JLink Info: Reset: Halt core after reset via DEMCR.VC_CORERESET.
We are using the nRF52 DK board and Keil uvision 5.
Using SDK 17.0.0 we can successfully load and build the `examples`. If we choose `examples/peripherals` we can build and run these projects.
However, if you use examples/ble_peripherals and say choose ble_app_hts we get the following:
* JLink Info: Device "NRF52832_XXAA" selected.
JLink info:
DLL: V6.46 , compiled May 23 2019 17:49:56
Firmware: J-Link OB-SAM3U128-V2-NordicSemi compiled Jan 7 2019 14:07:15
Hardware: V1.00
S/N : 682371969
* JLink Info: Found SW-DP with ID 0x2BA01477
* JLink Info: Scanning AP map to find all available APs
* JLink Info: AP[2]: Stopped AP scan as end of AP map has been reached
* JLink Info: AP[0]: AHB-AP (IDR: 0x24770011)
* JLink Info: AP[1]: JTAG-AP (IDR: 0x02880000)
* JLink Info: Iterating through AP map to find AHB-AP to use
* JLink Info: AP[0]: Core found
* JLink Info: AP[0]: AHB-AP ROM base: 0xE00FF000
* JLink Info: CPUID register: 0x410FC241. Implementer code: 0x41 (ARM)
* JLink Info: Found Cortex-M4 r0p1, Little endian.
* JLink Info: FPUnit: 6 code (BP) slots and 2 literal slots
* JLink Info: CoreSight components:
* JLink Info: ROMTbl[0] @ E00FF000
* JLink Info: ROMTbl[0][0]: E000E000, CID: B105E00D, PID: 000BB00C SCS-M7
* JLink Info: ROMTbl[0][1]: E0001000, CID: B105E00D, PID: 003BB002 DWT
* JLink Info: ROMTbl[0][2]: E0002000, CID: B105E00D, PID: 002BB003 FPB
* JLink Info: ROMTbl[0][3]: E0000000, CID: B105E00D, PID: 003BB001 ITM
* JLink Info: ROMTbl[0][4]: E0040000, CID: B105900D, PID: 000BB9A1 TPIU
* JLink Info: ROMTbl[0][5]: E0041000, CID: B105900D, PID: 000BB925 ETM
ROMTableAddr = 0xE00FF000
* JLink Info: Reset: Halt core after reset via DEMCR.VC_CORERESET.
* JLink Info: Reset: Reset device via AIRCR.SYSRESETREQ.
Target info:
Device: nRF52832_xxAA
VTarget = 3.300V
State of Pins:
TCK: 0, TDI: 1, TDO: 1, TMS: 1, TRES: 1, TRST: 1
Hardware-Breakpoints: 6
Software-Breakpoints: 8192
Watchpoints: 4
JTAG speed: 1000 kHz
Erase Done.
Programming Done.
Verify OK.
Application running ...
Flash Load finished at 14:17:17
and the application does not run!!!
Why are we getting
JLink Info: Reset: Halt core after reset via DEMCR.VC_CORERESET and JLink Info: Reset: Reset device via AIRCR.SYSRESETREQ?
I have seen some other posts mentioning these two, but it is usually complicated with something else or not clearly answered.
Thanks
T
  • OK, installed the command line tools and run:
    C:\Users\fpformkin>nrfjprog -f nrf52 --recover
    Recovering device. This operation might take 30s.
    Erasing user code and UICR flash areas.
    Went back to Keil
    and tried programming the softdevice part of the project and get the following problem.
    JLink info:
    Firmware: J-Link OB-SAM3U128-V2-NordicSemi compiled Mar 17 2020 14:43:00
    Hardware: V1.00
    S/N : 682371969
    Target info:
    VTarget = 3.300V
    State of Pins:
    Watchpoints: 4
    Erase Done.
    Programming Done.
    Verify OK.
    Flash Load finished at 12:22:58
  • That seems like a successful flash of a program.
    Sorry you are correct. I have just loaded an application and it working fine :-). I was focusing too much on removing:
    Thank you very much for your help. It seems that
    Fixed it.
    Tom
