I'm not using softdevice, What is maximum GPIOTE Peripheral clock frequency for Interrupts for nrf52832? [Without PPI]
Thanks
Thanks
Here is the difference between polling and ISR.. polling is working much better.. What's wrong???
#include <stdbool.h>
#include <stdint.h>
#include "nrf.h"
#include "nrf_drv_timer.h"
#include "nrf_drv_clock.h"
#include "nrf_drv_gpiote.h"
#include "app_error.h"
#include "nrf_delay.h"
#include "boards.h"
#define PIN_TO_TOGGLE 27
#define PIN_TO_TOGGLE2 28
#define PIN_SCL 25
//#define USE_INTERRUPTS
#ifdef USE_INTERRUPTS
void in_pin_scl_handler(nrf_drv_gpiote_pin_t pin, nrf_gpiote_polarity_t action)
if(nrf_drv_gpiote_in_is_set(PIN_SCL))
nrf_gpio_pin_set(PIN_TO_TOGGLE2);
nrf_gpio_pin_clear(PIN_TO_TOGGLE2);
static void hfclk_config(void) {
ret_code_t err_code = nrf_drv_clock_init();
nrf_drv_clock_hfclk_request(NULL);
hfclk_config();
ret_code_t err_code;
if(!nrf_drv_gpiote_is_init())
nrf_drv_gpiote_in_config_t in_config2 = GPIOTE_CONFIG_IN_SENSE_TOGGLE(true);
in_config2.pull = NRF_GPIO_PIN_PULLUP;
err_code = nrf_drv_gpiote_in_init(PIN_SCL, &in_config2, in_pin_scl_handler);
nrf_drv_gpiote_in_event_enable(PIN_SCL, true);
#else
nrf_gpio_cfg_input(PIN_SCL,NRF_GPIO_PIN_PULLUP);
nrf_gpio_cfg_output(PIN_TO_TOGGLE);
nrf_gpio_cfg_output(PIN_TO_TOGGLE2);
while (1)
#ifndef USE_INTERRUPTS
nrf_gpio_pin_set(PIN_TO_TOGGLE);
nrf_gpio_pin_clear(PIN_TO_TOGGLE);
this is quite expected - in polling mode, CPU needs to execute one port read, compare and one port write in a loop. In interrupt mode, there is an overhead of interrupt handler (take a look at nrfx_gpiote_irq_handler in SDK\modules\nrfx\drivers\src\nrfx_gpiote.c to see amount of code executed at each interrupt occurence). The advantage of interrupt mode is that you can do other tasks or put CPU to sleep while waiting for pin change, but polling will be faster in any case.
