pc-ble-driver build up error on windows
I want to build up a test software to test our product.
I find out pc-ble-driver that might be conformed our requirement and follow up below link to set up environment on windows 10
https://github.com/NordicSemiconductor/pc-ble-driver
And, I use visual studio 2019 to set up.
But, I encounter a issue in chapter Compiling pc-ble-driver from source step 2.
2. CMake Select the Visual Studio compiler to use according to this article: Build C/C++ code on the command line
$ cmake -G Ninja ..
Command line display error message as below:
-- NRF_BLE_DRIVER_VERSION not specified, setting it to 0.0.0
-- Architecture not set, using native 32-bit toolchain.
CMake Error at test/CMakeLists.txt:18 (find_package):
  Could not find a package configuration file provided by "Catch2" with any
  of the following names:
    Catch2Config.cmake
    catch2-config.cmake
  Add the installation prefix of "Catch2" to CMAKE_PREFIX_PATH or set
  "Catch2_DIR" to a directory containing one of the above files.  If "Catch2"
  provides a separate development package or SDK, be sure it has been
  installed.
I change CMakeLists.txt in pc-ble-driver-master\test folder.
From
find_package(spdlog CONFIG REQUIRED)
To
if(NOT TARGET spdlog)
    # Stand-alone build
    set(SPDLOG_DIR "C:\\dev\\spdlog")
endif()
After changed, it still display same error message.
Kindly guide me through the problem.
Thank you.
  • Hi Susheel,
    Thank you for your reply.
    I try to add environment variables in system variables of windows GUI, and add it directly in command line console. In command line, it displays as below:
    D:\Delta\BLE\HCI\pc-ble-driver-master\test>cmake -DBOOST_ROOT=C:\boost\boost_1_68_0 -DBOOST_LIBRARYDIR=C:\boost\boost_1_68_0\stage\lib
    CMake Warning:
      No source or binary directory provided.  Both will be assumed to be the
      same as the current working directory, but note that this warning will
      become a fatal error in future CMake releases.
    CMake Warning (dev) in CMakeLists.txt:
      No project() command is present.  The top-level CMakeLists.txt file must
      contain a literal, direct call to the project() command.  Add a line of
      code such as
        project(ProjectName)
      near the top of the file, but after cmake_minimum_required().
      CMake is pretending there is a "project(Project)" command on the first
      line.
    This warning is for project developers.  Use -Wno-dev to suppress it.
    -- Selecting Windows SDK version 10.0.18362.0 to target Windows 10.0.17763.
    CMake Error at CMakeLists.txt:16 (find_package):
      Could not find a package configuration file provided by "spdlog" with any
        spdlogConfig.cmake
        spdlog-config.cmake
      Add the installation prefix of "spdlog" to CMAKE_PREFIX_PATH or set
      "spdlog_DIR" to a directory containing one of the above files.  If "spdlog"
      installed.
    In CMakeLists.txt file of text folder, the line 16 is find_package(spdlog CONFIG REQUIRED).
    But, above this message, I get there is no source and projectName warning message which project name should I add in CMakeLists.txt?
    Thank you.
  • Hi Ben,
    You need to point to a valid build directory in your command line
    "cmake -DBOOST_ROOT=C:\boost\boost_1_68_0 -DBOOST_LIBRARYDIR=C:\boost\boost_1_68_0\stage\lib " there's no ".." in the end of your command.
    My colleague HĂĄkon Alseth noticed it.
  • Hi Susheel,
    I try to follow below link to install spdlog and set up environment variables:
    https://github.com/gabime/spdlog
    But, it appears some error for finding makefile.
    C:\dev\spdlog-1.x\build>cmake .. && make -j
    -- Build spdlog: 1.7.0
    -- Build type: Release
    -- Generating example(s)
    -- Generating install
    -- Configuring done
    -- Generating done
    -- Build files have been written to: C:/dev/spdlog-1.x/build
    make: *** No targets specified and no makefile found.  Stop.
    System environment variables by using windows GUI.
    C:\dev\spdlog-1.x\build & C:\dev\spdlog-1.x in path
    I return the build folder and add ".." end of my command to let it return to upper layer path.
    D:\Delta\BLE\HCI\pc-ble-driver-master\build>cmake -DBOOST_ROOT=C:\boost\boost_1_68_0 -DBOOST_LIBRARYDIR=C:\boost\boost_1_68_0\stage\lib ..
    CMake Warning at C:/dev/vcpkg/scripts/buildsystems/vcpkg.cmake:116 (message):
      Unable to determine target architecture, continuing without vcpkg.
      build/CMakeFiles/3.18.2/CMakeSystem.cmake:6 (include)
      CMakeLists.txt:25 (project)
    -- Architecture not set, using native 64-bit toolchain.
    -- Building with build type: .
    CMake Error at C:/dev/spdlog-1.x/build/spdlogConfig.cmake:15 (include):
      include could not find load file:
        C:/dev/spdlog-1.x/build/spdlogConfigTargets.cmake
      test/CMakeLists.txt:14 (find_package)
    CMake Error at test/CMakeLists.txt:16 (find_package):
        Catch2Config.cmake
        catch2-config.cmake
      installed.
    It looks like catch2 can't be found that does mean the previous step of
    vcpkg install asio catch2 spdlog not working?
    Thank you.
  • I am not so familiar with the spdlog, but it seems like it has some environment variables missing as it cannot find the minimal files it needs to function.
  • Hi Susheel,
    It can be built after I add a loss environment variables "VCPKG_ROOT" and re-install CMake.
    Thank you for your assistance.
