BLE_ADC SAADC sampling rate
Hello!
USing help from this forum i have successfullz transmitted adc value from one pin of AIN# to ble and reasing values successfullz but now i am facing an issue that when iever i change adc sample rat time from 250 to other lower vaalue to increase sample rat like if i write 2 that is 1/2ms will be 500hz but it gives onlz 10 to 15 ereadings it then app gives an error of gatt connection timeout 0x08 .Can someone help me with this how to set sampling rate at 500 or 1000 hz.
Thanks.
  • i didnt check abiut this debug set i will update about this tomorrow but nothing seems on code side because it send values prfctly on uart and shows on serial monitor perfectly.
    Yes, please do that and let me know.
    Yes, it sounds like the device is still running, but we will need to find out why the connection is broken.
    With DEBUG defined the device should output where the error was generated, and which error it is, if an error occurs.
    In this case, this might lead us to the reason why the connection is broken. Please define DEBUG and attach the log readout for when the connection is broken.
    Karl
