pc-ble-driver build up error on windows
I want to build up a test software to test our product.
I find out pc-ble-driver that might be conformed our requirement and follow up below link to set up environment on windows 10
https://github.com/NordicSemiconductor/pc-ble-driver
And, I use visual studio 2019 to set up.
But, I encounter a issue in chapter Compiling pc-ble-driver from source step 2.
2. CMake Select the Visual Studio compiler to use according to this article: Build C/C++ code on the command line
$ cmake -G Ninja ..
Command line display error message as below:
-- NRF_BLE_DRIVER_VERSION not specified, setting it to 0.0.0
-- Architecture not set, using native 32-bit toolchain.
CMake Error at test/CMakeLists.txt:18 (find_package):
  Could not find a package configuration file provided by "Catch2" with any
  of the following names:
    Catch2Config.cmake
    catch2-config.cmake
  Add the installation prefix of "Catch2" to CMAKE_PREFIX_PATH or set
  "Catch2_DIR" to a directory containing one of the above files.  If "Catch2"
  provides a separate development package or SDK, be sure it has been
  installed.
I change CMakeLists.txt in pc-ble-driver-master\test folder.
From
find_package(spdlog CONFIG REQUIRED)
To
if(NOT TARGET spdlog)
    # Stand-alone build
    set(SPDLOG_DIR "C:\\dev\\spdlog")
endif()
After changed, it still display same error message.
Kindly guide me through the problem.
Thank you.
