Secure DFU won't connect NRF51 S130 SDK 12.3.0
Hello. I am testing the Secure DFU for NRF51 with softdevice S130 provided in the SDK Version 12.3.0 following the steps in this guide. https://devzone.nordicsemi.com/nordic/short-range-guides/b/software-development-kit/posts/getting-started-with-nordics-secure-dfu-bootloader#h44sjziaea6x739chl3s2bk6zz9163
I was able to build the bootloader and flashed it to the chip. In the nRF connect application I can see the DFU advertising with the name DFUtarg, but when I try to connect to the device the connection is never established. First it says connecting then discovering, but it never goes past discovering. After a few seconds it seems to timeout and the app shows disconnected.
I also loaded the app blinky example to the device, the bootloader does jump to the application and I can establish a connection with NRF Connect and read and write the characteristics. When I enter de DFU mode pressing the button 4, DFUtarg shows up in the app, but the same problem occurs that it won't connect.
Led 3 on the dev board turns on, as I read that it should when the chip is in DFU mode, but I also noticed that Led 1 also turns on slightly after. I couldn't find anywhere in the documentation or the source code why Led 1 turns on.
I have also tried deleting the bluetooth cache and the nrf Connect cache from the phone and tested with a different phone, but the problem persists.
Any help to solve this problem would be greatly appreciated.
    Please try to see if you get the same result if you program the pre-compiled bootloader hex file in \nRF5_SDK_12.3.0_d7731ad\examples\dfu\bootloader_secure\pca10028_debug\hex\. I am not really sure what the problem could be. Have you made any changes to the bootloader code apart from adding new keys?
     LED_1 is on when advertising and turned off while connected. The LED is referenced as "ADVERTISING_LED_PIN_NO" in the project.
  • I tested with the pre-compiled bootloader hex file and it does connect.
    I only changed the dfu_public_key.c file, but I will try again from scratch in case I changed something by accident.
  • I finally got it to work using a different compiler version.
    First I was compiling with armgcc version 9.3.1 (2020-q2-update). After rebuilding and it still didn't work I downloaded the same version(4.9.3) that is in the makefile.windows file, rebuilt micro-ecc, the bootloader, and the blinky firmware using that version and it worked. I was able to connect and upload the blinky firmware through NRF Connect.
    I also did a little bit of debugging with the bootloader compiled with version 9.3.1 and noticed that when I try to connect the WDT interrupt activates.
  • Good to hear that you were able to solve this, and thanks for reporting back. If I remember correctly, the link time optimization option (-flto) messed up something with the vector table if built with other GCC versions (This SDK is verified with 4.9.3). I think it will work with 9.3.1 if you remove '-flto' in the Makefile.
