sd_clock_hfclk_request slow
Hi
I am trying to use the internal ADC to capture an analog value every second. For this I use a timer to wake up every second, start the ADC and go back to sleep.
I used example code found on the forum. When I look at the timings, I see that this piece of code takes much longer than expected:
uint32_t p_is_running = 0;
sd_clock_hfclk_request();
while(! p_is_running) {  							//wait for the hfclk to be available
	sd_clock_hfclk_is_running((&p_is_running));
I set a pin before and after the while loop, and have measured on the scope that it takes almost 2 ms to exit the loop. And I do not even power down the device yet, my main loop is just polling the event scheduler. So I think my hfclk is already running anyway.
What could be the cause of this delay?
And why is the hfclk request / release necessary? Will it keep the chip from entering in low power if the hfclk is not released? Is that not done automatically?
As an experiment, I removed the release function at the end of the ADC IRQ handler. In that case there is no delay at all. But now I am not sure of course if I do it right if I eventually will enable the power_manage() again, to go to low power in between samples or other events.
Could anyone explain the mechanism a bit more in detail?
