JLink Info: Reset: Halt core after reset via DEMCR.VC_CORERESET.
We are using the nRF52 DK board and Keil uvision 5.
Using SDK 17.0.0 we can successfully load and build the `examples`. If we choose `examples/peripherals` we can build and run these projects.
However, if you use examples/ble_peripherals and say choose ble_app_hts we get the following:
* JLink Info: Device "NRF52832_XXAA" selected.
JLink info:
DLL: V6.46 , compiled May 23 2019 17:49:56
Firmware: J-Link OB-SAM3U128-V2-NordicSemi compiled Jan 7 2019 14:07:15
Hardware: V1.00
S/N : 682371969
* JLink Info: Found SW-DP with ID 0x2BA01477
* JLink Info: Scanning AP map to find all available APs
* JLink Info: AP[2]: Stopped AP scan as end of AP map has been reached
* JLink Info: AP[0]: AHB-AP (IDR: 0x24770011)
* JLink Info: AP[1]: JTAG-AP (IDR: 0x02880000)
* JLink Info: Iterating through AP map to find AHB-AP to use
* JLink Info: AP[0]: Core found
* JLink Info: AP[0]: AHB-AP ROM base: 0xE00FF000
* JLink Info: CPUID register: 0x410FC241. Implementer code: 0x41 (ARM)
* JLink Info: Found Cortex-M4 r0p1, Little endian.
* JLink Info: FPUnit: 6 code (BP) slots and 2 literal slots
* JLink Info: CoreSight components:
* JLink Info: ROMTbl[0] @ E00FF000
* JLink Info: ROMTbl[0][0]: E000E000, CID: B105E00D, PID: 000BB00C SCS-M7
* JLink Info: ROMTbl[0][1]: E0001000, CID: B105E00D, PID: 003BB002 DWT
* JLink Info: ROMTbl[0][2]: E0002000, CID: B105E00D, PID: 002BB003 FPB
* JLink Info: ROMTbl[0][3]: E0000000, CID: B105E00D, PID: 003BB001 ITM
* JLink Info: ROMTbl[0][4]: E0040000, CID: B105900D, PID: 000BB9A1 TPIU
* JLink Info: ROMTbl[0][5]: E0041000, CID: B105900D, PID: 000BB925 ETM
ROMTableAddr = 0xE00FF000
* JLink Info: Reset: Halt core after reset via DEMCR.VC_CORERESET.
* JLink Info: Reset: Reset device via AIRCR.SYSRESETREQ.
Target info:
Device: nRF52832_xxAA
VTarget = 3.300V
State of Pins:
TCK: 0, TDI: 1, TDO: 1, TMS: 1, TRES: 1, TRST: 1
Hardware-Breakpoints: 6
Software-Breakpoints: 8192
Watchpoints: 4
JTAG speed: 1000 kHz
Erase Done.
Programming Done.
Verify OK.
Application running ...
Flash Load finished at 14:17:17
and the application does not run!!!
Why are we getting
JLink Info: Reset: Halt core after reset via DEMCR.VC_CORERESET and JLink Info: Reset: Reset device via AIRCR.SYSRESETREQ?
I have seen some other posts mentioning these two, but it is usually complicated with something else or not clearly answered.
Thanks
T
