SOFTDEVICE: ASSERTION FAILED after using fds_gc
I have an issue when i am doing  writing of a structure where autoprog is a struct like this :
typedef struct
    uint8_t tag_tab[TAG_ID_LENGTH];
}tag;
typedef struct {
    uint8_t reader_cfg;
    //uint8_t reader_sn[SIZE_OF_SN];
    uint8_t reader_mac[PARAM_MAC_SIZE];
    uint32_t number_of_tag;
    tag tab_tag_autorized[AUTOPROG_NB_OF_TAGS_MAX];
} PARAM_AUTOPROG_t;
When AUTOPROG_NB_OF_TAGS_MAX = 10 i have no problem during the garbage collection but when it is 100 after 3 flash_write when the fonction fds_gc() is called there is a SOFTDEVICE: ASSERTION FAILED, i don't see the link between writing to flash and the sofdevice that has a problem.
is there a way to know why the softdevice stops ?
I am using nrf52_6.1.0 with SDK 15.2.0
Thank you for your help
  • MarcAntoineProtiere said:
    Yes i am using nrf52_6.1.0 with SDK 15.2.0 ,
     So the S140 v6.1.0, right? Slight smile
    Do you mean to debug the softdevice or the application ?
     I mean the application. The reason you say it is a softdevice assert is probably because you see it in the log? If you do a debug session, you should see that it runs to the case NRF_FAULT_ID_SD_ASSERT. If you put a breakpoint here. what does the call stack look like?
    BR,
    Edvin
  • yes  S140 v6.1.0
    Yes i was using the log with NRF_LOG_INFO and i get the sofdevice assert.
    I will try do it in debug and i let you know.
  • Hi
    I tried to run the program in debug whithout the breakpoint and it has stopped at line 100 of app_error_weak.c
     * Copyright (c) 2016 - 2018, Nordic Semiconductor ASA
     * All rights reserved.
    #include "app_error.h"
    #include "nrf_log.h"
    #include "nrf_log_ctrl.h"
    #include "nrf_strerror.h"
    #if defined(SOFTDEVICE_PRESENT) && SOFTDEVICE_PRESENT
    #include "nrf_sdm.h"
    /*lint -save -e14 */
     * Function is implemented as weak so that it can be overwritten by custom application error handler
     * when needed.
    __WEAK void app_error_fault_handler(uint32_t id, uint32_t pc, uint32_t info)
        __disable_irq();
    #ifndef DEBUG
        NRF_LOG_ERROR("Fatal error");
    #else
        NRF_LOG_FINAL_FLUSH();
        switch (id)
            case NRF_FAULT_ID_SD_ASSERT:
                NRF_LOG_ERROR("SOFTDEVICE: ASSERTION FAILED");
            case NRF_FAULT_ID_APP_MEMACC:
                NRF_LOG_ERROR("SOFTDEVICE: INVALID MEMORY ACCESS");
            case NRF_FAULT_ID_SDK_ASSERT:
                assert_info_t * p_info = (assert_info_t *)info;
                NRF_LOG_ERROR("ASSERTION FAILED at %s:%u",
                              p_info->p_file_name,
                              p_info->line_num);
            case NRF_FAULT_ID_SDK_ERROR:
                error_info_t * p_info = (error_info_t *)info;
                NRF_LOG_ERROR("ERROR %u [%s] at %s:%u\r\nPC at: 0x%08x",
                              p_info->err_code,
                              nrf_strerror_get(p_info->err_code),
                              p_info->line_num,
                              pc);
                 NRF_LOG_ERROR("End of error report");
                NRF_LOG_ERROR("UNKNOWN FAULT at 0x%08X", pc);
        NRF_BREAKPOINT_COND;
        // On assert, the system can only recover with a reset.
    #ifndef DEBUG
        NRF_LOG_WARNING("System reset");
        NVIC_SystemReset();
    #else
        //app_error_save_and_stop(id, pc, info);
        while(1);
    #endif // DEBUG
    /*lint -restore */
    so after i have put a breakpoint on the line 57 to get the stack when the softdevice assert here :
    //breakpoint here{
    So the stack look like this when i have the sofdevice assert with the breakpoint:
    Can you please check sdk_config.h and look for a definition of NRF_FSTORAGE_SD_MAX_WRITE_SIZE. By default I think this is set to 4096 in most cases. Can you please try to set this to 1024 instead? this is just a backend setting, so your application logic doesn't need to think about this.
    Try that, and see if the assert still occurs.
    Edvin
  • Congrats your solution is working i have not the assert when i change this value !
    Thanks a lot for your help
