I've attached a Wireshark capture of an issue I am attempting to troubleshoot. I am confused as to why the peripheral is sending an Exchange MTU Request (No. 157) to the central. Afterwards, even though it appears the MTU is successfully negotiated to 512 I see packet fragmentation on my 65-72 byte notifications. I do not see fragmentation during the BLE DFU process with larger packets, so I'm sure it is something in my application code. Has anyone seen this before?
mtu_request_from_peripheral_and_unexpected_fragmentation.pcapng
UPDATE:
After diving into the SDK a little more I've found that if the max MTU is greater than the default MTU the device will attempt to negotiate to the maximum. When the MTU is negotiated it appears that the packet size is supposed to be updated as well. I've set up logging ( will add log output soon ) on my device and am seeing some odd ordering in the log messages. I also see logs from the default MTU Exchange Response handler even though my central is responding with an error.
Is it possible to disable the automatic MTU negotiation and still allow the request from the central to negotiate a larger MTU? The library I'm using (go-ble) talks directly to the Linux HCI device and has not implemented handlers for all incoming request types.
Logs from NRF52, line 7 comes from on_exchange_mtu_rsp_evt in components/ble/nrf_ble_gatt.c. I assume this is being called in reponse to the Request Not Supported packet sent from my central.
<debug> nrf_ble_gatt: Requesting to update ATT MTU to 512 bytes on connection 0x0. <debug> nrf_ble_gatt: Updating data length to 251 on connection 0x0. <info> app: Connected. <debug> nrf_ble_gatt: Peer on connection 0x0 requested an ATT MTU of 515 bytes. <debug> nrf_ble_gatt: Updating ATT MTU to 512 bytes (desired: 512) on connection 0x0. <debug> app: UNHANDLED BLE EVENT: 85 <debug> nrf_ble_gatt: ATT MTU updated to 23 bytes on connection 0x0 (response). <info> app: Data len is set to 0x17(23) <debug> app: UNHANDLED BLE EVENT: 58 <debug> nrf_ble_gatt: Data length updated to 27 on connection 0x0. <debug> nrf_ble_gatt: max_rx_octets: 27 <debug> nrf_ble_gatt: max_tx_octets: 27 <debug> nrf_ble_gatt: max_rx_time: 328 <debug> nrf_ble_gatt: max_tx_time: 328 <info> app: Data len updated to 27!
