Unable to read chunk of data from Peripheral\SPIS Example
       I'm trying to implement a  SPI Communication between Arduino UNO and PCA10056 DK.  PCA10056 DK run as a SPI slave.. Arduino uno run as a SPI Master.
      The problem is SPI Master keep sending a chunk of data (size - 25 bytes ) by each second..  But I'm unable to receive 25 bytes  from PCA 10056 board.
       Sometimes I receive 10 bytes or 12 bytes... not sure why it happening
       Is it any Mode issue or Clock div?
  •  Is it any Mode issue or Clock div?
    Impossible to say without looking at code or the plot on a DSO (digital storage oscilloscope, 4 channels recommended for SPI).
  • #define TEST_STRING "Nordic"
    static uint8_t       m_tx_buf[25];           /**< TX buffer. */
    static uint8_t       m_rx_buf[25];    /**< RX buffer. */
    static const uint8_t m_length =25;        /**< Transfer length. */
    //static char     m_buf={0};
    static volatile bool spis_xfer_done; /**< Flag used to indicate that SPIS instance completed the transfer. */
     * @brief SPIS user event handler.
     * @param event
    void spis_event_handler(nrf_drv_spis_event_t event)
        if (event.evt_type == NRF_DRV_SPIS_XFER_DONE)
    	spis_xfer_done = true;
    		//if(event.rx_amount>2)
                NRF_LOG_INFO(" Transfer completed. Received: %d   %X",event.rx_amount);//,m_rx_buf[0]);//event.rx_amount,m_rx_buf[0],m_rx_buf[1],m_rx_buf[2]);
        // Enable the constant latency sub power mode to minimize the time it takes
        // for the SPIS peripheral to become active after the CSN line is asserted
        // (when the CPU is in sleep mode).
        NRF_POWER->TASKS_CONSTLAT = 1;
        NRF_LOG_INFO("SPIS example");
        nrf_drv_spis_config_t spis_config = NRF_DRV_SPIS_DEFAULT_CONFIG;
        spis_config.csn_pin               = APP_SPIS_CS_PIN;
        spis_config.miso_pin              = APP_SPIS_MISO_PIN;
        spis_config.mosi_pin              = APP_SPIS_MOSI_PIN;
        spis_config.sck_pin               = APP_SPIS_SCK_PIN;
        APP_ERROR_CHECK(nrf_drv_spis_init(&spis, &spis_config, spis_event_handler));
        while (1)
            memset(m_rx_buf, 0, m_length);
            spis_xfer_done = false;
            APP_ERROR_CHECK(nrf_drv_spis_buffers_set(&spis, m_tx_buf, m_length, m_rx_buf, m_length));
            while (!spis_xfer_done)
                __WFE();
            NRF_LOG_FLUSH();
            bsp_board_led_invert(BSP_BOARD_LED_0);
     The amount of received byte ...I'm printing it on console.
  • spis_config has a parameter:
    spis_config.mode = NRF_SPIS_MODE_0, which is set by NRF_DRV_SPIS_DEFAULT_CONFIG;
    Try all the modes with your SPIM:
    NRF_SPIS_MODE_0
    NRF_SPIS_MODE_1
    NRF_SPIS_MODE_2
    NRF_SPIS_MODE_3
    And see if you receive all the data with any of these. Perhaps the master is using another mode than NRF_SPIS_MODE_0.
    BR,
    Edvin
