After Unpromising (Reset Node) the node is not able to discover for further provisioning.
   We are using nRF52840 chipset with SDK 15.0.0  with Mesh implemetation.
1. We are provisioning the mesh node using the nRF mesh APP.
2. Then we are resetting the node using same nRF mesh APP.
3. Sometimes above works and we are able to scan/see the node in unprovision list  of mesh APP.
4. But sometime when we reset (unprovision) the node it is not coming back in unprovision list neither we are able to scan/see  it anymore.which is almost dead state for us because we are no longer able to see and connect it.
This has become show stopper for us because even after power cycle we are not able to discover it.
Waiting for your immediate resolution and support.
Ram
  • Hi Hung,
       Thanks for providing the inputs and supporting us.
      As informed i tried to use the function apply_reset(), but this is called from the callback function mesh_event_cb(), how do i trigger this callback function intern which triggers the apply_reset() function.
      Actually in our current code the Mesh reset  is happening randomly ( say out of 10 tries 6 tries it reset the node another 4 it fails).
    In failure case it is observed that the BLE chip get reset automatically before be execute the reset command( force reset).
    Even we are not able to have the calll stack information in the bedugging mode to find out the reason for failure.
    Currently we are using the proxy Mesh SDK, Please let me know is there any way to identity the version number of Mesh APP because it is old code and i didnt get the Mesh SDK with name proxy Mesh SDK in nordic official release.
  • Hi Ramachandra,
    I don't recognize the "nrf52-mesh-proxy-server" folder. What's inside that folder ? Could you step in the bin\softdevices folder and take a screenshot?
    I strongly suggest you to migrate to our latest Mesh SDK which is version 4.2
    We noticed that you are having multiple cases with us and on your other cases your mesh doesn't work very reliably. I would suggest that you test using our latest SDK and firmware on your board to check if you see the same issue. This is to verify that the issue was not from your hardware but maybe from  your firmware.
    In our lightswitch server example we allow pressing button 4 to reset the node,  you can try to do the same on your firmware to check if it can reset the node (without sending mesh packet to reset) this way you maybe able to debug it easier. Note that to debug you need to clear the code optimization in the compiler.
  • Hi Hung,
      Please find the details below.
      The bin\softdevices contains the softdevice images. We are currently the BLE chipset nRF52840 and s140 softdevices ehile programming.
    I will try to test the suggested SDK on our hardware and let you know how it behaves.
    Ram
  • Hi Ram,
    It seems that you are using pretty old SDK, most likely SDK v2.2.0.
    I suggest you to move to latest SDK.
    If it's not possible you may need to test with our example and check if you get the same issue or not.  Note that when you debug you need to set optimization level to 0 and debug level to 3.
  • Hi Hung,
       Sure we will try with the new Mesh SDK version 4.2 and check it out once.
       But does this SDk support for configuring both Generic On OFF Server and Generic On Off Client model in same binary image as shown in the below snippet.
      Because i remember before using the proxy sdk( which we are using currently) we use to have two separate binary images one for configuring the Generic On OFF Server and one for Generic On Off Client( We use to get only 1 option under Element)
    Please suggest if anything i am missing.
    Ram
