
       /* create root node and array */
       sensors = cJSON_CreateArray();
       /* add sensors array to root */
       cJSON_AddItemToObject(root, "sensors", sensors);
       /* add 1st sensor to sensors array */
       cJSON_AddItemToArray(sensors, sensor = cJSON_CreateObject());
       cJSON_AddItemToObject(sensor, "value", cJSON_CreateString(value1));
       cJSON_AddItemToObject(sensor, "sensor_id", cJSON_CreateString(id1));
       cJSON_AddItemToObject(sensor, "value", cJSON_CreateString(value2));
       cJSON_AddItemToObject(sensor, "sensor_id", cJSON_CreateString(id2));
       /* print everything */
       printk("%s\n", out);
       /* Publish with MQTT */
    				out, strlen(out));
       free(out);
       /* free all objects under root and root itself */
       cJSON_Delete(root);
       return;
    Could you try to adapt this to your use?
    Edit: code is based on the following stack overflow ticket.
    Carl Richard
  • I managed to adapt the example, so now I only need to remove the quotes "" from the value1 "13.0".
    Do you have an idea how to do this?
    David
  • You do not want the "sensors" array on top. Do interpret it correctly?
    Carl Richard
  • I want it like this --->
    "value": "13.0"
    without the quotes around 13.0
    David
  • Hi again, David!
    I've rewritten it to your configuration. However, there is an issue with the cJSON library that prevents it from handling doubles from what I could tell. Therefore you need to convert from string (i.e. "13.0") to float (i.e. 13.0) on the cloud end.
    	char *out;
    	char value_buf[6];
    	double value = 13.0;
    	snprintf(value_buf, sizeof(value_buf), "%.1f",
    	value);
    	printk("Value: %s\n", value_buf);
    	cJSON *root;
    	/* add sensor data */
    	cJSON_AddItemToObject(root, "sensor_id", cJSON_CreateString(id1));
    	cJSON_AddItemToObject(root, "value", cJSON_CreateString(value_buf));
    	if (out == NULL) {
    		printk("Failed print...\n");
       			out, strlen(out));
    	free(out);
    	cJSON_Delete(root);
    	return;
    I hope this works out!
    Carl Richard
