Problem Interfacing SPI external Flash and writing to the Flash Registers
I am trying to interface  External Flash (IS25LP064A ) using SPI example in SDK v16. I am able to read the Manufacturer_ID and the device ID from the external flash. Now I want to Read, write and Erase the flash. But I am unable to do so. Please tell me if any example is there or the way how to do that .
Please give any example code to interface SPI flash.
  • HI Amanda,
    Here is my complete code. and here is the data sheet. http://www.issi.com/WW/pdf/25LP032-64A-B.pdf. I am trying to read and write data to flash. But I am unable to write or read. Also I am unable to set the WEL using WREN command. The only output I am getting after reading a status register or any adress is 0. Please let me know what's the missing things in my code. Please help me with any example code if u have or please let me know what is wrong or missing in my code.
     * Copyright (c) 2015 - 2019, Nordic Semiconductor ASA
     * All rights reserved.
    #include "nrf_drv_spi.h"
    #include "nrf_gpio.h"
    #include "nrf_delay.h"
    #include "boards.h"
    #include "app_error.h"
    #include <string.h>
    #include "nrf_log.h"
    #include "nrf_log_ctrl.h"
    /* Flash memory parameters */
    #define FLASH_PAGESIZE          256                     /* 256 Bytes */         /**< External Flash - Page Size */
    #define FLASH_SECTORSIZE        (16 * FLASH_PAGESIZE)	/* 16 Pages = 4KB */    /**< External Flash - Sector Size */
    #define FLASH_BLOCKSIZE		(16 * FLASH_SECTORSIZE)	/* 16 Sectors = 64KB */ /**< External Flash - Block Size */
    #define FLASH_SIZE              (128 * FLASH_BLOCKSIZE)	/* 128 Blocks = 8MB */  /**< External Flash - Total Memory Size */
    #define FLASH_BLOCK32K		(32 * 1024)		/* 32KB Block */
    #define FLASH_PAGESIZE_OFFSET    0x000100
    #define REG_SR_BIT_WIP    0
    #define READ_WRITE_LENGTH 200
    #define SPI_INSTANCE  0 /**< SPI instance index. */
    static const nrf_drv_spi_t spi = NRF_DRV_SPI_INSTANCE(SPI_INSTANCE);  /**< SPI instance. */
    static volatile bool spi_xfer_done;  /**< Flag used to indicate that SPI instance completed the transfer. */
    #define WAIT_FOR_PERIPH() do { \
            while (!m_finished) {} \
            m_finished = false;    \
        } while (0)
    #define TEST_STRING "Nordic"
    static uint8_t       m_tx_buf[] = TEST_STRING;           /**< TX buffer. */
    static uint8_t       m_rx_buf[sizeof(TEST_STRING) + 1];    /**< RX buffer. */
    static const uint8_t m_length = sizeof(m_tx_buf);        /**< Transfer length. */
    static uint8_t m_buffer_rx[256];
    static uint8_t m_buffer_tx[256];
    void cs_low(void)
      nrf_gpio_pin_clear(SPI_SS_PIN);
    void cs_high(void)
       nrf_gpio_pin_set(SPI_SS_PIN);
    uint8_t flash_ID_test( uint8_t id )
      ret_code_t err_code;
      static uint8_t instruction[8] = {0};
      uint8_t id_read = id;
      switch (id_read)
                case 1:
                    instruction[0] = 0xAB ;//RDID Command: Read Manufacturer and Product ID
                    instruction[1] = 0x00;
                    instruction[2] = 0x00;
                    instruction[3] = 0x00;
                   spi_xfer_done = false;
                   cs_low();
                   err_code = nrf_drv_spi_transfer(&spi,(uint8_t const *)instruction,sizeof(instruction),m_buffer_rx,7);
                   if(err_code == NRF_SUCCESS)
                        printf("RDID Transfer Successful\n");
                   printf("Flash_ID_1: %d\n",err_code);
                   while(spi_xfer_done == false)
                   printf("\rDevice ID is :");
                   printf("%02x \n",m_buffer_rx[4]);
                   cs_high();
                case 2:
                    instruction[0] = 0x90 ;//Read Manufacturer and Device ID
                    instruction[1]= 0x00;
                    instruction[3]= 0x00;
                    memset(m_buffer_rx,0x00,sizeof(m_buffer_rx));
                    cs_low();
                    nrf_drv_spi_transfer(&spi,(uint8_t const *)instruction,sizeof(instruction),m_buffer_rx,8);
                        printf("RDID_2 Transfer Successful\n");
                    printf("Flash_ID_2: %d\n",err_code);
                    cs_high();
    //                printf("%02x,%02x,%02x,%02x,%02x,%02x\n",m_buffer_rx[0],m_buffer_rx[1],m_buffer_rx[2],m_buffer_rx[3],m_buffer_rx[4],m_buffer_rx[5]);
                     printf(" Manufacturer_ID: %02x,Device_ID:%02x\n",m_buffer_rx[4],m_buffer_rx[5]);
    //                printf("%d,%d,%d,%d,%d,%d\n",m_buffer_rx[0],m_buffer_rx[1],m_buffer_rx[2],m_buffer_rx[3],m_buffer_rx[4],m_buffer_rx[5]);
                case 3:
                    m_buffer_tx[0] = 0x9f;//FLASH_CMD_RDID
                    cs_low();
    //                nrf_drv_spi_transfer(&spi,(uint8_t const *)m_buffer_tx,1,m_buffer_rx,4);
                    err_code = nrf_drv_spi_transfer(&spi,m_buffer_tx,1,m_buffer_rx,5);
                    nrf_delay_ms(2);
                        printf("RDID_3 Transfer Successful\n");
                    while(spi_xfer_done == false){}
                     printf("Flash_ID_3: %d\n",err_code);
                    printf("Manufacturer_ID: %02x Memory_Type : %02x, Capacity:%02x\n",m_buffer_rx[1],m_buffer_rx[2],m_buffer_rx[3]);
                    cs_high();
                        printf("Out of range");
       return err_code;
    void enable_software_request(void)
    	cs_low();
    	uint8_t rsten = 0x66;
    	m_buffer_tx[0] = rsten;
    	nrf_drv_spi_transfer(&spi,(uint8_t const *)m_buffer_tx,1,m_buffer_rx,1);
    	cs_high();
    	printf("Flash Enable Software request(RTSEN) Successful\n");
    void reset_software()
    	cs_low();
    	uint8_t rst = 0x99;
    	m_buffer_tx[0] = rst;
    	cs_high();
    	printf("Flash Software reset successful\n");
    void disable_write()
            cs_low();
    	uint8_t wrdi = 0x04;
    	m_buffer_tx[0] = wrdi;
    	err_code = nrf_drv_spi_transfer(&spi,(uint8_t const *)m_buffer_tx,1,m_buffer_rx,1);
            cs_high();
    	printf("Flash disable write opearation successful\n");
    uint8_t read_status_register()
         uint8_t data;
         static uint8_t spi_tx_cmd[2];
         static uint8_t spi_rx_cmd[2];
         uint8_t RDSR =0x05;
         cs_low();
         spi_tx_cmd[0] = RDSR;
         spi_tx_cmd[1] = 0x00;
         err_code = nrf_drv_spi_transfer(&spi,(uint8_t const *)spi_tx_cmd,2,spi_rx_cmd,2);
          printf("Status_Reg_Err_code : %d\n",err_code);
          printf("Rdsr-stat: %02X\n",spi_rx_cmd[0]);
          printf("Rdsd stat %02X\n",spi_rx_cmd[1]);
            printf("RDSR Transfer Successful\n");
         while(spi_xfer_done == false)   {}
        cs_high();
        return  data;
    void write_enable()
        uint8_t status_register;
        uint8_t spi_tx_cmd[1];
        cs_low();
        uint8_t WREN = 0x06;
        spi_tx_cmd[0] = WREN;
        err_code = nrf_drv_spi_transfer(&spi,spi_tx_cmd,sizeof(spi_tx_cmd),NULL,0);
        printf("Write_enable_err_code : %d\n",err_code);
           printf("WREN Transfer Successful\n");
    //    cs_high();
    //    printf("Flash Write Enable Latch operation successful\n");
    void write_status_register(uint8_t newStatus)
      uint8_t WRSR = 0x01;
      cs_low();
      spi_tx_cmd[0] = WRSR;
      spi_tx_cmd[1] = newStatus;
      nrf_drv_spi_transfer(&spi,(uint8_t const *)spi_tx_cmd,2,spi_rx_cmd,1);
      if(err_code = NRF_SUCCESS)
      cs_high();
    uint8_t read_function_register()
         uint8_t data ;
         uint8_t RDFR = 0x48;
         cs_low();
         spi_tx_cmd[0] = RDFR;
         err_code = nrf_drv_spi_transfer(&spi,(uint8_t const *)spi_tx_cmd,sizeof(spi_tx_cmd),spi_rx_cmd,sizeof(spi_rx_cmd));
            printf("RDFR Transfer Successful\n");
         cs_high();
    //     printf("%02x\n",spi_rx_cmd[1]);
    //     printf("%02x\n",data);
    //     printf("%02d\n",data);
           return  data;
    void write_function_register( uint8_t newValue)
        uint8_t WRFR = 0x42;
        cs_low();
        spi_tx_cmd[0] = WRFR;
        spi_tx_cmd[1] = newValue;
       err_code = nrf_drv_spi_transfer(&spi,(uint8_t const *)spi_tx_cmd,2,spi_rx_cmd,1);
       printf("WRFR Err_code: %d\n",err_code);
           printf("WRFR Transfer Successful\n");
        cs_high();
    void program_page(uint32_t address, uint8_t *data_ptr, uint32_t data_length)
         int i=0;
          uint8_t CMD_PROGRAM = 0x02;
          uint8_t spi_tx_cmd[] = {CMD_PROGRAM, (address >> 16) & 0xFF, (address >> 8) & 0xFF, (address >> 0) & 0xFF};
          uint8_t spi_rx_cmd[8];
          write_enable();
    //      read_status_register();
          cs_low();
          err_code =  nrf_drv_spi_transfer(&spi, (uint8_t const *)spi_tx_cmd, sizeof(spi_tx_cmd),spi_rx_cmd,1);
            printf("Program_page_Err_2: %d\n",err_code);
          while(data_length > 255)
              err_code = nrf_drv_spi_transfer(&spi,data_ptr,255,0,0);
                 printf("Program_page_Err_3: %d\n",err_code);
              data_ptr = data_ptr + 255;
              data_length = data_length - 255;
         err_code = nrf_drv_spi_transfer(&spi, data_ptr, data_length,m_buffer_rx,0);
             printf("Program_page_Err_4: %d\n",err_code);
          cs_high();
    void normal_read(uint32_t address, uint8_t * data_ptr, uint32_t data_length)
         uint8_t CMD_READ = 0x03;
         uint8_t spi_tx_cmd[] = {CMD_READ, (address >> 16) & 0xFF, (address >> 8) & 0xFF, (address >> 0) & 0xFF};
         static uint8_t spi_rx_cmd[256];
         cs_low();
    //   data = nrf_drv_spi_transfer(&spi, spi_tx_cmd, sizeof(spi_tx_cmd), spi_rx_cmd,sizeof(spi_rx_cmd));
         err_code = nrf_drv_spi_transfer(&spi, spi_tx_cmd, sizeof(spi_tx_cmd), spi_rx_cmd,4);
            err_code = nrf_drv_spi_transfer(&spi, 0, 0, data_ptr, 255);
            data_ptr += 255;
            data_length -= 255;
           err_code = nrf_drv_spi_transfer(&spi, 0, 0, data_ptr, data_length);
          cs_high();
    void sector_erase(uint32_t address)
        uint8_t CMD_SECTOR_ERASE = 0x20;
        uint8_t spi_tx_cmd[] = {CMD_SECTOR_ERASE, (address >> 16) & 0xFF, (address >> 8) & 0xFF, (address >> 0) & 0xFF};
        cs_low();
        write_enable();
           uint8_t spi_tx_cmd_1[1];
           spi_tx_cmd_1[0] = WREN;
           nrf_drv_spi_transfer(&spi,spi_tx_cmd_1,sizeof(spi_tx_cmd_1),0,0); // Enabling Write
        nrf_drv_spi_transfer(&spi, spi_tx_cmd, sizeof(spi_tx_cmd), 0, 0);
       cs_high();
    void block_erase(uint32_t address)
        uint8_t CMD_BLOCK_ERASE = 0xd8;
        uint8_t spi_tx_cmd[] = {CMD_BLOCK_ERASE, (address >> 16) & 0xFF, (address >> 8) & 0xFF, (address >> 0) & 0xFF};
        write_enable();
        cs_low();
       cs_high();
    void chip_erase(void)
        uint8_t CMD_CHIP_ERASE = 0x60;
       uint8_t spi_tx_cmd[] = {CMD_CHIP_ERASE};
        write_enable();
        cs_low();
        cs_high();
     * @brief SPI user event handler.
     * @param event
    void spi_event_handler(nrf_drv_spi_evt_t const * p_event,
                           void *                    p_context)
        spi_xfer_done = true;
        NRF_LOG_INFO("Transfer completed.");
        if (m_rx_buf[0] != 0)
            NRF_LOG_INFO(" Received:");
            NRF_LOG_HEXDUMP_INFO(m_rx_buf, strlen((const char *)m_rx_buf));
    void flash_spi_init()
    {   ret_code_t err_code;
        nrf_drv_spi_config_t spi_config = NRF_DRV_SPI_DEFAULT_CONFIG;
        spi_config.ss_pin   = SPI_SS_PIN;
        spi_config.miso_pin = SPI_MISO_PIN;
        spi_config.mosi_pin = SPI_MOSI_PIN;
        spi_config.sck_pin  = SPI_SCK_PIN;
        spi_config.frequency = NRF_DRV_SPI_FREQ_125K;
        APP_ERROR_CHECK(nrf_drv_spi_init(&spi, &spi_config, spi_event_handler, NULL));
        nrf_delay_ms(100);
    void flash_access_switch()
        uint8_t man_id, dev_id, status_register, function_register;
        uint8_t data_buf[READ_WRITE_LENGTH] ;
        char str_buff[50] ="Hello";
        char str_read_buff[50] ={0};
        uint8_t data_read_buffer[READ_WRITE_LENGTH];
        uint32_t address;
        uint8_t choice;
        address = 0x1000;
         uint8_t var =10;
         while(1)
             printf("Enter your choice\n");
             printf("1.Flash_ID_test\n2.Read status Register\n3.Read Function register\n4.Normal read\n5. Enable write\n6.Sector erase\n");
             printf("7.Program Page\n8.Block Erase\r\n ");
             scanf("%d",&choice);
              switch(choice)
                  case 1:
                      flash_ID_test(3);
                  case 2:
                       status_register = read_status_register();
                       printf("Status: %i\r\n", (int)status_register);
                  case 3:
                      function_register = read_function_register();
                      printf("Function: %i\r\n", (int)function_register);
                  case 4:
                      normal_read(address, data_read_buffer, 50);
                      printf("Reading address %.8x: ", address);
                      for(int i = 0; i < 50; i++)
                              printf("%d\r\n" ,(int)data_read_buffer[i]);
                      printf("\r\n");
                  case 5:
                      printf("Running write enable\r\n");
                      write_enable();
                  case 6:
                      printf("Running sector erase at address %8x\r\n",address);
                      sector_erase(address);
                  case 7:
                      for(int i =0; i < 50; i++)
                          data_buf[i] = var;
                          var++;
                      program_page(address, data_buf,sizeof(data_buf));
                      printf("Programming data at address %.8X\r\n", address);
                  case 8:
                      printf("Erasing block at addres %.8X\r\n",address);
                      block_erase(address);
              } //switch
         }//while
     } // function
          //spi_xfer_done = false;
        error_info_t err_code;
        flash_spi_init();
        flash_ID_test(3);
        flash_access_switch();
        while (1)
            // Reset rx buffer and transfer done flag
            memset(m_rx_buf, 0, m_length);
            APP_ERROR_CHECK(nrf_drv_spi_transfer(&spi, m_tx_buf, m_length, m_rx_buf, m_length));
            while (!spi_xfer_done)
                __WFE();
            NRF_LOG_FLUSH();
            bsp_board_led_invert(BSP_BOARD_LED_0);
            nrf_delay_ms(200);
    Did you get any error, out log, or logic trance of the SPI bus for the write_enable()?
     Could you try to increase the rx_buffer_length to 4 as this suggestion?
    -Amanda H.
  • This is the output when after read_status_register();
    I have changed the rx_buffer_length to 4 as per your suggestion.Still I am unable to write the data to flash and read the data from flash. Please help me with any code example if u have.
    Status_Reg_Err_code : 0
    Rdsr-stat: 00
    Rdsd stat 00
    Can u please tell me what went  wrong in my code ??
  • Did you change the code to
    printf("Rdsr-stat: %02X\n",spi_rx_cmd[2]);
    printf("Rdsd stat %02X\n",spi_rx_cmd[3]);
    after increasing rx_buffer_length to 4?
    -Amanda H.
  • Yes I did that too. But Still not able to write and read the data to and from the external flash.
    Can u please provide any sample code that will help?.
  • I would suggest using a scope or analyzer on the SPI bus to check.
    As I said at first, I don't think we have an example for that flash. You might search other flash cases on DZ for reference.
    -Amanda H.
