Authentication failed with status BLE_GAP_SEC_STATUS_INVALID_PARAMS
Hi!
I'm developing code for Central device on nRF52840. SDK 16.0.0 SoftDevice S140.
Peripheral is a Bluetooth mini printer. I can connect to it and print. But when I try to bond calling pm_conn_secure() I have failure PM_EVT_CONN_SEC_FAILED with error BLE_GAP_SEC_STATUS_INVALID_PARAMS.(0x8A)
My settings are:
#define SEC_PARAM_BOND 1
#define SEC_PARAM_MITM 1
#define SEC_PARAM_IO_CAPABILITIES BLE_GAP_IO_CAPS_KEYBOARD_DISPLAY
#define SEC_PARAM_OOB 0
#define SEC_PARAM_MIN_KEY_SIZE 7
#define SEC_PARAM_MAX_KEY_SIZE 16
#define SEC_PARAM_LESC 1
#define SEC_PARAM_KEYPRESS 0
I tried to pair that printer on two Android phones. When I pair via Android settings I have passkey invitation. When I bond printer from nRF Connect for Android, on both phones it bonded without asking passkey. Not sure if bonded correctly because all Characteristics in printer are open.
nRF Connect for Windows 10 with PCA10040 as dongle behaves differently. It returns BLE_GAP_SEC_STATUS_INVALID_PARAMS
Log is below.
2020-08-28T15:33:24.563Z DEBUG 382 -> [00 7e 00 00 01 47 07 10 01 01 ] type: VENDOR_SPECIFIC reliable:yes seq#:5 ack#:0 payload_length:a data_integrity:1 header_checksum:8d err_code:0x0
2020-08-28T15:33:24.607Z DEBUG 378/ 0 <- [N/A] type: ACK reliable: no seq#:0 ack#:6 payload_length:0 data_integrity:0 err_code:0x0
2020-08-28T15:33:24.607Z DEBUG 379/ 0 <- [01 7e 00 00 00 00 ] type: VENDOR_SPECIFIC reliable:yes seq#:0 ack#:6 payload_length:6 data_integrity:1 header_checksum:a2 err_code:0x0
2020-08-28T15:33:24.608Z DEBUG 383 -> [N/A] type: ACK reliable: no seq#:0 ack#:1 payload_length:0 data_integrity:0 err_code:0x0
2020-08-28T15:33:24.608Z DEBUG Authenticate, secParams: r { "bond": true, "io_caps": 4, "lesc": true, "mitm": true, "oob": false, "keypress": false, "min_key_size": 7, "max_key_size": 16, "kdist_own": [object Object], "kdist_peer": [object Object] }
2020-08-28T15:33:24.655Z DEBUG 380/ 0 <- [02 19 00 00 00 8a 00 00 00 00 00 ] type: VENDOR_SPECIFIC reliable:yes seq#:1 ack#:6 payload_length:b data_integrity:1 header_checksum:51 err_code:0x0
2020-08-28T15:33:24.655Z DEBUG 384 -> [N/A] type: ACK reliable: no seq#:0 ack#:2 payload_length:0 data_integrity:0 err_code:0x0
2020-08-28T15:33:24.655Z DEBUG GAP_EVT_AUTH_STATUS time:2020-08-28T15:33:24.655Z connHandle:0 authStatus:138 authStatusName:bleGapSecStatusInvalidParams errorSrc:0 errorSrcName:bleGapSecStatusSourceLocal bonded:false sm1Levels:[lv1:false lv2:false lv3:false lv4:false] sm2Levels:[lv1:false lv2:false lv3:false lv4:false] kdistOwn:[enc:false sign:false link:false] kdistPeer:[enc:false sign:false link:false] lesc:false keyset:null
2020-08-28T15:33:24.656Z WARN Authentication failed with status BLE_GAP_SEC_STATUS_INVALID_PARAMS
2020-08-28T15:34:54.816Z DEBUG 385 -> [00 7e 00 00 01 43 07 10 01 01 ] type: VENDOR_SPECIFIC reliable:yes seq#:6 ack#:2 payload_length:a data_integrity:1 header_checksum:7c err_code:0x0
2020-08-28T15:34:54.851Z DEBUG 381/ 0 <- [N/A] type: ACK reliable: no seq#:0 ack#:7 payload_length:0 data_integrity:0 err_code:0x0
2020-08-28T15:34:54.851Z DEBUG 382/ 0 <- [01 7e 00 00 00 00 ] type: VENDOR_SPECIFIC reliable:yes seq#:2 ack#:7 payload_length:6 data_integrity:1 header_checksum:98 err_code:0x0
2020-08-28T15:34:54.851Z DEBUG 386 -> [N/A] type: ACK reliable: no seq#:0 ack#:3 payload_length:0 data_integrity:0 err_code:0x0
2020-08-28T15:34:54.852Z DEBUG Authenticate, secParams: r { "bond": true, "io_caps": 4, "lesc": false, "mitm": true, "oob": false, "keypress": false, "min_key_size": 7, "max_key_size": 16, "kdist_own": [object Object], "kdist_peer": [object Object] }
2020-08-28T15:34:54.897Z DEBUG 383/ 0 <- [02 19 00 00 00 8a 00 00 00 00 00 ] type: VENDOR_SPECIFIC reliable:yes seq#:3 ack#:7 payload_length:b data_integrity:1 header_checksum:47 err_code:0x0
2020-08-28T15:34:54.897Z DEBUG 387 -> [N/A] type: ACK reliable: no seq#:0 ack#:4 payload_length:0 data_integrity:0 err_code:0x0
2020-08-28T15:34:54.898Z DEBUG GAP_EVT_AUTH_STATUS time:2020-08-28T15:34:54.897Z connHandle:0 authStatus:138 authStatusName:bleGapSecStatusInvalidParams errorSrc:0 errorSrcName:bleGapSecStatusSourceLocal bonded:false sm1Levels:[lv1:false lv2:false lv3:false lv4:false] sm2Levels:[lv1:false lv2:false lv3:false lv4:false] kdistOwn:[enc:false sign:false link:false] kdistPeer:[enc:false sign:false link:false] lesc:false keyset:null
2020-08-28T15:34:54.898Z WARN Authentication failed with status BLE_GAP_SEC_STATUS_INVALID_PARAMS
When I try to pair printer via Windows it asks passkey.
Which parameter can be invalid? I believe I tried all possible combinations which makes sense.
Thanks.
Update.
Below is Sniffer logs.
Android nRF Connect application successfully bonded:
No.     Time     Source                PHY        Protocol Length     Delta time (µs end to start) SN         NESN       More Data  Event counter Info
   1312 46.200   Master_0xa60a2eab     LE 1M      SMP      11         44689µs                      0          0          False      115           Sent Pairing Request: AuthReq: Bonding, MITM | Initiator Key(s): LTK, IRK, CSRK | Responder Key(s): LTK, IRK, CSRK
Frame 1312: 37 bytes on wire (296 bits), 37 bytes captured (296 bits) on interface wireshark_extcap2016, id 0
Nordic BLE Sniffer
    Board: 7
    Header Version: 2, Packet counter: 55640
    Length of packet: 10
    Flags: 0x03
        .... ...1 = CRC: OK
        .... ..1. = Direction: Master -> Slave
        .... .0.. = Encrypted: No
        .... 0... = MIC (not relevant): 0
        .000 .... = PHY: LE 1M (0)
        0... .... = Reserved: 0
    Channel: 35
    RSSI: -43 dBm
    Event counter: 115
    Delta time (end to start): 44689µs
    [Delta time (start to start): 44769µs]
    [Packet time (start to end): 168µs]
Bluetooth Low Energy Link Layer
    Access Address: 0xa60a2eab
    [Master Address: 73:42:fd:0a:66:7b (73:42:fd:0a:66:7b)]
    [Slave Address: 0f:02:18:41:82:bb (0f:02:18:41:82:bb)]
    Data Header: 0x0b02
    [L2CAP Index: 57]
    CRC: 0xc26cf9
Bluetooth L2CAP Protocol
    Length: 7
    CID: Security Manager Protocol (0x0006)
Bluetooth Security Manager Protocol
    Opcode: Pairing Request (0x01)
    IO Capability: Keyboard, Display (0x04)
    OOB Data Flags: OOB Auth. Data Not Present (0x00)
    AuthReq: 0x05, MITM Flag, Bonding Flags: Bonding
        000. .... = Reserved: 0x0
        ...0 .... = Keypress Flag: False
        .... 0... = Secure Connection Flag: False
        .... .1.. = MITM Flag: True
        .... ..01 = Bonding Flags: Bonding (0x1)
    Max Encryption Key Size: 16
    Initiator Key Distribution: 0x07, Signature Key (CSRK), Id Key (IRK), Encryption Key (LTK)
        0000 .... = Reserved: 0x0
        .... 0... = Link Key: False
        .... .1.. = Signature Key (CSRK): True
        .... ..1. = Id Key (IRK): True
        .... ...1 = Encryption Key (LTK): True
    Responder Key Distribution: 0x07, Signature Key (CSRK), Id Key (IRK), Encryption Key (LTK)
   1313 46.245   Master_0xa60a2eab     LE 1M      SMP      11         44831µs                      0          0          False      116           Sent Pairing Request: AuthReq: Bonding, MITM | Initiator Key(s): LTK, IRK, CSRK | Responder Key(s): LTK, IRK, CSRK
Frame 1313: 37 bytes on wire (296 bits), 37 bytes captured (296 bits) on interface wireshark_extcap2016, id 0
Nordic BLE Sniffer
    Board: 7
    Header Version: 2, Packet counter: 55641
    Flags: 0x03
        .... ...1 = CRC: OK
    Channel: 5
    RSSI: -41 dBm
    Event counter: 116
    Delta time (end to start): 44831µs
    [Delta time (start to start): 44999µs]
    Data Header: 0x0b02
    [L2CAP Index: 58]
    CRC: 0xc26cf9
    Length: 7
   1314 46.248   Slave_0xa60a2eab      LE 1M      SMP      11         151µs                        0          1          False      116           Rcvd Pairing Response: AuthReq: Bonding | Initiator Key(s): CSRK | Responder Key(s): LTK
Frame 1314: 37 bytes on wire (296 bits), 37 bytes captured (296 bits) on interface wireshark_extcap2016, id 0
Nordic BLE Sniffer
    Board: 7
    Header Version: 2, Packet counter: 55642
    Flags: 0x01
        .... ...1 = CRC: OK
        .... ..0. = Direction: Slave -> Master
    Channel: 5
    RSSI: -73 dBm
    Event counter: 116
    Delta time (end to start): 151µs
    [Delta time (start to start): 319µs]
    Data Header: 0x0b06
    [L2CAP Index: 59]
    CRC: 0x06748e
    Length: 7
    Opcode: Pairing Response (0x02)
    IO Capability: No Input, No Output (0x03)
    AuthReq: 0x01, Bonding Flags: Bonding
        .... .0.. = MITM Flag: False
    Initiator Key Distribution: 0x04, Signature Key (CSRK)
        .... ..0. = Id Key (IRK): False
        .... ...0 = Encryption Key (LTK): False
    Responder Key Distribution: 0x01, Encryption Key (LTK)
        .... .0.. = Signature Key (CSRK): False
   1315 46.291   Master_0xa60a2eab     LE 1M      SMP      21         44513µs                      1          1          False      117           Sent Pairing Confirm
Frame 1315: 47 bytes on wire (376 bits), 47 bytes captured (376 bits) on interface wireshark_extcap2016, id 0
Nordic BLE Sniffer
    Board: 7
    Header Version: 2, Packet counter: 55643
    Flags: 0x03
        .... ...1 = CRC: OK
    Channel: 12
    RSSI: -39 dBm
    Event counter: 117
    Delta time (end to start): 44513µs
    [Delta time (start to start): 44681µs]
    [Packet time (start to end): 248µs]
    Data Header: 0x150e
    [L2CAP Index: 60]
    CRC: 0x73e44e
    Length: 17
    Opcode: Pairing Confirm (0x03)
    Confirm Value: 564c8748f3c4f764f86f46a650c083bc
   1316 46.294   Slave_0xa60a2eab      LE 1M      SMP      21         150µs                        1          0          False      117           Rcvd Pairing Confirm
Frame 1316: 47 bytes on wire (376 bits), 47 bytes captured (376 bits) on interface wireshark_extcap2016, id 0
Nordic BLE Sniffer
    Board: 7
    Header Version: 2, Packet counter: 55644
    Flags: 0x01
        .... ...1 = CRC: OK
    Channel: 12
    RSSI: -76 dBm
    Event counter: 117
    Delta time (end to start): 150µs
    [Delta time (start to start): 398µs]
    Data Header: 0x150a
    [L2CAP Index: 61]
    CRC: 0xb3590a
    Length: 17
    Confirm Value: 5c5d2ff700ab71c89eb252ab4bb5fa05
   1317 46.336   Master_0xa60a2eab     LE 1M      SMP      21         44352µs                      0          0          False      118           Sent Pairing Random
Frame 1317: 47 bytes on wire (376 bits), 47 bytes captured (376 bits) on interface wireshark_extcap2016, id 0
Nordic BLE Sniffer
    Board: 7
    Header Version: 2, Packet counter: 55645
    Flags: 0x03
        .... ...1 = CRC: OK
    Channel: 19
    RSSI: -41 dBm
    Event counter: 118
    Delta time (end to start): 44352µs
    [Delta time (start to start): 44600µs]
    Data Header: 0x1502
    [L2CAP Index: 62]
    CRC: 0x095355
    Length: 17
    Opcode: Pairing Random (0x04)
    Random Value: 631f89c457eaf1b3951c3296bdd3e447
   1318 46.382   Master_0xa60a2eab     LE 1M      SMP      21         44751µs                      0          0          False      119           Sent Pairing Random
Frame 1318: 47 bytes on wire (376 bits), 47 bytes captured (376 bits) on interface wireshark_extcap2016, id 0
Nordic BLE Sniffer
    Board: 7
    Header Version: 2, Packet counter: 55646
    Flags: 0x03
        .... ...1 = CRC: OK
    Channel: 36
    RSSI: -43 dBm
    Event counter: 119
    Delta time (end to start): 44751µs
    Data Header: 0x1502
    [L2CAP Index: 63]
    CRC: 0x095355
    Length: 17
   1319 46.427   Master_0xa60a2eab     LE 1M      LE LL    23         44751µs                      1          1          False      120           Control Opcode: LL_ENC_REQ
Frame 1319: 49 bytes on wire (392 bits), 49 bytes captured (392 bits) on interface wireshark_extcap2016, id 0
Nordic BLE Sniffer
    Board: 7
    Header Version: 2, Packet counter: 55647
    Flags: 0x03
        .... ...1 = CRC: OK
    Channel: 33
    RSSI: -42 dBm
    Event counter: 120
    [Packet time (start to end): 264µs]
    Data Header: 0x170f
    Control Opcode: LL_ENC_REQ (0x03)
    Random Number: 0 (0x0000000000000000)
    Encrypted Diversifier: 0 (0x0000)
    Master Session Key Diversifier: 10986969477047204564 (0x98798e8725753ad4)
    Master Session Initialization Vector: 1727634650 (0x66f99cda)
    CRC: 0xa6d9c2
   1320 46.431   Slave_0xa60a2eab      LE 1M      LE LL    13         150µs                        1          0          True       120           Control Opcode: LL_ENC_RSP
Frame 1320: 39 bytes on wire (312 bits), 39 bytes captured (312 bits) on interface wireshark_extcap2016, id 0
Nordic BLE Sniffer
    Board: 7
    Header Version: 2, Packet counter: 55648
    Flags: 0x01
        .... ...1 = CRC: OK
    Channel: 33
    RSSI: -79 dBm
    Event counter: 120
    [Delta time (start to start): 414µs]
    [Packet time (start to end): 184µs]
    Data Header: 0x0d1b
    Control Opcode: LL_ENC_RSP (0x04)
    Slave Session Key Diversifier: 13418200902072171183 (0xba3706a0b4d67aaf)
    Slave Session Initialization Vector: 2253425201 (0x0000000086508a31)
    CRC: 0x651c16
nRF52840 Central code bonding failed. I tried to change IO capability to match Android but it didn't help:
    181 6.866    Master_0xb066ed9d     LE 1M      SMP      11         149µs                        1          1          False      52            Sent Pairing Request: AuthReq: Bonding, MITM | Initiator Key(s): LTK, IRK | Responder Key(s): LTK, IRK
Frame 181: 37 bytes on wire (296 bits), 37 bytes captured (296 bits) on interface wireshark_extcap3496, id 0
Nordic BLE Sniffer
    Board: 7
    Header Version: 2, Packet counter: 5066
    Flags: 0x03
        .... ...1 = CRC: OK
    Channel: 34
    RSSI: -53 dBm
    Event counter: 52
    Delta time (end to start): 149µs
    [Delta time (start to start): 229µs]
    Access Address: 0xb066ed9d
    [Master Address: eb:a0:5a:49:e0:e2 (eb:a0:5a:49:e0:e2)]
    Data Header: 0x0b0e
    [L2CAP Index: 18]
    CRC: 0x8db90b
    Length: 7
    IO Capability: Keyboard Only (0x02)
    Initiator Key Distribution: 0x03, Id Key (IRK), Encryption Key (LTK)
    Responder Key Distribution: 0x03, Id Key (IRK), Encryption Key (LTK)
    182 6.868    Slave_0xb066ed9d      LE 1M      SMP      11         150µs                        1          0          False      52            Rcvd Pairing Response: AuthReq: Bonding | Initiator Key(s): CSRK | Responder Key(s): LTK
Frame 182: 37 bytes on wire (296 bits), 37 bytes captured (296 bits) on interface wireshark_extcap3496, id 0
Nordic BLE Sniffer
    Board: 7
    Header Version: 2, Packet counter: 5067
    Flags: 0x01
        .... ...1 = CRC: OK
    Channel: 34
    RSSI: -75 dBm
    Event counter: 52
    [Delta time (start to start): 318µs]
    Data Header: 0x0b0a
    [L2CAP Index: 19]
    CRC: 0xda393f
    Length: 7
    183 6.893    Master_0xb066ed9d     LE 1M      SMP      6          29050µs                      0          0          False      53            Sent Pairing Failed: Invalid Parameters
Frame 183: 32 bytes on wire (256 bits), 32 bytes captured (256 bits) on interface wireshark_extcap3496, id 0
Nordic BLE Sniffer
    Board: 7
    Header Version: 2, Packet counter: 5068
    Flags: 0x03
        .... ...1 = CRC: OK
    Channel: 13
    RSSI: -47 dBm
    Event counter: 53
    Delta time (end to start): 29050µs
    [Delta time (start to start): 29218µs]
    [Packet time (start to end): 128µs]
    Data Header: 0x0602
    [L2CAP Index: 20]
    CRC: 0xd3e3b2
    Length: 2
    Opcode: Pairing Failed (0x05)
    Reason: Invalid Parameters (0x0a)
    184 6.922    Master_0xb066ed9d     LE 1M      SMP      6          29871µs                      0          0          False      54            Sent Pairing Failed: Invalid Parameters
Frame 184: 32 bytes on wire (256 bits), 32 bytes captured (256 bits) on interface wireshark_extcap3496, id 0
Nordic BLE Sniffer
    Board: 7
    Header Version: 2, Packet counter: 5069
    Flags: 0x03
        .... ...1 = CRC: OK
    Channel: 29
    RSSI: -51 dBm
    Event counter: 54
    Delta time (end to start): 29871µs
    [Delta time (start to start): 29999µs]
    Data Header: 0x0602
    [L2CAP Index: 21]
    CRC: 0xd3e3b2
    Length: 2
It looks like that the problem is in Signature Key (CSRK). Nordic SoftDevice doesn't support it. As soon as I enable it in security parameters, peer manager return error.
    // Signing is not supported.
    if (p_sec_params->kdist_own.sign || p_sec_params->kdist_peer.sign)
        return false;
