BLE_ADC SAADC sampling rate
Hello!
USing help from this forum i have successfullz transmitted adc value from one pin of AIN# to ble and reasing values successfullz but now i am facing an issue that when iever i change adc sample rat time from 250 to other lower vaalue to increase sample rat like if i write 2 that is 1/2ms will be 500hz but it gives onlz 10 to 15 ereadings it then app gives an error of gatt connection timeout 0x08 .Can someone help me with this how to set sampling rate at 500 or 1000 hz.
Thanks.
    I am happy to hear that you found some useful information for this purpose in the forums, and that you were able to successfully sample and transmit the sample over a BLE link, great!
    I am not sure I have understood you correctly here. Are you saying that if you increase the sampling rate of the SAADC then you are receiving a GATT connection timeout 0x08?
    Could you elaborate a little more on what you are doing here - how are you changing your sampling frequency? Are you working out of an example from the SDK - if so, which one? What hardware are you using, do you have a nRF52 Development Kit, or a custom board?
    If you could share some code, that would be beneficial. Please use the " Insert -> Code " option for sharing code in the forum.
    Karl
     * Copyright (c) 2014 - 2018, Nordic Semiconductor ASA
     * All rights reserved.
    /** @file
     * Peripheral: SAADC
     * Compatibility: nRF52832 rev 2/nRF52840 rev 1, SDK 15.2.0
     * Softdevice used: S132 v6.1.0/S140 v6.1.0
     * This SAADC example samples on 4 different input pins, and enables scan mode to do that. It is otherwise an
     * offsprint from the standard ble_app_uart example available in nRF5 SDK 15.2.0
     * Works together with softdevice S132 v6.1.0 on nRF52832 and S140 v6.1.0 on nRF52840
     * Transmits SAADC output to hardware UART and over BLE via Nordic UART Servive (NUS).
     * Info on NUS -> http://infocenter.nordicsemi.com/topic/com.nordic.infocenter.sdk5.v13.0.0/ble_sdk_app_nus_eval.html?cp=4_0_0_4_1_2_17
     * Info on hardware UART settings -> http://infocenter.nordicsemi.com/topic/com.nordic.infocenter.sdk5.v13.0.0/uart_example.html?cp=4_0_0_4_4_41
    #include <stdint.h>
    #include <string.h>
    #include "nordic_common.h"
    #include "nrf.h"
    #include "ble_hci.h"
    #include "ble_advdata.h"
    #include "ble_advertising.h"
    #include "ble_conn_params.h"
    #include "nrf_sdh.h"
    #include "nrf_sdh_soc.h"
    #include "nrf_sdh_ble.h"
    #include "nrf_ble_gatt.h"
    #include "nrf_ble_qwr.h"
    #include "app_timer.h"
    #include "ble_nus.h"
    #include "app_uart.h"
    #include "bsp_btn_ble.h"
    #include "nrf_pwr_mgmt.h"
    #include "nrf_drv_saadc.h"
    #include "nrf_drv_ppi.h"
    #include "nrf_drv_timer.h"
    #if defined (UART_PRESENT)
    #include "nrf_uart.h"
    #if defined (UARTE_PRESENT)
    #include "nrf_uarte.h"
    #include "nrf_log.h"
    #include "nrf_log_ctrl.h"
    #define APP_BLE_CONN_CFG_TAG            1                                           /**< A tag identifying the SoftDevice BLE configuration. */
    #define DEVICE_NAME                     "Nordic_UART"                               /**< Name of device. Will be included in the advertising data. */
    #define NUS_SERVICE_UUID_TYPE           BLE_UUID_TYPE_VENDOR_BEGIN                  /**< UUID type for the Nordic UART Service (vendor specific). */
    #define APP_BLE_OBSERVER_PRIO           3                                           /**< Application's BLE observer priority. You shouldn't need to modify this value. */
    #define APP_ADV_INTERVAL                64                                          /**< The advertising interval (in units of 0.625 ms. This value corresponds to 40 ms). */
    #define APP_ADV_DURATION                18000                                       /**< The advertising duration (180 seconds) in units of 10 milliseconds. */
    #define MIN_CONN_INTERVAL               MSEC_TO_UNITS(20, UNIT_1_25_MS)             /**< Minimum acceptable connection interval (20 ms), Connection interval uses 1.25 ms units. */
    #define MAX_CONN_INTERVAL               MSEC_TO_UNITS(75, UNIT_1_25_MS)             /**< Maximum acceptable connection interval (75 ms), Connection interval uses 1.25 ms units. */
    #define SLAVE_LATENCY                   0                                           /**< Slave latency. */
    #define CONN_SUP_TIMEOUT                MSEC_TO_UNITS(4000, UNIT_10_MS)             /**< Connection supervisory timeout (4 seconds), Supervision Timeout uses 10 ms units. */
    #define FIRST_CONN_PARAMS_UPDATE_DELAY  APP_TIMER_TICKS(5000)                       /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
    #define NEXT_CONN_PARAMS_UPDATE_DELAY   APP_TIMER_TICKS(30000)                      /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
    #define MAX_CONN_PARAMS_UPDATE_COUNT    3                                           /**< Number of attempts before giving up the connection parameter negotiation. */
    #define DEAD_BEEF                      0xDEADBEEF                                  /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
    #define UART_TX_BUF_SIZE                512                                         /**< UART TX buffer size. */
    #define UART_RX_BUF_SIZE                512                                         /**< UART RX buffer size. */
    #define SAADC_SAMPLES_IN_BUFFER         4
    #define SAADC_SAMPLE_RATE		10                                         /**< SAADC sample rate in ms. */
    BLE_NUS_DEF(m_nus, NRF_SDH_BLE_TOTAL_LINK_COUNT);                                   /**< BLE NUS service instance. */
    NRF_BLE_GATT_DEF(m_gatt);                                                           /**< GATT module instance. */
    NRF_BLE_QWR_DEF(m_qwr);                                                             /**< Context for the Queued Write module.*/
    BLE_ADVERTISING_DEF(m_advertising);                                                 /**< Advertising module instance. */
    static uint16_t   m_conn_handle          = BLE_CONN_HANDLE_INVALID;                 /**< Handle of the current connection. */
    static uint16_t   m_ble_nus_max_data_len = BLE_GATT_ATT_MTU_DEFAULT - 3;            /**< Maximum length of data (in bytes) that can be transmitted to the peer by the Nordic UART service module. */
    static ble_uuid_t m_adv_uuids[]          =                                          /**< Universally unique service identifier. */
    volatile uint8_t state = 1;
    #ifdef NRF52810_XXAA
    static const nrf_drv_timer_t   m_timer = NRF_DRV_TIMER_INSTANCE(2);
    #else
    static const nrf_drv_timer_t   m_timer = NRF_DRV_TIMER_INSTANCE(3);
    static nrf_saadc_value_t       m_buffer_pool[2][SAADC_SAMPLES_IN_BUFFER];
    static nrf_ppi_channel_t       m_ppi_channel;
    static uint32_t                m_adc_evt_counter;
    /**@brief Function for assert macro callback.
     * @warning This handler is an example only and does not fit a final product. You need to analyse
     * @param[in] line_num    Line number of the failing ASSERT call.
     * @param[in] p_file_name File name of the failing ASSERT call.
    /**@brief Function for initializing the timer module.
    static void timers_init(void)
     *          the device. It also sets the permissions and appearance.
        uint32_t                err_code;
                                              strlen(DEVICE_NAME));
        APP_ERROR_HANDLER(nrf_error);
    /**@brief Function for handling the data from the Nordic UART Service.
     * @details This function will process the data received from the Nordic UART BLE Service and send
     *          it to the UART module.
     * @param[in] p_evt       Nordic UART Service event.
    /**@snippet [Handling the data received over BLE] */
            uint32_t err_code;
            for (uint32_t i = 0; i < p_evt->params.rx_data.length; i++)
                do
                    err_code = app_uart_put(p_evt->params.rx_data.p_data[i]);
                    if ((err_code != NRF_SUCCESS) && (err_code != NRF_ERROR_BUSY))
                        NRF_LOG_ERROR("Failed receiving NUS message. Error 0x%x. ", err_code);
                } while (err_code == NRF_ERROR_BUSY);
            if (p_evt->params.rx_data.p_data[p_evt->params.rx_data.length - 1] == '\r')
                while (app_uart_put('\n') == NRF_ERROR_BUSY);
        uint32_t           err_code;
        ble_nus_init_t     nus_init;
        // Initialize NUS.
    /**@brief Function for handling an event from the Connection Parameters Module.
     * @details This function will be called for all events in the Connection Parameters Module
     *          which are passed to the application.
     * @note All this function does is to disconnect. This could have been done by simply setting
     *       the disconnect_on_fail config parameter, but instead we use the event handler
     *       mechanism to demonstrate its use.
        uint32_t err_code;
    /**@brief Function for handling errors from the Connection Parameters module.
        // Prepare wakeup buttons.
        uint32_t err_code;
        switch (ble_adv_evt)
            case BLE_ADV_EVT_FAST:
            case BLE_ADV_EVT_IDLE:
                sleep_mode_enter();
        uint32_t err_code;
            case BLE_GAP_EVT_CONNECTED:
                NRF_LOG_INFO("Connected");
                NRF_LOG_INFO("Disconnected");
                ble_gap_phys_t const phys =
                    .rx_phys = BLE_GAP_PHY_AUTO,
                    .tx_phys = BLE_GAP_PHY_AUTO,
            } break;
                // Pairing not supported
            case BLE_GATTC_EVT_TIMEOUT:
            case BLE_GATTS_EVT_TIMEOUT:
                // No implementation needed.
    /**@brief Function for the SoftDevice initialization.
     * @details This function initializes the SoftDevice and the BLE event interrupt.
        ret_code_t err_code;
        uint32_t ram_start = 0;
        // Enable BLE stack.
    /**@brief Function for handling events from the GATT library. */
    void gatt_evt_handler(nrf_ble_gatt_t * p_gatt, nrf_ble_gatt_evt_t const * p_evt)
        if ((m_conn_handle == p_evt->conn_handle) && (p_evt->evt_id == NRF_BLE_GATT_EVT_ATT_MTU_UPDATED))
            m_ble_nus_max_data_len = p_evt->params.att_mtu_effective - OPCODE_LENGTH - HANDLE_LENGTH;
            NRF_LOG_INFO("Data len is set to 0x%X(%d)", m_ble_nus_max_data_len, m_ble_nus_max_data_len);
        NRF_LOG_DEBUG("ATT MTU exchange completed. central 0x%x peripheral 0x%x",
                      p_gatt->att_mtu_desired_central,
                      p_gatt->att_mtu_desired_periph);
    /**@brief Function for initializing the GATT library. */
    void gatt_init(void)
        err_code = nrf_ble_gatt_init(&m_gatt, gatt_evt_handler);
        err_code = nrf_ble_gatt_att_mtu_periph_set(&m_gatt, NRF_SDH_BLE_GATT_MAX_MTU_SIZE);
     * @param[in]   event   Event generated by button press.
        uint32_t err_code;
        switch (event)
            case BSP_EVENT_SLEEP:
                sleep_mode_enter();
            case BSP_EVENT_DISCONNECT:
                err_code = sd_ble_gap_disconnect(m_conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION);
            case BSP_EVENT_WHITELIST_OFF:
     *          a string. The string will be be sent over BLE when the last character received was a
     *          'new line' '\n' (hex 0x0A) or if the string has reached the maximum data length.
    /**@snippet [Handling the data received over UART] */
        static uint8_t index = 0;
        uint32_t       err_code;
        switch (p_event->evt_type)
            case APP_UART_DATA_READY:
                index++;
                if ((data_array[index - 1] == '\n') ||
                    (data_array[index - 1] == '\r') ||
                    (index >= m_ble_nus_max_data_len))
                    if (index > 1)
                        do
                        } while (err_code == NRF_ERROR_RESOURCES);
                    index = 0;
            case APP_UART_FIFO_ERROR:
    /**@brief  Function for initializing the UART module.
    /**@snippet [UART Initialization] */
    static void uart_init(void)
            .rx_pin_no    = RX_PIN_NUMBER,
            .tx_pin_no    = TX_PIN_NUMBER,
            .use_parity   = false,
            .baud_rate    = NRF_UART_BAUDRATE_115200
    #else
            .baud_rate    = NRF_UARTE_BAUDRATE_115200
                           UART_RX_BUF_SIZE,
                           UART_TX_BUF_SIZE,
                           uart_event_handle,
                           APP_IRQ_PRIORITY_LOWEST,
                           err_code);
        ble_advertising_init_t init;
        init.advdata.name_type          = BLE_ADVDATA_FULL_NAME;
        init.advdata.flags              = BLE_GAP_ADV_FLAGS_LE_ONLY_LIMITED_DISC_MODE;
        init.srdata.uuids_complete.p_uuids  = m_adv_uuids;
        bsp_event_t startup_event;
        uint32_t err_code = bsp_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS, bsp_event_handler);
    static void log_init(void)
        UNUSED_RETURN_VALUE(NRF_LOG_PROCESS());
        nrf_pwr_mgmt_run();
    void timer_handler(nrf_timer_event_t event_type, void* p_context)
        nrf_drv_timer_config_t timer_config = NRF_DRV_TIMER_DEFAULT_CONFIG;
        timer_config.frequency = NRF_TIMER_FREQ_31250Hz;
        err_code = nrf_drv_timer_init(&m_timer, &timer_config, timer_handler);
        /* setup m_timer for compare event */
        uint32_t ticks = nrf_drv_timer_ms_to_ticks(&m_timer,SAADC_SAMPLE_RATE);
        nrf_drv_timer_extended_compare(&m_timer, NRF_TIMER_CC_CHANNEL0, ticks, NRF_TIMER_SHORT_COMPARE0_CLEAR_MASK, false);
        uint32_t timer_compare_event_addr = nrf_drv_timer_compare_event_address_get(&m_timer, NRF_TIMER_CC_CHANNEL0);
        uint32_t saadc_sample_event_addr = nrf_drv_saadc_sample_task_get();
        err_code = nrf_drv_ppi_channel_assign(m_ppi_channel, timer_compare_event_addr, saadc_sample_event_addr);
            uint16_t adc_value;
            uint8_t value[SAADC_SAMPLES_IN_BUFFER*2];
            uint16_t bytes_to_send;
            // set buffers
            err_code = nrf_drv_saadc_buffer_convert(p_event->data.done.p_buffer, SAADC_SAMPLES_IN_BUFFER);
            // print samples on hardware UART and parse data for BLE transmission
            printf("ADC event number: %d\r\n",(int)m_adc_evt_counter);
            for (int i = 0; i < SAADC_SAMPLES_IN_BUFFER; i++)
                printf("%d\r\n", p_event->data.done.p_buffer[i]);
                adc_value = p_event->data.done.p_buffer[i];
                value[i*2] = adc_value;
                value[(i*2)+1] = adc_value >> 8;
            // Send data over BLE via NUS service. Makes sure not to send more than 20 bytes.
            if((SAADC_SAMPLES_IN_BUFFER*2) <= 20)
                bytes_to_send = (SAADC_SAMPLES_IN_BUFFER*2);
                bytes_to_send = 20;
            uint8_t nus_string[20];
    int n = sprintf(nus_string, "%d\r\n%d\r\n", p_event->data.done.p_buffer[0], p_event->data.done.p_buffer[1]);
            err_code = ble_nus_data_send(&m_nus, nus_string, &bytes_to_send, m_conn_handle);
            if ((err_code != NRF_ERROR_INVALID_STATE) && (err_code != NRF_ERROR_NOT_FOUND))
            m_adc_evt_counter++;
    void saadc_init(void)
        nrf_drv_saadc_config_t saadc_config = NRF_DRV_SAADC_DEFAULT_CONFIG;
        saadc_config.resolution = NRF_SAADC_RESOLUTION_10BIT;
        nrf_saadc_channel_config_t channel_0_config =
            NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE(NRF_SAADC_INPUT_AIN3);
        channel_0_config.gain = NRF_SAADC_GAIN1_4;
        channel_0_config.reference = NRF_SAADC_REFERENCE_VDD4;
        err_code = nrf_drv_saadc_init(&saadc_config, saadc_callback);
        err_code = nrf_drv_saadc_channel_init(0, &channel_0_config);
        err_code = nrf_drv_saadc_buffer_convert(m_buffer_pool[0],SAADC_SAMPLES_IN_BUFFER);
        err_code = nrf_drv_saadc_buffer_convert(m_buffer_pool[1],SAADC_SAMPLES_IN_BUFFER);
    /**@brief Application main function.
        bool erase_bonds;
        // Initialize.
        uart_init();
        log_init();
        timers_init();
        power_management_init();
        ble_stack_init();
        gap_params_init();
        gatt_init();
        services_init();
        advertising_init();
        conn_params_init();
        saadc_sampling_event_init();
        saadc_init();
        // Start execution.
        advertising_start();
        // Enter main loop.
        for (;;)
            idle_state_handle();
    This is my code in this code in start #define at thiis point  SAADC_SAMPLE_RATE 10                                         /**< SAADC sample rate in ms.*/
    I have written 10 and sending 4 samples in buffer but i want to make sample rate 500 or 1000hz for this i think i have to write 2 here instead of 10 i dont know if i am correct i just want to send single sample or more samples are also fine but at the rate of 500hz or 1000hz .Kindly guide what changes should i do and if this code is fine for other working i am getting adc values on uart through UART from pin AIN3.I have removed other pins and channels init just using chnnel0 and AIN3 as input pin .This was the example of SAADc scan mode ble adc.
    Thanks
  • Hello again,
    How many samples are sent at the time is currently controlled by the SAMPLES_IN_BUFFER size, since your SAADC DONE event is where the samples are being sent, and DONE happens when your buffer is filled up here.
    Yes, if a samples is triggered every 2 ms, then there will be a total of 500 samples per second = 500 Hz.
    You will need to make sure that you are equipped to handle these samples though. If your connection interval is 20 ms, and you sample every 1 ms then you will have 20 samples to send every connection interval.
    Please change the SAADC_SAMPLE_RATE to 2. Are you not achieving the 500 Hz sampling rate? If so, what error is being generated?
    Could you also ensure that you have defined DEBUG in your preprocessor defines?
    It is illustrated in the included image:
    This will let you see any potential errors written out in the RTT debug log.
    I do not understand what you mean by this, sorry. Please rephrase or elaborate on it.
    I might be misunderstanding what you are trying to say here, but you are in fact not receiving ADC values through UART. The ADC values are sampled from AIN3 by the SAADC.
    Briefly looking over the code you have provided it seems to me that the example will send both SAADC values and characters received through UART, to a connected BLE device.
    Where is this code from?
    Karl
  • when i change SAADC_SAMPLE_RATE  to 2 it gives me error 8 : gatt connection timeout in nrf connect app .Whereas it sends on uart serial monitor data completely fine but break ble connection.I want to set sample rate to 2 but i dont know what i am doing wrong.
    This is useful information, thanks.
    Are you using nRF Connect application for Android or iOS?
    I see from some earlier, similar tickets that this problem seems to resolve if you increase the MIN_ and MAX_ connection interval.
    Could you attempt to set MIN_CONN_INTERVAL to 15, and MAX_CONN_INTERVAL to 100 ms, and see if this resolves the issue?
    If this does not work, could you provide the log from the device when this error occurs?
    Karl
